Sounds like a 5000-5200mAh at 10A would be fine - I just couldn’t find one short enough to work…
Seems like the same cell but the quoted length (if accurate) is longer (69.5 vs. 67.7). Mine are a tight fit already.
Because the 26650’s are made in China and I don’t trust the quality control in multi cell lights to them. Single cell lights don’t get uneven voltages. The PCB’s add that level of safety.
I have spoken to HKJ & he has recommended Keepower IMR 5200 mah unprotected button top cells at 67.40mm.
Here is his review of the cell Test/Review of Keeppower IMR26650 5200mAh (Black) 2015 | Candle Power Flashlight Forum
I am going to go with his recommendation
Sounds good - let us know how they work out. I need a some backup 26650s.
PD, I have one I ordered from Amazon for review and I LOVE it! Measured a bunch of lights tonight on the IS and included the S70.
4,545 OTF lumens and 9.22A being pulled at the tail (2*4.61A). No mods performed and running KK 26650 cells. Wonderful light!
That would explain some of the beam shots that I have seen where it would appear that it is more than 3000 lms
It is impressive that is for sure.
Nice to see them understate specs, normally it is the other way around.
The S50 has longer runtimes then Thorfire claims, also very nice.
i think you canot add the Amperes from cells in Series
4,6A stock is still impressive
I don’t doubt at all that it’s a great light, I am thinking about getting one.
But are these beam shot’s realistic?
Those pics seem to show an accurate representation of the difference between mode levels. But if you want to know if that’s how it will look to your eyes, I don’t know. I don’t have your eyes.
I second PD here.
Both the S50 and the S70 produce a massive amount of light and shining them through a tunnel of trees like in the pics would certainly give a result similar to what you see there.
I liked Thorfire before I got the S50 and S70 because when looking at the descripton of the VG10 they wrote something like “the tactical ring is renewed, the older one sucked (yes they sed the word suck) so it needed replacing” this is so not marketing speak (I hate those slick marketing talks) and it won me over.
I bought it. The VG10 is very nice and the quality and preformance of the S50 and S70 seem more then they promise us. (longer runtimes, higher lumens) and combining that with 2 year warranty and a compagny that is responding to people (unlike the unanswered emails I send to Sunwayman about a more expensive light or the stories about Olight being not responsive)
I finally received my light in the mail today. Very happy with an as is factory budget light and that rarely happens. Output, 4 mode spacing, size, it’s all as advertised. Current readings and a thorough stripping is not happening anytime soon. The two mod’s I do see are as follows;
1st thing I noticed is that the batteries are tight regardless of length. Springs are thick and well coiled. One modification I like to do on high amps light is stick these in. Gold Plated Beryllium Copper Spring 5mm H x 11mm D Both this and the original spring is 1mm dia. however the replacement is a better material. This should now allow the longest batteries listed to be used. My choice is King Kong 26700 with a magnet. Probably only replace the one under the driver to allow the tail spring to give that battery tight push needed for different lengths.
2nd thing is to look at the driver for a modest current bump.
Output is impressive, but all mods are on hold until my shoulder heals I’m in day 13 of rotator cuff surgery.
12 day’s to the UK using Deutsche Post.
This will be my first powerful light purchase. The brightest light I currently own is an old maglite 3D I popped a P4 in years and years ago. I’ve gone a little crazy lately since joining the forum and ordered a half dozen lights or so, but this S70 is the one I’m really looking forward to. Can anyone else confirm that the keeppower 5200 unprotected 26650’s are the way to go? I ordered two of them but will order something else if needs be.
Those batteries should work great in your light. Plenty of current plenty of run time.
I run them in my S70
Also have a look at this thread Thorfire S50 / microReview + Budget Mod
Apparently this simple mod on the S50, 1 blob of solder, can also be done to the S70 giving a BIG increase in performance, although the S70 is already a very bright light as stock
The Keeppower 26650 5200mAh batteries should work fine.
However, if you’re the type of flashoholic that tries to squeeze every last lumen out from his flashlights, then I’d suggest trying one of the top performers recommended by Mooch:
Plus this one, recommended by many of our BLF members:
If you compare the Keeppower 26650 5200mAh curve …
… against those of the top performers, you’ll see a considerable difference (0.3V to 0.4V) in voltage sag under 15A loading.
At the 5A loading of the Thorfire S70, the difference between the top performing batteries and the Keeppower 26650 5200mAh batteries would be much less (say 0.1V to 0.2V). And that difference would be more than compensated for by the longer run times of the Keeppower batteries.
Reference link: [Mooch’s recommendations and test results]
Got myself 2 Heter 4500mAh cells from Gearbest for the S70
They measure 10mR and 5000mAh
And the S70 seems a little bit brighter with them compared to use it with protected 18650 cells I used to test with.
Oh they were $11/
And welcome to BLF!
hey guys i used my lg 18650 HG2 fully charged at 4.10 volts gives me about 4.6 amps at the tail-cap so that puts the figures around 4000 lumen.
