No he won’t be buying from Cutter. The specs you listed sound like an excellent neutral option. I’m just trying to translate it into something I can tell Simon to ask his Cree rep in Hong Kong about. Should I tell him to look for XHP70 3A K4? Mention it has a high CRI and temp of 5000K?
I’ve been look through Cree data sheets and at first the only XHP70 I could find listed with any of the higher CRI ratings including 90+ is the Warm White 2600K-3700K. That was following the link from Cutter to the Cree site. Digging further down the rabbit hole I eventually found the XHP70 chart with Flux Characteristics, ANSI White Order Codes and Bins.
If anyone wants a look that is here XHP70 chart
I think within there I can found the one Dale is referring to. Specifically it looks like for 5000K with 90+ CRI the order number would be XHP70A-00-0000-0D0UK40E3.
Edit I think some of those zeros in the middle may need to be filled in with the proper characters. Once again I’m a little lost… :-/
You’re not kidding. My head was spinning after looking through several pages of charts and codes and bins and ordering number formats. I passed along what I could to Simon while trying not to overcomplicate things too much. Thanks… I think.
Can tell me someone information about waterproof grade of future flashlight?
And may be someone know concrete information about release date?
One week before today Simon has said me that release will be after 1-2 weeks. So i’m waiting for april
Hello!
It has little bit bigger waterproof than i need
And little bit costly
And i just love design of L2 and L6
I just want to clarify - will it (L6) be at least IPX8-waterproof or not?
At $250 that Acebeam should be higher than IPX8! Sheesh. And yeah the L6 looks way better IMHO.
I’ve asked Simon to confirm but I believe it will be IPX8. We should be hearing news on the release very soon. I expected him to have the first sample by now but I haven’t heard anything yet. Simon is quite a busy guy though. He’s still getting settled in the new location so it’s a bit hectic.
Exactly. 90% of the flashlights we talk about here are not waterproof unless we are specifically talking about a dive light. IPX8 is a good indication that if you drop your light in a puddle it’s going to be ok. I’m sure that Acebeam is quite waterproof which is why I was surprised only to see it rated as IPX8. Then again that rating system gets a little funny and IPX8 seems to mean anything from puddle-proof to true waterproof. :–5
I have too many lights, most are “Fun lights”. My serious work lights have to be IPX8. I’ve seen hot lights suck in water when getting immersed. Not listed as such but the better the water proofing the better it is to use in hazardous/flammable areas. All my serious lights have to survive 2 days at the bottom of a 7’ pool. I have used dive lights, interestingly not much in the manner of cooling fins but they tend to have at least twice the weight. TrustFire TR-DF003 was a light I used a lot, some serious work most camping fun light. Very heavy, very waterproof always worked which kind of surprised me.
Good: Simon got the first sample of the L6. :GRADE:
Bad: They used the wrong side switch in the sample so it can’t handle the current? :weary:
So there are still a few things to be worked out before we can see some real progress but I can confirm that it sure is a good looking light! The L2’s big brother looks mean.
Down the barrel:
Enjoying the breeze:
Hanging out with some good friends:
So, while it’s not exactly what I wanted to report at least we have a few pictures to drool over until the time comes. :-}
Edit As a few have pointed out the side switch is an e-switch so does not carry any current. I don’t know exactly what Simon was referring to but it might be heat. He did mention long ago that the first switch they tried did not like the heat from the XHP70. Whatever the case it’s a small setback but all will be worked out.
