After reading both your existing approach and TKās I think itās reasonable to say that a properly tuned PID should be much better than either. That said, PID tuning escapes many people. Itās escaped me so far, but I havenāt made a serious try at it. There should be plenty of demos showing PID responding to interesting situations.
This is true, apparently the intention was to make high-power parts footprint-compatible with the pre-existing low-power MOSFETs already being packaged in SO8.
Iāve been providing the thermal pad since the first FET driver I showed off. (it also provided a DPAK footprint in the same place! [Certainly this would make locating the Power-SO8 FET during soldering difficult.])
Latest Narsil (requires an ATtiny85 with FET+1 driver) uploaded with a few new features:
expanded modes sets from 8 to 12, new mode set supports up to 8 mode levels (7 + moon)
An Indicator LED (SMD LED) is supported as a locator LED and low voltage indicator
Moonlight mode can be optionally added (enable/disable), and the moon output level custom set
Here's the summary of configuration settings:
Configuration UI Operation
The main Configuration UI settings is activated from OFF or ON by click& hold for at least 2.5 seconds. The light will display a strobe, but if you continue to hold, strobe will stop and the light will blink 2 times quickly, and once slowly to indicate the Configuration UI mode is active. There are 5 settings, listed in the table below. You can change or leave any of these settings ā thereās no need to set each one. Clicks choose the value for each setting, and each click will blink the light to acknowledge the click. If no clicks are entered in 4 seconds, the light jumps to the next configuration setting indicated by 2 quick blinks and slow quicks of the number for what setting it is (ex: 3 slow blinks means the 3rd setting). You can bypass the timeout by doing a click&hold to skip to the next setting. If you continue to hold it, it will exit configuration UI settings mode altogether, indicated by 4 quick blinks.
The Advanced Configuration UI settings is activated from Battery Check mode by doing a click& hold for at least 1.1 seconds. The battery voltage reading will be interrupted, then the light will blink 2 times quickly, and once slowly to indicate the Adv. Configuration UI mode is active. There are 5 settings summarized below.
Advanced Configuration Settings
Setting #
Function
Clicks
Defaults
1
Locator LED feature
1=disable, 2=enable
1
2
Set Moonlight Level
1 - 7 (PWM value)
3
4
Battery level Indicator LED Only
1=disable, 2=enable
1
3
Indicator LED Enable
1=disable, 2=enable
2
5
Power switch modes w/mem
1=disable, 2=enable
1
Full Atmel Studio project source code, ZIP'ed, manual in docx and PDF format, and .BAT files for downloading and setting fuses posted on a google share drive here: google drive - Narsil share
Some mods running Narsil w/Indicator LED support (BLF SD10, UF-T18, ZY-T11 clone, SWM C20C):
Thanks All! Notice the brightness of those LEDs? Wayy too low resistance used. On the UF-T18 there was a resistor already mounted on the switch PCB, but must be low. Probably only used for blinking in stock driver - looks ok when blinked, super bright when on steady.
Actually the UF-T18's switch LED is the ultimate low moon mode. It actually throws a pretty good amt of light ().
Ok - Iām calling the physical SMD LED wired to pin #3 the āIndicator LEDā, but the ālocator LEDā is the functionality of it being ON when the main LED is OFF. Thought this might be confusing, so no prob, ask away.
I took only a brief look at PID before deciding on something simpler. The atmel example code I found for it compiled to like 5500 bytes and the MCU only had 2048, so I put it aside and tried to come up with something tiny instead. However, I hear PID can be implemented in far less space than what I foundā¦
wight linked to one that was supposed to compile in 534 bytes. Iāll start there. Space is certainly an issue, I donāt know how much I will be able to afford. My ādevelopmentā firmware is getting full, but some of that stuff can be stripped out for āuserā firmware.
I was just looking at Mountain Electronics and I saw that the DRJones H17F driver with lucidrv2 uses PID. And from reading about his UI, it seems fairly rich as well. That driver is using ATtiny25.
Yeah, Iām sure he has spent loads of time on his drivers. I was only remarking that PID is definitely possible in a small(ish) space. Hoping to encourage some of these talented people working on drivers and firmware, confirming that it can be done. It wasnāt long ago that TK didnāt know it could be.
Doc Jones is famous for getting the most of every single bit in every single byte. Heās probably got the worldās most efficient PID algorithm in terms of memory usage. Also, 2KB code space in a 25 is a nice bumpā¦ Iām amazed what heās done is so little space of the 13Aās.
Is it the time it take the heat to get from the LED to the sensor that you are compensating for?
The LED wonāt get any hotter after you reduce the current.
Just modded my SupFire M6 to add the indicator LED and light pipe, then upgraded the 85 to the latest Narsil. I used this light pipe: mouser-LPCM050CTP, only $0.56 each. Came out nice! The 3 LED's will work on a PWM setting of 2 for moon mode, and I measured a true 0.1 lumens on fresh SAM 30Q BT's. On hi, measured lumens: 5202 @start, 4991 @30 secs. It's got U3 2A XM-L2's on 20 mm Noctigons, 20 AWG wires.
I think the brightness of the indicator came out really nice using a 1K resistor with an orange LED, mounted tombstone style on a ground pad, directly in front of the light pipe (had to align the old driver/contact board up). It's bright enough to see in a well lit room, but not too bright, and mounted next to the button makes it easy to find the button in the dark. Here's some pics:
The 1K resistor, also tombstone style mounted on a pad from pin #3. The blue wire is for the switch (pin #2):
The light pipe is about 11mm long, while the M6 thickness is about 8 mm, but because I could set the LED position a bit back on the board, it matched up pretty well:
Err, it wonāt? The LEDās temperature doesnāt simply ātrackā with input current. Think about it - this is just like an electric oven. Reducing the input current may or may not reduce the temperature - it depends on ambient temp, whatās around the oven, and whether you reduced the current from 100% to 80% or maybe 50% to 30%. Somewhere in there exists a āsteady stateā break point - above that point temperature will rise and below it temperature will fall.
For this application using lookup tables is tricky: they only fully function when they are created with knowledge of the many variables (LED, battery, light mass, external mass, ambient temp). Holding or not holding the flashlight makes a huge difference, but how do we know which lookup table to use (hand vs. no-hand) at any given time?
PID lets us dodge almost everything, I think. You brought up slow/laggy measurements - that may be an issue, Iām not really certain. My immediate take is that whether itās an issue depends on your goal: I think most of us are ignoring the LED temp and are only interested in maintaining flashlight usability with very high power setups. (someone please let me know if Iām wrong!) In the case of maintaining usability, getting laggy temp measurements isnāt really a big deal - theyāll be reasonably close to āflashlight surfaceā temps and we should be able to tune the PID settings to achieve the right performance. To re-iterate - for me the ārightā performance is a flashlight which I can continue to grip without burning myself, but also a flashlight that will not become scalding hot if I set it down on a table for 60s.
Very slick Tom E, good work. What type of wire are you using for your little hookup wires? The sheathing on the green wire which goes to the LED caught my eye as oddā¦
Soo, the tiny25/45/85 includes a useful extra feature which I should point out over here. They can measure vcc internally. No pin or voltage divider resistors needed. See my post here: Flashlight Firmware Repository - #790 by Halo
