[quote=J-Dub74]
Definitely, I’m very much looking forward to the first review.
[quote=J-Dub74]
No idea guys. I’m just the messenger here. He said “there is little problem with the switch ,factory didn’t use big current version switch”. That’s all I got. As far as the head goes it’s just a little bigger than the L2, maybe 5mm or so. Simon says the head diameter of the L6 is 72mm.
The OP says:
• Reflector diameter 65.48mm
• Head diameter 72mm
So if that is correct the reflector of the L6 is approximately 11.48mm bigger in diameter (~21) as the L2’s reflector. And just a couple mm’s bigger (~5) than the S70’s reflector.
Made a drawing to visualize: (picture is very close to scale 1to1, that means those cirkels represent the actual dimensions of the ID of the reflectors)
will34:Nice! Is the head significantly larger than the L2? I’m having a hard time to tell by the picture. Also, why would the side switch need to be high current?
thijsco19: will34:Nice! Is the head significantly larger than the L2? I’m having a hard time to tell by the picture. Also, why would the side switch need to be high current?
Also, how does it compare with the Thorfire S70?
That monster looks awesome!
J-Dub74:No idea guys. I’m just the messenger here. He said “there is little problem with the switch ,factory didn’t use big current version switch”. That’s all I got. As far as the head goes it’s just a little bigger than the L2, maybe 5mm or so. Simon says the head diameter of the L6 is 72mm.
The OP says:
Hey thank you for putting all that together. If that’s all accurate and the L6 reflector is larger that the S70 reflector that is good news for us.
The S70 dimension and the L2 dimension are measured with a simple ruler thus not 100% accurate (but still within 1mm :laughing:
That is indeed good news.
Will Simon make a smooth reflector, so we can choose between smooth and orange peel, for the host? That way we have a wide variety of options! I mean this L6 might look similar than the L2 but its still a different beast!
That is indeed good news.Will Simon make a smooth reflector, so we can choose between smooth and orange peel, for the host? That way we have a wide variety of options! I mean this L6 might look similar than the L2 but its still a different beast!
I’m not holding you to 100% accuracy buddy. I appreciate the approximated comparison you did.
He did say he would make both smooth reflectors for the L6 and OP for the L2 but not until after the first run of the L6. So it may be a little while but in the end we should have both reflector options for both of these big lights.
Subscribed!
I hope Simon uses a XHP70 SinkPad instead of the usual bargain basement aluminum MCPCBs.
+1,0000,000,000,000
You just have to. It’s not optional. But as DB mentioned, it will be running at a lower spec so they probably will toss the 70 on the outdated and obsolete heat insulating star. :SICK: :SICK:
That and if they decide on using an OP reflector to correct the cross? I’ll pass. I hate OP reflectors on anything. IMO. I have seen partial OP designs, so that might, might be a possibility…
That’s the thing with aluminium star, I’ve been annoyed too to see them being used in a good quality light but I’ve come to appreciate the fact that if they do what they’re designed for in the stock light then that’s fine, most buyer’s won’t even know what one is.
I have the XHP70 in my L2 with the standard smooth refector and I cannot see a cross, I don’t know if that’s because I haven’t adjusted the height of the emitter with respect to the reflector to optimise it.
Will be L6 compatible with L2 tubes or not?
I mean these tubes:
http://ru.aliexpress.com/store/product/battery-tube-for-Convoy-L2-ring-style-tube-26650-battery-tube/330416_32590614573.html
http://ru.aliexpress.com/store/product/battery-tube-for-Convoy-L2-block-style-tube-26650-battery-tube/330416_32592967403.html
Typical of nearly every large high powered flashlight, there are huge thermal bottlenecks in the head (observe the pinched areas of aluminum while following the yellow lines from the floor plate to the bezel). This will prevent heat from traveling from the floor plate through the entire head to disperse the heat into the air. The results are trapped heat at the base of the head, which also heats the batteries to high temperatures during extended use (especially the 1st cell). Using your lithium batteries to absorb heat is not good! And once they are hot, they take a long time to cool down inside the battery tube (2X not good!). :Sp
Id like to offer a few suggestions which could transform this light from just another large Convoy into one of industry renowned stellar performance that will smoke its competition in price, functionality, performance and mod friendliness:
- Bolster the wall thickness inside the head to closely follow the contours of the reflector. Keep the walls as thick as possible. There should be very little space anywhere between the reflector and the inside of the head (less than 2mm). All that dead air we now see between the reflector and head should be solid aluminum!
- Trim all that wasted aluminum from the fat mid portion of the reflector so the head can be built thicker to help conduct heat.
- Make ALL the cooling fins the same diameter as the bezel to add surface area to exchange heat with the air. While we have grown used to seeing lights with useless small tapered cooling fins, they are ineffective and only there for aesthetics. The highest concentration of heat is generated at the floor plate where the largest/deepest cooling fins are needed to conduct heat… not those silly worthless little girly fins! :Sp Its time to get serious and offer a light that works as good as it looks!
Something like a scaled up C12 (only much better):
- Keep the floor plate at least as thick as it appears to be in the rendering. It looks like a chunky 8mm. VERY NICE! The thicker the better.
- 2 x 26650 cells will get sucked dry in no time at all. Much better would be 3 x 32650 so the famous high capacity/low sag (yet inexpensive) TF32650 cells could be used. The unprotected version of those cells remain the highest capacity of all that have been tested to date (6,700mah) and dont even break a sweat at +10A. Without them, the TrustFire TR-J20 would never be able to reach its fullest, long running mod potential.
- Is the reflector really only 65mm? Again, the light would get heat soaked very quickly becasue it seriously lacks the surface area necessary to transfer the heat from a +40 watt emitter. Also, the smallish reflector would hamper the efficiency of the large XHP70. How about 100-120mm reflector? This would provide a much larger head surface area to transfer heat while putting out more lumens and throwing them much much farther for the same amount of power. :bigsmile: Its time to stop choking the potential of the incredible XHP-70 and unleash its full capability.
- Offer separate battery extension tubes for 4 cell mod configurations. Higher voltage/less amps if far less picky with power requirements than low voltage/high amps, while realizing far greater run times. Again, hopefully for 32650 cells. We can always use plastic sleeve adapters to drop down to 26650 cells for those who prefer the smaller cells (Such is the case for the TrustFire TR-J20)
- Rather a no-brainier, but a Copper DTP MCPCB should be mandatory for any flashlight that creates this much heat.
- Quality dual sided AR lens… absolutely mandatory.
- Obviously, also offer as a host kit with the ability to purchase all the parts separately (including orange peal and smooth reflectors), drivers, battery tubes, switches, etc. Id buy a ton of them in bulk quantity if the specs were changed and proven effective!
- With different battery tube, reflector finish and driver options, this could be a modular system offered from 2 - 4 cell configurations to handle the XHP-50, XHP-70 and XHP-35 while properly dispensing with the enormous amount of heat these emitters generate. A modular system would also keep manufacturing costs down while offering several different configurations… rather than just one mediocre, hot running, inefficient flashlight.
The one guy that could pull this off while maintaining a quality product is Simon. Then we could ditch all those other overpriced poorly designed XHP based flashlights and base our large single emitter flashlight mods in mostly one host. The stock offerings as well as the mod potential could be endless.
So far, the only “out of the box” large flashlight I am aware of that offers proper heat sinking, a great mod host, quality and a fair price is the TrustFire TR-J20, although it could stand to have had larger cooling fins at the base. Simon could do much better while providing the best “beast” light to date.
Im not holding my breath, but it would sure tear down all the other overpriced failures that have been based on XHP emitters so far. The changes would completely transform the light posted in the OP, but would also make it worthy for the XHP-70. Otherwise, its just another 65mm XHP (but with legendary Convoy budget quality).
Maybe offer both!!! :bigsmile: :bigsmile:
What do others think?
I like the 100 to 120 reflector.I would buy it today!!!
Same. I wish there was an affordable host for the Lum 5-90. I’ve searched high and low, and PVC isn’t my style, hah.
The 5-90 fits in the Olight SR-90 pretty well.
[quote=PrinceValorum]
Do let me know if you’d be interested in selling the host for ~$50. I’d be very interested.
I hope Simon offers xhp50 or triple xhp50 in this light.
Well that’s not going to happen because then I’d have to change my thread title to “Convoy L6 …XHP70 or XHP50 or XHP50 triple Beast!” and that’s just confusing not to mention a bit wordy.
Honestly though there is no plan to make the complete light in anything but the XHP70 at this time… however, this light will be available as a host so the sky is the limit.
Unless you’re looking for Copper for heat sinks, not gonna find much of that in the sky. Just sayin. And finding triple optics may only be slightly easier than creating your own from scratch depending on final interior head size. I’ll probably be finding all that out on my own, but still…
Triple emitter flashlights at mega power are a nightmare for a manufacturer. Litigation and all that. Interesting though, the concept of manufacturing bursting the safety bubble. It could happen… (not holding my breath or giving away the lathe just yet)
Subscribed
definitely interested
Hey J-Dub,
is there any progress? Why can Simon not talk to us directly? Does he not speak English???
Greetings
Stephan
I have heard something about release after 20-21 april:
simon mao
2016-03-31 20:47
will on available after 20days
