Nope. I use a VIA for LED- located right beside the FET’s tab. Footprint is not the same as the FET I normally use (NXP PSMN3R0-30YLD with LFPAK56 footprint). It’s about the same size though.
Are you saying the LFPAK56 is different from the S08? I think most people here use them interchangeably. That’s why I didn’t think they were any different.
I think they are interchangeably, but they are not the same. The footprint I made for the PSMN3R0-30YLD works perfectly for that FET, but the measurements and space between the pins are not the same as the S08. I know as I’ve just made my own S08 footprint for the SIRA00DP using the datasheet measurements.
I’m going to have to take this back… I just put them over each other and they are basically the same. The SIRA00DP has a different looking tab, and the footprint for that could be made differently, but the pins align perfectly with the PSMN3R0-30YLD… So I actually didn’t have to make another footprint. Oh well, what’s done is done.
Yes, it doesn’t start lowering until it hits the user-configured ceiling.
The lowering goes along a 64-step scale which is approximately visually linear. So, it’s hard to see but not impossible… and the first step is the most visible because I didn’t ramp down the 7135 at the top of the scale… it goes from 100% 7135 + 99% FET to 0% 7135 + 100% FET. The FET by itself is brighter than FET+7135, so the final step gets a visible bump up when using a full high-amp cell. The other levels are hard to see even when staring at it.
I really should ramp down the 7135 in the top few levels instead of going directly from 255 to 0, but I haven’t done it yet.
There’s also a somewhat visible bump at the boundary where it goes from 7135-only to both channels, but it’s not usually very noticeable.
Cooling for linear mode FET drivers:
Is it practical to use metal core printed circuit boards for drivers, as everyone (but the very cheapest) does for the LED? Or is there nowhere to get them made in small numbers? If not that, how about copper braid stuck on the FET with thermal epoxy?
People are already leaving a lot of copper around the FET, but more on other parts of the board might help the heat transfer (as well as helping reduce high frequency spikes).
Someone here has taken measurements and says that potting helps a lot.
More radical approaches are fans and liquid cooling. I once saw a Cray II working. It was in a fish tank full of low viscosity freon. There were streaks of tiny bubbles rising from the components.
10x for your efforts, i finally got time today to build and that bistro driver of yours- it works great with Attiny25v 10su and ssu
It does have issues( investigating) with both Attiny25 and 85 20su/ssu - it changes modes on a random base,freely
Anyway, can i use your code in order to make a simple hunting bistro firmare? Something like 1-2-3 modes selectable/offtime ofc and a temp.calibration ?
After reading both your existing approach and TK’s I think it’s reasonable to say that a properly tuned PID should be much better than either. That said, PID tuning escapes many people. It’s escaped me so far, but I haven’t made a serious try at it. There should be plenty of demos showing PID responding to interesting situations.
This is true, apparently the intention was to make high-power parts footprint-compatible with the pre-existing low-power MOSFETs already being packaged in SO8.
I’ve been providing the thermal pad since the first FET driver I showed off. (it also provided a DPAK footprint in the same place! [Certainly this would make locating the Power-SO8 FET during soldering difficult.])
Latest Narsil (requires an ATtiny85 with FET+1 driver) uploaded with a few new features:
expanded modes sets from 8 to 12, new mode set supports up to 8 mode levels (7 + moon)
An Indicator LED (SMD LED) is supported as a locator LED and low voltage indicator
Moonlight mode can be optionally added (enable/disable), and the moon output level custom set
Here's the summary of configuration settings:
Configuration UI Operation
The main Configuration UI settings is activated from OFF or ON by click& hold for at least 2.5 seconds. The light will display a strobe, but if you continue to hold, strobe will stop and the light will blink 2 times quickly, and once slowly to indicate the Configuration UI mode is active. There are 5 settings, listed in the table below. You can change or leave any of these settings – there’s no need to set each one. Clicks choose the value for each setting, and each click will blink the light to acknowledge the click. If no clicks are entered in 4 seconds, the light jumps to the next configuration setting indicated by 2 quick blinks and slow quicks of the number for what setting it is (ex: 3 slow blinks means the 3rd setting). You can bypass the timeout by doing a click&hold to skip to the next setting. If you continue to hold it, it will exit configuration UI settings mode altogether, indicated by 4 quick blinks.
The Advanced Configuration UI settings is activated from Battery Check mode by doing a click& hold for at least 1.1 seconds. The battery voltage reading will be interrupted, then the light will blink 2 times quickly, and once slowly to indicate the Adv. Configuration UI mode is active. There are 5 settings summarized below.
Advanced Configuration Settings
Setting #
Function
Clicks
Defaults
1
Locator LED feature
1=disable, 2=enable
1
2
Set Moonlight Level
1 - 7 (PWM value)
3
4
Battery level Indicator LED Only
1=disable, 2=enable
1
3
Indicator LED Enable
1=disable, 2=enable
2
5
Power switch modes w/mem
1=disable, 2=enable
1
Full Atmel Studio project source code, ZIP'ed, manual in docx and PDF format, and .BAT files for downloading and setting fuses posted on a google share drive here: google drive - Narsil share
Some mods running Narsil w/Indicator LED support (BLF SD10, UF-T18, ZY-T11 clone, SWM C20C):
Thanks All! Notice the brightness of those LEDs? Wayy too low resistance used. On the UF-T18 there was a resistor already mounted on the switch PCB, but must be low. Probably only used for blinking in stock driver - looks ok when blinked, super bright when on steady.
Actually the UF-T18's switch LED is the ultimate low moon mode. It actually throws a pretty good amt of light ().
Ok - I’m calling the physical SMD LED wired to pin #3 the “Indicator LED”, but the “locator LED” is the functionality of it being ON when the main LED is OFF. Thought this might be confusing, so no prob, ask away.
I took only a brief look at PID before deciding on something simpler. The atmel example code I found for it compiled to like 5500 bytes and the MCU only had 2048, so I put it aside and tried to come up with something tiny instead. However, I hear PID can be implemented in far less space than what I found…
