Hello guys... I am going to make a purchase from DX tomorrow morning (including a Trustfire X9 ) and was wondering which of the following switches would fit best in the Ultrafire WF-504B and which is the most durable. The only part of the torch I do not trust is the switch (current one is broken).
Edit: if you know of anywhere else that sells good quality switches (at a reasonable price) or ones that are mod-able to make them reliable I would love to hear where. Cheers
Thanks for the reply... well after playing round with the switch a bit (while measuring it up) I found out it is not actually broken... seems there is just bad contact between the retaining ring and the switch. Go figuar
Your reply did in a way fix the problem though.. it made me measure up the switch. It would have sucked to order a switch only to find it did not fix the problem. Now all I have to do is figuar a way of keeping the retaining ring and switch in constant contact.
