You could try an R1 or R050 SMD resistor to lower the amps a little.
Well done! Looking forward to your S70 review/mod.
stock was “loose“ and i opened it by turning the driverspring only.
after adding the thermal paste two fingets sre needed:D
Everything was great except for the silver fingers. You should amputate them right now.
Hey, good review. I like that light, it seems like a solid build.
Does the solderblob have effect on the lower mods? Or just onthe high mode? Does it still have the stepdown timer?
just a bit
see the table in the op
did not try that - but i see no reason why it should have changed
(its a timer)
Whoops, I’m a dummy, I did not notice that. I thought it was just manufacturer specs. Thank you!
Back in stock, or at least it can be ordered. Just had one
thanks for the info!
you know where to get a code…
Martin,
Does the turbo step-down kick in at 3 minutes or does it step down sooner?
How hot (subjectively) does the modded S50 get when it reaches step-down?
Does the modded S50 continue to heat up, even after downshifting to the high mode? If so, does it step down a second time (from high to medium)?
I wonder how well the turbo step-down works for the modded S50 and whether the flashlight will overheat when left on high.
Great work, BTW!
Too bad this light is sold out at banggood
The S50 is back in stock, as of today (Friday, March 19).
And the discount code still works!
i found this video on youtube, and on here… looked like a cool, easy, mod…
Did you measure the KCD/throw before the mod? Interested in this with the great price of the group buy, but i want to know how much throw it has.
i will hit the mancave and make that measurement when the baby alloe it
Hi, does the S70 use the same driver, so it is moddable in the same way?
Cheers!
You mean “S70”?
its also only a solder blob on the S70
but i am not sure it is the same driver (cause the e-switch)
Awesome, really want to try that! Pm me code please? (For s50/s70)
