I know… I’m right there with you. I am just now and s-l-o-w-l-y getting back in communication with Simon. It is not yet the regular communication I am used to. Aside from the normal CNY thing Simon moved to a new factory and has several issues to address. What I can tell you is that this delay is in part due to Simon not wanting to release this light until it is right. It should prove worth the wait. Hang in there friends!
I don’t know if it has been mentioned, but he has a notice up on his shop at ali that he has “severe periarthritis of shoulder”, which probably isn’t helping either.
Should work pretty well, 3A isn’t really pushing a 6V emitter hard so it shouldn’t make extreme heat issues. Don’t know if that driver can take being resistor modded, some of those style don’t fare well trying that.
As long as the diameter fits or you can make it fit, should work pretty nicely.
Unfortunately, I do not have a major update to announce on the L6 quite yet. As most of you are aware there were a few complications during CNY and moving to the new factory. I can tell you that Simon is doing better physically and that things at Convoy are returning to where they should be. We are starting to make progress again but taking the extra time necessary to make sure things are done to Convoy standards. Steps are being taken to increase QC and streamline internal processes. Simon is looking for an assistant to improve this entire process but where his factory is located it is proving very difficult to find someone to fill this position who speaks English as well as Chinese. We are working out the details on the driver for the L6 currently but I can’t confirm the specifics just yet. I expect to be able to announce something with more substance fairly soon. Stay tuned…
The factory is getting ready to send the first sample to Simon. Keep in mind this and many of my threads are based on preliminary information not typically available to the general public. Bugs are usually worked out behind closed doors before the “public” sees a product… but BLF is a special place. I say this only because there could be issues that create the “one step forward, two steps back scenario”. Probably not, but just sayin…
Thanks tarver. Yes, that sums up about all I can say on the matter at this time. Simon was working with the Cree representative to try and find more tint options. I can’t promise 3000K but Simon is doing his best to bring more options to the table than the average XHP70 light. Most are simply cool white and I understand it’s not easy to find a lot of variety in this particular emitter but I did ask that he try to find something at least in the neutral range. I’ll check with him to see if any progress has been made on that front.
I got mine from Cutter in Australia, they did a Spectrum Analysis and say it does 96CRI, not sure which of Cree’s listing this is, but it definitely makes a nice light! I have it in my Olight SR-90 Intimidator with an Illuminations Machines Lum 5-90 reflector.
That sounds impressive. Can that be translated into simply a stock Cree emitter model? Simon will be dealing directly with Cree to aquire the emitters. The one you linked seems more like a Cutter branded specialty product. Also seems odd they would choose an aluminum star over copper. Simon planned to put all the XHP70 on copper.
I just found the one they said was 96CRI in they’re testing, didn’t figure the link would matter on the star as it’d be highly unlikely Simon would buy from Cutter, right?
No he won’t be buying from Cutter. The specs you listed sound like an excellent neutral option. I’m just trying to translate it into something I can tell Simon to ask his Cree rep in Hong Kong about. Should I tell him to look for XHP70 3A K4? Mention it has a high CRI and temp of 5000K?
