thanks for the info!
you know where to get a code…
Martin,
Does the turbo step-down kick in at 3 minutes or does it step down sooner?
How hot (subjectively) does the modded S50 get when it reaches step-down?
Does the modded S50 continue to heat up, even after downshifting to the high mode? If so, does it step down a second time (from high to medium)?
I wonder how well the turbo step-down works for the modded S50 and whether the flashlight will overheat when left on high.
Great work, BTW!
Too bad this light is sold out at banggood
The S50 is back in stock, as of today (Friday, March 19).
And the discount code still works!
i found this video on youtube, and on here… looked like a cool, easy, mod…
Did you measure the KCD/throw before the mod? Interested in this with the great price of the group buy, but i want to know how much throw it has.
i will hit the mancave and make that measurement when the baby alloe it
Hi, does the S70 use the same driver, so it is moddable in the same way?
Cheers!
You mean “S70”?
its also only a solder blob on the S70
but i am not sure it is the same driver (cause the e-switch)
Awesome, really want to try that! Pm me code please? (For s50/s70)
Do you mean that this same mod would work on the S70 (by applying a solder blob)?
Or do you mean that the stock S70 comes with a solder blob at this position on the circuit board?
NVM, found the answer:
The same mod can be made on the S70
i hope i can do the S70 mod-video this week
Thanks, Martin!
According to the Taschenlampen website, the author measured 4K+ lumens from the solder-blobbed, de-domed S70. He also conjectured that the plain solder-blob modded S70 (without the de-dome) would have been around 5K lumens!
Yes - i have some contact with him and DO trust him 100%
My happyness was a bit too early. Just got a note that restock will happen only on 18th April. Let’s see…
Ditto for my S50 order. :cowboy_hat_face:
Will34 made a valid point with this question but I saw no answer. I’m hoping someone can give a range in ohms resistance that will likely achieve 4-5 amps.
Yeah I don’t think there’s any doubt you could do that, but someone will need to either find a datasheet for the components on the driver or do some trial-and-error to to find what resistor values give what results. I personally don’t have any resistors of that low value range to experiment with.
You’re right about that. There’s just not enough of these in the right hands yet to know the exact answer. I’m putting in a Mouser order and was just hoping someone could give me a likely suspect line up that I could try later. I don’t even have the light yet (Out of stock).
