Love the lighted tail cap in the Convoy S2+, awesome!
Just installed the mcclicky kit that came in the mail this morning into a maglite tail cap.
This should be good enough right??? Haha time to make a cup of tea and head downstairs to play lathe.
Thank you, I made it with some 3mm LEDs (dremelled down ), and standard resistors. It’s a tight fit and had to try many differents values to find the compromise between good illumination and working modes (backward/forward is tricky when you add some resistors…)
Tried to upgrade the heat colored C8
Had LB led, no memory 5 mode driver
Warnted to use the AK47 driver with low cell protection 2 modegroups and a nice tinted XML.
Made a mistake and did not replace the wires banggood delivered the driver with.
So when cutting the wires to a better size after pressing it in the pill the red one came out.
No tools to push it out, it is very tight. Fear I need to use a nail and break the driver, then all I have is a A6 BLF fet driver.
So put it away and for easter we are going to paint some eggs.
Maratac Copper CR123 triple
Ok all done with the “MagClicky” mod. Looks better now.
I’m getting a reading of 4 ohms across the switch. Any thoughts on this? It seems a little high to me. I clipped a lead it the end of the spring and the other to the side of the cap.
Use a squared off toothpick or headless matchstick. You should be able to miss the components and pop it out without damage.
@Firelight- that’s a dsche quad. The cutter dtp quads aren’t available yet but they mentioned marketing them through MtnE.
Yesterday I decided to make a companion for the Mokume Sinner, to help in sizing a holster for the Mokume light and also give immediate access to spare cells. So I made a 2x18350 cell carrier that’s the same size as the Mokume light. Now I can make the holster in a more “square” configuration at about 2 1/2” wide x 3 1/2” high so a belt clip will fit behind it better.
Cut it from clear polycarbonate rod, 1” diameter. It was kind of fun boring it out, normally a bore that deep is a blind operation but the clear material enabled me to see the cutting tool and watch the chips stack making it easy to see when it needed clearing. The side walls at the cells are nearly 3.5mm thick, should be pretty impact resistant and will definitely help protect the 2 extra cells.
Dedomed XP-G2 S4 2B.
XP32 Noctigon MCPCB
2XR100 resistor mod.
719.640Cd (1.696m) at start.
709.200Cd (1.684m) at 30 seg.
Spot in low at 4m.
250m.
OMG! How in the world did you do that signature marking? Awesome!
No disrespect, but I find that 719Kcd difficult to believe. I’ve had mine (when I had one) at 500-600 and the spot is intense, even at just over 400 it threw across the Mississippi at Vicksburg. Probably deceptive though, as there is a lot of ambient light in that picture for sure. I know it’s very hard to reach those numbers, in ANY light.
I did the same thing with the 32mm Noctigon and XP-G2, found the driver very difficult to mod fully as it would peak over 8A and blow emitters at turn on, very frustrating for me to get the output limited just below ceiling. Finally traded it off.
Great work, love the writing, hoping you’ll share how you did that!
I used an electric engraver with carbide tip.
Thanks, gotta check into that. I’ve been using a very small carbide bit in my Proxxon that actually came from my Dentist! It’s prone to grab and bounce around as it’s 2 flutes.
Do you use the lowest or highest speed?
How do you go about laying it out on the light? Free hand it with a pencil first? Looks great!
What a beautiful color that C8 came out! Awesome!
And every “Fatman” is exactly the same! How? Enquiring minds want to know!
Yes. Free hand it with a pencil first.
Sorry to be so full of questions, but does that engraver vibrate the tip or spin it?
We used to have one of those, I put my Dad’s DL number on everything decades ago! Where oh where has our engraver gone?
The tip vibrates at 7200 rpm. I bought it in ALDI years ago.
The anodizing of Maxtoch is softer and easier to burn than Fenix one. The 2X logo is more like the lightpainted original.
That Convoy C8 came out gorgeous, made me want to do one, so this morning I stripped a new matte black Convoy C8 and cooked it. I saw it go a nice bronze maroon kind of color and stopped right there! It’s cooled down, I’m at the re-build it stage, but can’t decide what to do with it. Thinking about a green emitter, not sure. The green emitter I want does over 2000 lumens, has a 4.9Vf and costs over a hundred bucks!
What LED did you put in?
