Thorfire S50 Review video
4 posts / 0 new
robo819
robo819's picture
Last seen: 3 weeks 5 days ago
I received the Thorfire S50 for review from Thorfire.
My first impressions when I received this light were the great packaging that I have come to expect from Thorfire with their products, the flashlight box was inside a larger box with large bubble wrap all around it. Once I got through that and down to the light itself and pulled it from the box I knew it was a serious hunk of a light. great heft and excellent build quality.
Link to the light here: http://www.amazon.com/ThorFire-Flashlight-Searchlight-Torchlight-Waterpr...
$59.99 at the time of this review.
Video and listed specifications following that. (best if watched in full screen)
Features: Emitter Type: Cree XHP-50 Brightness: 55-2000Lm Power Source: 2 * 18650 Batteries(NOT INCLUDED) Modes: Low-Mid-High-Turbo, Hidden Strobe IPX8 Waterproof & Shockproof Hard anodized aircraft graded Aluminum alloy casing Product Weight: 450g (Excluding the battery) Size: approx 254mm (Length) * 27mm(Body Diameter) *60mm(Head Diameter) Maximum Runtime of 60 Hours at Low Output; runs on Medium for 12 Hours and on High for 3.75 Hours
What you get: ThorFire S50 Flashlight, spare O rings/tail caps/lens, and 18 months warranty with good customer services.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 03/01/2016 - 00:48
The Miller
The Miller's picture
Last seen: 6 months 1 week ago
Nice review
There is no space for a side switch, the ALU is a massive chunk where the reflector is snugged into, no big air gap there (like that first technical drawing of the to come Convoy XHP light)
The dual switch XHP light from Yhorfire is the S70, this one is simpler to disassemble.
Cigargrio is not possible but preskng the button with pinky works fine the tail had cut outs for it.
robo819
robo819's picture
You are right about no room for the side switch TM. I didn’t think about that at the time I said it I don’t guess, but the big aluminum pill is threaded right into the space a wire would need to run and switch would need to sit, so that would rule out the possibility of the side switch.
The Miller
I like that the tube is a little more narrow at the tail end (seey review for measurement’s)
Gives it an elegant look, yes I like the looks of the S50 more then the S70.
