I guess I should assume you were thinking about this.
Umm, I don’t know much about drivers, but would there be a way you could re-work the driver to interrupt power to the LED+ instead of the LED- so that none of that drillin’ and choppin’ are necessary? Or is driver design such that your drillin’ and choppin’ IS the easy way? Or is it that the components all work on the negative side, so switching positive is basically impossible?
Good gosh man…so you’re basically saying that we could all be running around with 12 emitter Convoy S2+s on a triple XP board?
Uhm, I guess so…
Say you can overdrive the E17A to 1500mA on a XP-Noctigon, the output (extrapolated from the Nichia datasheet graph) could be 560 lumen, times 12 is 6720 lumen, with losses 5000 lumen out the front.
… for a brief moment because you are running your S2+ at 18 amps/63W O:-)
… for a brief moment because you are running your S2+ at 18 amps O:-)
w00t!
…and there goes the battery tube - melting away… }
Thanks for showing off these LED’s Djozz. I can think of a couple fancy ways to design a special star for this led.
One approach is to use a dielectric PVD coating to electrically isolate the star from the rest of the light while retaining optimal thermal transfer. Imagine a two piece star, split down the center, with the dielectric PVD coating on the bottom and sides of the stars semicircle halves. Butt these together. The gap at the center would be practically non existent but it could be shimmed ~.001” or more and that gap filled with high temp thermal epoxy. The gap between the halves would widen and bevel after it left the area under the LED, taking on more thermal epoxy to more strongly keep the star together as one piece.
A less elegant method would be to take an aluminum disc (or the head of a light) and machine two pockets across it, with only a .002” wide divider in the center between them. Anodize the aluminum, then embed a thick, machined copper strip into each of the pockets. A small amount of high temperature thermal epoxy would be necessary under the copper strips. Or, omitting the.002” aluminum divider, (so one contiguous pocket) the copper strips could be shimmed in the middle when “set” into the pockets. Filling the shim gap would be high temp epoxy. The gap could be made ~.001” or wider with this method.
Interesting. Very nice find, djozz!
Hoop, that makes me think of a board I made for a Luxeon Z once: LuxeonZ, the making of a copper board, and testing
It still works but upon heating up, after a few minutes something deforms and shorts, when cooled down it works again. I think I made the AAA insulating layer too thin.
You could use the DTP pad for probably the cathode, and use enough thermal compound between the star and pill that there is no electrical pathway. It’s not ideal, but better than permanent DD, with a little better thermal characteristics.
It would be nice is someone made a cooper MCPCB with its footprint and a thin or heat conducting insulation layer. The Cree LEDs must have an insulating layer in them, but apparently it conducts heat better than the insulating layers of existing MCPCBs do.
I suppose by PVD you mean physical vapor deposition, that is the relevant meaning in Wikipedia. That and anodization both sound like good ways to make thermally conducting electrical insulation layers. I am thinking thin film diamond, but that is too expensive.
I think a thin sheet of something would be easier to control than a thermal epoxy layer under the star. That would really be the best way, because the area of the insulator conducting the heat is much bigger.
How about the mica insulators used for TO-3 packages on heatsinks in through hole stuff? I dont remember how big a TO-3 is exactly, but i think it would be enough to fit under most stars in this small a light.
I like djozz’s Luxeon Z approach for a diy solution. I would suggest lapping all of the surfaces very flat and then using some thin spacers between the mating parts, like a couple of small pieces of cigarette rolling paper here and there. Clamp the star between some 1-2-3 blocks or other flats for curing; excess epoxy will flow out.
I had bought some MG chemicals high temp epoxy that can tolerate reflow temps but it’s not that cheap. The thermal performance is only ~.265 w/(m·k) tho. Seems timtronics has better performing stuff, around 2.7 w/(m·k).
What about a PCB from OshPark? With the thinner, double-copper boards, and plenty of vias, the heat can be spread across the whole top and bottom of the pcb to help get it away from the emitter. Mask the entire board to make it electrically insulated from the body of the flashlight, leaving only the solder pads for the wires and the emitter. The whole board would be practically DTP. Or, if you’re convinced that only the negative side is carrying heat (although I doubt that can be true, even if it’s designed that way) you could make most of the board connected to the negative side, and only an area large enough to solder the LED+ on that side of the emitter. It should be very simple/easy to design for someone who knows what they’re doing.
Masking the entire board would affect the thermal performance though eh? That’s what these alternative design proposals try to eliminate.
Well, I’m not smart enough to know, but some have said that the junction from emitter to star is the most critical heat path. It does make some sense though, that from the relatively tiny connection point of the emitter, the heat spreads out to an increasingly large area. So, as long as the relatively large outer edge of the board can still conduct heat at least at the same rate overall as the contact area under the emitter, it’s all good, right? Like, if the area under the emitter is 1/10th the area around the rim, then the rim can conduct 1/10th as well and still work fine. I don’t know what the thermal conductivity of solder mask is, so I can’t say if it can do that or not.
Edit: Just for fun, I did some rough calculation. If you consider the entire package size to be the contact area of the emitter, you get 4.41mm² area for the larger Nichia E21A. Supposing a 20mm PCB, and assuming a 1.5mm outside edge contact, you get roughly ~45mm² area. So, like I said, you’d only need the edge of the board to conduct 1/10th as well to be able to carry away the heat as effectively as it is being carried out of the emitter.
I think djozz already came up with the best solution. Battery inserted reversed, battery+ on the entire housing, these Nichias’ anode mounted on the thermal pad (noctigon/sinkpad), connect + and - pads on the board for a cathode; dedicated driver. That beeing said, it’s a dedicated driver what we should consider concerning OSH Park…
Yea that does make sense. I don’t know if it would conduct through the masking 1/10th as well the DTP connection. Comparing high temp epoxies in post #23, there was a 10x difference in thermal conductivity just between two different brands of epoxy. Thermal performance can vary widely among materials.
*Edited for clarity.
Yea that does make sense. I don’t know if it would conduct through the masking 1/10th as well the DTP connection. There was a 10x difference in thermal conductivity just between two different brands of high temp epoxy.
Yeah, I just looked up thermal conductivity properties in Engineering Toolbox and the only materials that even come close to 1/10th (or better) are other metals and Diamond.
You could also isolate the MCPCB with a disc of aluminium nitride or something. Aluminium nitride is really interresting for that kind of purposes, but it’s expensive.
