Puh, thats great, need it in summertime this year, or next year, or…
Thank you!
Ahm yes, im in for one or two, depends on size and extras. Maybe one fully equipped - charger, power, mirror,… and one with the basics you told in the beginning
“Cree has announced the results of laboratory tests of a single high-power packaged LED that delivered almost 1600 lm with light quality that matches the incandescent lamp”
Mod it so it fits either the Uniquefire UF1401 (if I wor it out with Gearbest to get a working one) or a SRK with the V2 moonlight enabled driver.
Would that not make an ideal tabletop camping light?
Thanks for the suggestion. Looks like a great adapter but a little pricey. I was hoping someone like Den could design something cheap that can be attached to various flashlights around the house during an outage.
Which is why you’d be a great candidate to design an ultra cheap universal adapter for mass production. Heck you might even make a buck or two. Just be sure we forum members get a discount
Interested, depending on cost. I’ve been working on a “lid” light for a while, though much less powerful than this (two 18500s). Adafruit makes a stand alone Lith Ion/Li Poly micro USB charge board 3/4” square for 7 bucks. It’ll only push 500ma, but it’s self contained, affordable, available, and made here. Also, should it be of use to you, Nalgene 4 and 8 ounce polycarbonate straight wall jars have Mason threads on them (very close to the diameter you’re working with—2.625” thread OD and 2.52” jar ID). Stainless one piece Mason lids and silicone seals are available from Mason Lifestyle. I’m thinking that riveting a stainless lid to the base plate would be an easy and waterproof way to join the diffuser (if using the Nalgene jar) and body. Even better may be to cut mason threads in the aluminum housing itself and skip the lid, though the two may not work out diameter-wise.
This looks extremely promising. I’ll be in for at least one. If it had usb changing, it would definitely make it more appealing to the non-flash crowd and boost sales and gifting. Very cool, getrdun!!
the prototype under construction, though been over busy at work the last few weeks to do much progress on it, but i hope to get it ready by end of April.
I live in the mountains of East Tennessee, and with lots of trees and power lines, its not uncommon for power outages. I once went three days without power. I have a 6000kw generator, but you don’t run that for a light bulb. I’m interested for a few of these when finished. Thanks for all your work!
