A real car would not be nearly as useful as a lab test. The problem with a car is that it will not be the same each time. When I test in the lab there is very little variation, making it much easier to compare the results for different products.
that’s sure. If you make a test you have to make it properly or don’t make it at all. That’s the way of engineering of course.
Thanks bytheway for everything also for always kindly reply to every question or request!
Bumping to quote from a few months ago, but with the rerelease of the BLF-348 (and potential third batch depending on demand) some more 10440 reviews would be nice, especially the quoted DQG since it’s also sold by Gearbest.
I have ordered them, now the question is how the shipping works.
I have had some problems with my test stations, but I hope that is fixed now. This means I just have a few cells I need to do before I can get to the new cells, including 30Q
A new version of the “Nice” brand lithium AA battery is released, seems to be an improvement over the old version you already reviewed. But I don’t know when or where they will be available to buy.
I have promised some manufacturers to test their cells and this has been delayed significantly due to my melting test stations, I need to test these cells first (It is nearly done).
I am also nearly out of tested cells, all the small cells I have published recently was something that would have been pushed to later, if my test stations had worked.
Thank’s for your answer. I thought something in that direction. You would not voluntarily postpone the important top cells we are all waiting for and I’m sure that your test stations are glowing. It has been a long wait, ex. the GA showed up in jan-mar 2015 and I proposed a test of it in jun.2015. A lot of testers already did tests on the top cells but we need them badly in your comparator (without protection or rewrap). Looking forward to them showing up
I have bought a few of each top cell and unfortunately they are not all fresh, being fabricated in middle 2015. Hope you get them more fresh.
Did the 4/3AF NiMH cells get into the testing queue?
Last mention was at
Thu, 06/25/2015 - 22:49
Just checking as I’m also very interested in using these
(to “downgrade” last year’s li-ion flashlights so I can give them away to people, along with a NiMH charger — RMM has a 1-mode and someday may have a multi-mode driver for 1x NiMH)
Ah, Bugsy, you here? You were the one who asked about the 4/3AF originally
I’ll split the cost of those if Bugsy can arrange to send them, and I will poke around and try to find a seller somewhere outside the US. I’m sure they’re all made elsewhere. There must be a way to escape the search bubble …
