Self introduction to all dear:JAXMAN brand flashlight
Hi Jaxman.
I received my Jaxman Mini C8 and E2, both Nichia 4000K. Both beam tints look great. I now have the Jaxman E3 on my wishlist.
MORE NICHIA HIGH CRI LIGHTS PLEASE!
Oh,as to C8,we think it is a good model in the time of XRE lamps. I have to say C8 is a good design in the time of XRE lamps.While now it is XML time. We can not get a good spot of a C8 with XML or XML2 lamp,while the volume of C8 is still some large. So we decide to design a smaller C8. That is portable and flood, though it have not a good throw spot.
Dear Mattlward,
Mini C8 was designed for mountain bike cyclists. That is a sport with violent vibration. In order to get a strong structure against the vibration, we use welding design instead of a retaining ring on the pill.Any retaining ring is may to be relaxed when the violent vibration occurred.
Best wishes
Dear Mig0,
Sorry for late answer. The E3 runtime of Middle and Low is 8hs and 120hs.
This is test by a Ni-MH battery,2100mAH.
We need many, how about a group buy :beer:
Dear jaxman,
Runtimes that you indicated in your post #29 are acceptable.
Unfortunately, according to aliexpress, Nichia 219b based E3 is not available anymore…
Jaxman, Set up a group buy.
Thanks.
Sorry, it is really sold out….
Now it is ok. :-/
Best regards
Hi,
I am not familar with how to set up a group buy. You can do it,I will fufill your require as I can.
You can organize the group buy,I will support you.
I’m not understanding the Nichia “high cri”. What different is this from a normal CREE LED?
And is the E3 rear button green or black?
hi,the high CRI means a better color rendering than normal Lamps.
The E3 rear button we have black and green .We can provide both the 2 color.
I actually still don’t understand, but I went ahead to purchase both the Nichia E2 and E3 anyway. Thankds!
Maybe this review from Maukka will help. He does an awesome job really dissecting the quality of the beam from the lights he reviews.
thanks.
In case anyone’s interested, the Jaxman E2 Nichia is US$14.40 at Fasttech, after code BUNNY 10% off.
5700K: https://www.fasttech.com/products/3953105
4000K: https://www.fasttech.com/products/3953106
When the Jaxman E3 Nichia will be available at Fasttech?
Dear Jaxman, are you a manufacturer or do you have a manufacturer make your lights according to specs?
If you are a manufacturer would you be interested in making a light with us, the BLF community?
The Nichias just arrived
inside a anti static bag
inside a ziplockbaggie
inside a bigger ziplockbaggie
inside bubble warp filling a box
inside a prtective yellow tape wrapping
yes this was the best protection those little leds culd have gotten, thanks!
I would really like to see you sell the host version of all of your lights. I think the quality of your lights is right up there with Convoy and would like to buy hosts.
Hi jaxman,
last month, i wanted to order the m8 in 7, but it wasnot available. At the same time the cometa should arrive in Europe, but till now it is not there.
Now i want your original jaxman x1 ,but it seems you make it a little complicate for me:
Xhp shows a cross!!, is 6v and needs two batteries, because there is NO booster, allthough a mt g2 is not there….
So, only the old one with this simple ui and not sooo modern cree led should be your answer to this cometa dissaster??
I think not. I cannot believe, that you are not able to make it better.
Best regards
