Nichia E17A/E21A series (April 19th: updated with output tests in the OP)
72 posts / 0 new
djozz
djozz's picture
Last seen: 51 min 34 sec ago
New from Nichia, flat leds no bigger than the die, E17A is 1.7x1.7mm, E21A is 2.1x2.1mm. The E21A is rated for up to 1400mA continuously/2000 mA peak. The thermal resistance seems unrealistically low: 0.3 deg/W for the E21A. Claim is 'highest flux density in the industry', sounds like what we want to hear Smile Big drawback for us flashoholics: a two-pad solder lay-out, no thermal pad. But I can see 4 E21A leds soldered to a XM-Noctigon happening, or even better, four E17A's soldered to a XP-Noctigon. My conclusion sofar: great leds, but perhaps not for the majority of us, requires some skills, but then...
Update April 19th:
I tested two of these, one E17A 5000K 80+CRI (NCSWE17AT) and one E21A 5000K 80+CRI (NVSWE21AT) for output and voltage. Because these leds have the two-pad solder lay-out, I tested them on the only suitable boards available to me that can be easily used in flashlights: my own 119-boards that I had made by Kerui electronics: 1mm thick copper core, non-DTP, the solder-pads widening into a large pour under the solder mask (see my signature line for a thread on these boards).
Here is a size comparison to other well-known leds without dome: left the E17A, middle top a Cree XP-L HI, middle bottom a dedomed XP-G2, right the E21A.
It looks like the E21A has a similar die size as a XP-L Hi, and the E17A is slightly larger than a dedomed XP-G2, but if you have a look (picture below, at 0.5mA current) at the light emitting area of the E17A (the E21A shows a similar picture) you will see that despite the looks the led is not a bare die, the actual die is considerably smaller than the total led surface, while the two shown Cree dies are evenly bright up to the edge.
So the emitting area of the E17A is similar or even a bit smaller than a dedomed XP-G2. So at equal output the E17A will have better throw. Here is the led after the test with the phosfor scraped off, the actual die is about 1mm x 1mm (and badly damaged and cracked in the middle from the test innocent )
Let's move further to the output tests.
The output test was done like all my more recent emitter tests. I described it in detail in my XP-L test. , with two minor differences that should not matter significantly for the results: I used my Integrating sphere no. II instead of no. I, and for the current I used a clamp meter, which appears to measure 0.1A lower than the power supply current-reading that I used before.
In summary: 1) just one led was tested of each type, reflowed on my non-DTP copper board  2) I used my large version II integrating sphere with high quality luxmeter, 3) the output numbers and voltages were measured with the led close to 'steady state' for each current, so warmed up and settled, you should be able to get these numbers in a well heatsinked flashlight. Mind that these are output numbers of the bare led, in a flashlight there will be losses from light obstructions, lens and optic, 4) output is in 'djozz-lumen' defined as 1/550 of the output of my Sunwayman D40A on high setting, which I hope is close to the real lumen, but at least is consistent over all my emitter tests done in integrating spheres.
The newly obained output data were plotted together with earlier obtained data from a Nichia 219C 5000K 80+CRI, and a Cree XP-G2 S4 2B, for comparison. The E17A was tested up to where it burned to death (4.6A), the E21A led was tested up to 5A at which point it was not burned yet. Later I found the death current to be around 7A.
What can be seen:
*at least on these boards these new leds can handle way less current than the 219C of XP-G2. And actually I expect them not to behave much different on a board with better heatsinking like Clemence's upcoming VirEnce boards. That is because my boards with the Nichia 144A leds have proven to handle way more power than in these tests without problem.
*the voltage is nice low, at moderate currents slightly higher than the 219C
*the output and efficiency up to 1A is good, the E21A is on par with the 219C and XP-G2
*I would use the E17A up to 1A, and the E21A up to 2A. This is actually according to the datasheets for these leds, it seems that they can not be overdriven like many other leds.
When these leds finally blow, way above the current with maximum output, it is clear where it goes wrong: in the gap between the solder pads:
But at reasonable current with close to highest output, I don't think that a bad heat path from the led area above the gap has much influence on the output of the led. I think.
Conclusion.
So these leds are are not:
*great high current high output leds that can compete with high output leds that are around already
*the new throw kings: the dies are small indeed, and they are dome-less, but they lack the output density of dedomed Cree leds and Oslon Black Flat.
But I can see a use for these leds in small lights with moderate current, say AA-lights with a boost driver. I have not tested the beam that they produce but I expect it to be very good. And being Nichia's these leds will be available (through Clemence) in very good tints and CRI, I understand even in R9080 quality.
Thanks for reading!
Edited by: djozz on 04/18/2017 - 19:03
Ouchyfoot
Ouchyfoot's picture
Last seen: 3 weeks 6 days ago
This looks like fun.
DavidEF
DavidEF's picture
Last seen: 8 hours 15 min ago
I want one! Who needs a separate thermal pad? If Nichia believes it don’t need it, or there is no benefit to it, who are we to say otherwise? So, when does the GB start?
Edit: Luminous Flux of the E21A @700mA roughly compares to XP-G2 S3 or XM-L2 T6. Package size is 2.1mm x 2.1mm for the Nichia, 3.45mm x 3.45mm for XP-G2 and 5.0mm x 5.0mm for XM-L2. So, did I say I want one? Maybe I want a few dozen! Innocent
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
UliBär
UliBär's picture
Last seen: 12 hours 28 min ago
These new Nichias look very promising for tiny pocket throwers.
How is the color rendering of these pipsqueaks?
Aloha, Uli
DavidEF
DavidEF's picture
Looks like they come in two flavors – 70CRI and 80CRI
-Ayn Rand
djozz
djozz's picture
Thanks for finding out the flux comparisons!
The package comparison is not really fair, for flux density (which is the relevant factor for throw) you need to compare die size: the XP-G2 die size is 1.5×1.5mm, compared to 2.1×2.1mm for the E21A. That suggests that the XP-G2 still wins, even though Nichia claims that high flux density. But what will happen at high current on a copper board is the question…
Ouchyfoot
Ouchyfoot's picture
Since there isn’t a separate thermal pad, I don’t think a copper board will have any advantage over an aluminum board. Since the heat transfer will be going through one, or both, (I’m assuming it will be the cathode) contact pads, there will be a dielectric layer the heat will have to go through.
Sure, you could shift the emitter so part of the cathode is making contact with the DTP, but then you will be dealing with permanent direct drive.
DavidEF
DavidEF's picture
Yeah, I knew that, but I couldn’t find anywhere that says what the die size is. If you can link a source for me, that’d be great! And of course, the XP-G2 definitely wins by a long shot, because that wasn’t even the highest binned XP-G2! Wink
Although for flux density, only the die size counts, package size does matter in other ways. I’d still like to play around with some of these Nichias. Really, if you think about it, it would seem that Cree and Nichia had some similar advances. Cree starts making flat emitter packages from existing high output dies, and also squeezing dies onto smaller packages. Then, Nichia combines those two in a “chip IS the package” deal with a flat profile. If Cree wanted to, they could easily make a direct competitor to the Nichia E17A and E21A series. They’re already really close with the packaging, and way ahead in flux density!
-Ayn Rand
DavidEF
DavidEF's picture
A copper board should still give a little advantage, because it is copper. I agree that DTP isn’t even a consideration, but copper should do better than aluminum anyway, I’d expect.
-Ayn Rand
djozz
djozz's picture
If you mount four E17A leds on a XP-Noctigon, you can have all the plus-sides of the leds on the DTP-pad and thus the flashlight body, the led-minus’s will be on the two ledwire-pads combined. Then use a reversed battery and direct the minus of the battery to the ground of your driver, making sure that the led-side ground ring of the driver does not touch the body, while the batt+ pad does make contact with the body. You can rebuild the driver for this by isolating the led-side ground ring of the driver with Kapton-tape, and boring out (just slightly, from the battery side of the driver) all the via’s going to the other side to make them loose all contact to the other side, then make two holes and wire the old batt+-pad to the led-side ground ring, and the old batt-minus pad to the led-side+. Are we still there? Wink
Ouchyfoot
Ouchyfoot's picture
I guess I should assume you were thinking about this.
DavidEF
DavidEF's picture
Umm, I don’t know much about drivers, but would there be a way you could re-work the driver to interrupt power to the LED+ instead of the LED- so that none of that drillin’ and choppin’ are necessary? Or is driver design such that your drillin’ and choppin’ IS the easy way? Or is it that the components all work on the negative side, so switching positive is basically impossible?
-Ayn Rand
djburkes
djburkes's picture
Good gosh man…so you’re basically saying that we could all be running around with 12 emitter Convoy S2+s on a triple XP board?
djozz
djozz's picture
Uhm, I guess so… 8-)
Say you can overdrive the E17A to 1500mA on a XP-Noctigon, the output (extrapolated from the Nichia datasheet graph) could be 560 lumen, times 12 is 6720 lumen, with losses 5000 lumen out the front.
… for a brief moment because you are running your S2+ at 18 amps/63W Innocent
UliBär
UliBär's picture
djozz wrote:
… for a brief moment because you are running your S2+ at 18 amps Innocent
w00t!
…and there goes the battery tube – melting away… }:-)
Aloha, Uli
Hoop
Hoop's picture
Last seen: 1 month 19 hours ago
Thanks for showing off these LED’s Djozz. I can think of a couple fancy ways to design a special star for this led.
One approach is to use a dielectric PVD coating to electrically isolate the star from the rest of the light while retaining optimal thermal transfer. Imagine a two piece star, split down the center, with the dielectric PVD coating on the bottom and sides of the stars semicircle halves. Butt these together. The gap at the center would be practically non existent but it could be shimmed ~.001” or more and that gap filled with high temp thermal epoxy. The gap between the halves would widen and bevel after it left the area under the LED, taking on more thermal epoxy to more strongly keep the star together as one piece.
A less elegant method would be to take an aluminum disc (or the head of a light) and machine two pockets across it, with only a ~.002” wide divider in the center between them. Anodize the aluminum, then embed a thick, machined copper strip into each of the pockets. A small amount of high temperature thermal epoxy would be necessary under the copper strips. Or, omitting the ~.002” aluminum divider, (so one contiguous pocket) the copper strips could be shimmed in the middle when “set” into the pockets. Filling the shim gap would be high temp epoxy. The gap could be made ~.001” or wider with this method.
chouster
Interesting. Very nice find, djozz!
djozz
djozz's picture
Hoop, that makes me think of a board I made for a Luxeon Z once: http://budgetlightforum.com/node/27544
It still works but upon heating up, after a few minutes something deforms and shorts, when cooled down it works again. I think I made the AAA insulating layer too thin.
Lightgecko
Lightgecko's picture
Last seen: 8 months 1 week ago
You could use the DTP pad for probably the cathode, and use enough thermal compound between the star and pill that there is no electrical pathway. It’s not ideal, but better than permanent DD, with a little better thermal characteristics.
Curiosity killed the cat……But I’m not a cat…..
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 6 months 4 days ago
It would be nice is someone made a cooper MCPCB with its footprint and a thin or heat conducting insulation layer. The Cree LEDs must have an insulating layer in them, but apparently it conducts heat better than the insulating layers of existing MCPCBs do.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Fritz t. Cat
I suppose by PVD you mean physical vapor deposition, that is the relevant meaning in Wikipedia. That and anodization both sound like good ways to make thermally conducting electrical insulation layers. I am thinking thin film diamond, but that is too expensive.
I think a thin sheet of something would be easier to control than a thermal epoxy layer under the star. That would really be the best way, because the area of the insulator conducting the heat is much bigger.
Lightgecko
How about the mica insulators used for TO-3 packages on heatsinks in through hole stuff? I dont remember how big a TO-3 is exactly, but i think it would be enough to fit under most stars in this small a light.
Hoop
Hoop's picture
I like djozz’s Luxeon Z approach for a diy solution. I would suggest lapping all of the surfaces very flat and then using some thin spacers between the mating parts, like a couple of small pieces of cigarette rolling paper here and there. Clamp the star between some 1-2-3 blocks or other flats for curing; excess epoxy will flow out.
I had bought some MG chemicals high temp epoxy that can tolerate reflow temps but it’s not that cheap. The thermal performance is only ~.265 w/(m·k) tho. Seems timtronics has better performing stuff, around 2.7 w/(m·k).
DavidEF
DavidEF's picture
What about a PCB from OshPark? With the thinner, double-copper boards, and plenty of vias, the heat can be spread across the whole top and bottom of the pcb to help get it away from the emitter. Mask the entire board to make it electrically insulated from the body of the flashlight, leaving only the solder pads for the wires and the emitter. The whole board would be practically DTP. Or, if you’re convinced that only the negative side is carrying heat (although I doubt that can be true, even if it’s designed that way) you could make most of the board connected to the negative side, and only an area large enough to solder the LED+ on that side of the emitter. It should be very simple/easy to design for someone who knows what they’re doing.
-Ayn Rand
Hoop
Hoop's picture
Masking the entire board would affect the thermal performance though eh? That’s what these alternative design proposals try to eliminate.
DavidEF
DavidEF's picture
Well, I’m not smart enough to know, but some have said that the junction from emitter to star is the most critical heat path. It does make some sense though, that from the relatively tiny connection point of the emitter, the heat spreads out to an increasingly large area. So, as long as the relatively large outer edge of the board can still conduct heat at least at the same rate overall as the contact area under the emitter, it’s all good, right? Like, if the area under the emitter is 1/10th the area around the rim, then the rim can conduct 1/10th as well and still work fine. I don’t know what the thermal conductivity of solder mask is, so I can’t say if it can do that or not.
Edit: Just for fun, I did some rough calculation. If you consider the entire package size to be the contact area of the emitter, you get 4.41mm² area for the larger Nichia E21A. Supposing a 20mm PCB, and assuming a 1.5mm outside edge contact, you get roughly ~45mm² area. So, like I said, you’d only need the edge of the board to conduct 1/10th as well to be able to carry away the heat as effectively as it is being carried out of the emitter.
-Ayn Rand
chouster
I think djozz already came up with the best solution. Battery inserted reversed, battery+ on the entire housing, these Nichias’ anode mounted on the thermal pad (noctigon/sinkpad), connect + and – pads on the board for a cathode; dedicated driver. That beeing said, it’s a dedicated driver what we should consider concerning OSH Park…
Hoop
Hoop's picture
Yea that does make sense. I don’t know if it would conduct through the masking 1/10th as well the DTP connection. Comparing high temp epoxies in post #23, there was a 10x difference in thermal conductivity just between two different brands of epoxy. Thermal performance can vary widely among materials.
*Edited for clarity.
DavidEF
DavidEF's picture
Hoop wrote:
Yea that does make sense. I don’t know if it would conduct through the masking 1/10th as well the DTP connection. There was a 10x difference in thermal conductivity just between two different brands of high temp epoxy.
Yeah, I just looked up thermal conductivity properties in Engineering Toolbox and the only materials that even come close to 1/10th (or better) are other metals and Diamond.
-Ayn Rand
chouster
You could also isolate the MCPCB with a disc of aluminium nitride or something. Aluminium nitride is really interresting for that kind of purposes, but it’s expensive.
EasyB
Last seen: 6 hours 17 min ago
Anyone done any testing/measurements with these? I just ordered some 5000K 70cri E21A emitters from futureelectronics and will report any measurements I do.
