Review: 504 XM-L from Dinodirect
I have four of them (One of them calling itself a Uniquefire L2) - three in the "old-style" 504B body which is 100% interchangeable with the Solarforce L2, even the bezel rings and one in the "new-style" 504B body.
No trouble from the switches of any of them even at full power from XM-L dropins. All of them have spent much of their lives at 3+ amps.
3-mode instead of 5, crappy tailswitch/o-ring, R-whatever on the body, offcenter emitter.
Yep, sounds like mine too!
Wonder if the driver is moddable (is that a word?) like the UF-2100?
The light really needs a medium mode, badly.
Cheap light for my gun. Wasn't expecting much, really...
+1
High PWM frequency was an incredible surprice for me.
How can a light priced like this have proper PWM when far more expensive stuff gets the Every-Mode-Strobe (tm) -version?!
OK, it´s not 5-mode as it says on the site.
For me, 3-mode is better, I don´t like skipping modes all day. Naturally, there has to be that one Strobe so whats left, 2 modes and they are IMO spaced just right. Full power & low low. No visible PWM.
Really can´t complain. Emitter aside? I´ve seen worse on far more expensive lights... 2 received, the other has it in dead center.
Clickies are working on both samples. Will receive some more soon and comment on them also.
No hate here; that bad boy went straight into a waiting L2i.
hadaplanFoy
Modes is very personal - I just happen to hate hi-lo-strobe , and the reason I put my money down was cos of the 5 mode sales pitch ...
Its just as easy to do Hi-med-lo as to do the 2 mode + junk driver [ so that peeves me a little that they chose Hi-lo-strobe as the driver of choice for so many budge lights ]
I would be a happy camper if Ultrafire sold there 3 mode driver [ Hi-med-lo ] as a after market spare part [ Id buy a 10 pack in a heart beat ] ...
In fact I feel like Emailing them now ,
Have you checked manafont? Ultrafire 3 mode XML-T6 P60 dropin. :)
That's funny, pac! 16 bucks plus for the drop-in...NOT!
I own two - and reviews have been posted ...
Well , an interesting development ..
I ran the light on high for 5 minutes while taking out the rubbish :
The beam had a nice white spot in the center , now there is a yellowy brown spot in the middle , yellow on the edge and more brown to the center ... [ of the hotspot ]
Also the entire beam has yellowed out [ damn ] , did it change tint on me ? [ I really think it has ]
I own the dd 504b it cost me $12.31 all in. The tail cap switch is really bad worse than a dollar store light. The machining, finish and knurl are all good. The tail cap oring make no contact at all.The beam pattern is ugly. I robbed a one mode 501b of an internal tailswitch and OP reflector. Now I have a nice 504 and a really bad 501 which I will fix someday.
Dang, old! I'm going to run mine for 5 minutes right now!
I have to admit; this flashlight ain't bad. My switch is fine (so far) the tint is just okay and it is far and away the best UF 50x host I've had. I don't like the 3 second mode retention time but I should have bought more than one.
Don't get me wrong; it's no L2 but it is easily the best/brightest $13 light I have Once you replace all the o-rings, lube that bad boy up, trim the pill cover disc so it doesn't flap over 1/3 of the emitter and put the right reflector in . . . okay, that came out wrong. I'm serious, I do like this light, now that I've fixed it.
pleasantlysurprisedFoy
Hi foy what is the correct size O-ring to fix my DD 504b to make a water tight tailcap seal, and where do I buy it? For the money I like this light it is worth fixing up for sure.
I think it's 18mm for the tail cap. You can get them everywhere. Lighthound ships pretty fast . . . http://www.lighthound.com/O-Rings-for-Flashlights_c_101.html
Foy
I bet the driver is moddable just like the UF2100. And while your Modding put a 47k ohm resistor across the big capacitor to make mode memory set almost instaint!
I ran mine 15 mins. straight. Got quite warm, but no ill-effects.
Old, is the reflector unscrewed from the pill, a bit?
I took the head off to inspect, and my reflector unscrewed a bit. Plopped it back in, and it had a nice brown spot of puke (wasn't round, either), and some colors that brought back some memories.
Screwed the reflector on tightly, and problems disappeared.
Prolly not the issue with yours, but perhaps it will help someone.
@BlueBeam, consider it done, ASAP! Thanks!
Seems to be a lot of variation in these. Got mine today. Perfect three modes, 2.8A 800 lumens. Not very pretty but works fine.
Reflector is screwed down tight [ Multi grip tight ]
Mine had the cool blue/purple outer tinge , yellow corona , and white center ... Now its mostly yellow , with a little white in the outer edge of the center .
Hmmm , I will run it as much as possible ... and see what happens
Mine also has the white/yellow/purple effect as well, old.
Not very nice looking on a wall, but the opossums don't seem to mind...for a few seconds.
18mm O-rings from DX fit fine.
