It is a little brighter to the eye than the TF, build quality about the same I would say.
The configuration on the TomTop site shows with the battery tube is misleading , as with the tube in that configuration the 18650 is at least a full inch too short to use the light that way. It will only work with 2 cells (or 3 if you have a second extension tube).
Thanks for the review, Robo. The Trustfire TR 3T6 is a flashlight I have been considering and this seems basically a cone. But, I think am going to save my pennies, waiting for the Maxtoch 2X. However this triple has a nice broad, floody beam with some distance to it and it looks like a useful flashlight. Your reviews do a good job of demonstrating a flashlight’s capabilities at varying distances. Very helpful.
The proportions are strange, thickness of tube is odd. Not crazy about the large spring ground connection a la p60 either. I wonder if the short tube is for 2 X 18500.
A big head (like C8 or Warsun Mx900 - always C8 style)
Triple led (ok floody/wall of light)
1x18650 (thinner body)
dual switch (tail cap on/off- side switch for changing mode)
Blf A6 driver
1-2 short tubes for extend the body
Budget (25-29$ shipped)
Just want to put this out there for everybody. I did a bunch of research on this 3800. Lumen 3T6 a while back and have since modified 5 of them. Most recently the Trustfire XMK which is the exact same flashlight (pill/reflector) with new styling that seems to be better quality than the original but pill/reflector is the same. Fasttech sells the nicest Trustfire 3t6 I've found with an stainless bezel. Here: https://m.fasttech.com/products/0/10000663/1059701-trustfire-tr-3t6-cree-xm-l-t6-3800lm-5-mode
The $19.00 or so for the lixada seems like a great deal since it comes with the xml2s but it would be nice if it came with the extensions for 3s cells. Fasttech may have one.
I put dedomed XML-2 U4 1C's with an MTN26DD zener modded for 3s cells in all the ones I've modified. I omitted the p60 style ground spring by soldering on copper standoffs to the driver ground ring to make zero resistance contact with the tube. Bypassed springs, bypassed switch board and spring w/18awg drilled thru brass button. Copper spring contacts. Throw in some hot Samsung 25R's or E-fests and these things scream. You have to hold on tight when you first turn it on. They got a little kick to em
