That is completely unrelated to the dark theme and unrelated to anything you did. The problem is that BLF itself got a major back-end upgrade and the email notification feature doesn’t work yet. Subscribe to this thread for updates about that issue:
Thanks for the .css file TK. I wouldn’t change the .css to accommodate this list. That sort of list isn’t used that much and most people would only read it once or skip over it anyway.
I have no idea; I haven’t tried to do it with a hotkey. It’s usually pretty straightforward to just turn the extension on and off, or use the extension’s config interface to turn the theme on and off.
Oh (duh); yeah now that I installed it, in FF, I have “/User Styles” offered under /Tools/Add-ons/ —- and as yours is the only User Style there, it’s a mere 3 clicks.
FWIW, it seems easiest to manage by using the Stylish extension’s “userstyles.org” repository. Now that I have that all set up, anyway, updates are only a couple clicks.
Yup…added the userstyles.org tab…then copied your “global” affecting .css into a style specifically for budget light forum…so now it only affects this one website rather than all of them…it appears all it added was
to the front of it…everything else was straight copy/paste from your already made style
Very awesome TK!!!
or after simply clicking the tab, clicking find styles for this site, and clicking BLF After Dark BudgetLightForum dark theme by ToyKeeper and clicking install….duh, had me a smack my forhead coulda had a V8 moment just then
If there’s anyone whose posts you don’t want to see, it’s pretty easy to hide what they write. Add this to a custom style for each person on your personal blacklist:
/* block John Doe */
div.posted-by-54321 div.forum-post-content {
display: none !important;
div.posted-by-54321 div.forum-post-info {
background: linear-gradient(#b34, #512) !important;
Replace the “54321” with the numeric ID of the account, like the last part of the URL after clicking someone’s name. It’ll hide what they wrote and change the color of the post header to red. You can still see what they said by clicking the ‘quote’ button though, or viewing in another browser or incognito window.
Thanks TK,
I actually managed it and BLF After Dark is residing on my Chrome in Windows 7 Pro. Much much easier on the eyes, albeit some of the fine pring in signature lines and such is a bit difficult for me to read due to the specific blue color. I’ll adjust, I’m sure.
It blocks any posts by me, and you can change it to someone else by changing “6266” to a different number. Or copy/paste the two clauses with other numbers to add more people.
Sweet trick on iPhone or iPad…
Setting the accessibility shortcut to invert colours gives the site an awesome black and orange look when you triple click the home button.
It doesn’t need the second clause from earlier. This shorter one will remove the posts as if they weren’t even there. Quotes included by others are still visible though, and it’ll skip post numbers when something is hidden.
I just prefer to see that something was there, instead of making it entirely invisible.
(BTW, we don’t have 50,000+ users yet, but when that day comes and someone ends up with ID 54321, I apologize in advance)
