Could the shelf of the pill perhaps be thicker. I think since a lot of us will be using FET drivers, I don’t think the extra space for the driver is necessary. It would be nice to have even more copper in the pill.
I wouldn’t call the solder permanent. Maybe use the stock pill for your testing needs and then use the copper sink for when you’ve figured out what your favorite UI is, or just use a pretty small amount of solder unlike my 2nd post where I used a ton of it. I’ll try to remove the driver from mine with some solder wick and see how much trouble it gives me. I think it will go ok.
My initial design had retaining ring threads but I talked about the design with someone who’s opinion I value and he said don’t bother. It wouldn’t be overly difficult to do but I would have to make the retaining ring also because the stock brass ring does not have good enough threads, I think. It would probably strip or cross thread the copper.
I’ll check and get back to you. It’s probably at least double what the heatsink costs. Because of this, international orders may have to wait for a distributor to get ahold of a batch.
I made the shelf a bit thicker than the stock shelf. The stock shelf is like .036”, [.9mm] I made it .050” thick. [1.25mm] With copper being so fast at spreading heat, (3x that of brass) and the thermal path being very short, I doubt there is any sort of a bottleneck happening, but it could be made thicker, sure.
Thanks. I’m going to buy one though. I know it’s doable.
Nope, no plans for that yet.
Yes. The really old mags without a D will require their own version. The difference in size of the ID bewteen a D and non D serial is like .010”. (.25mm) It would not be hard to accommodate this, but it’s doubtful anyone’s going to ask for it. Who’s going to put a high end heatsink in a beat up 20 year old mag if not just for a laugh? We’ll see though.
Finished the first Convoy C8 pill. It’s the prototype so it’s a little crusty, and I forgot to put finishing passes in the bottom of the driver pocket so the tool marks are a bit heavy there. The wire holes are slots, which angle down into the driver pocket. This allows both 20mm or 16mm stars to be used. On the driver pocket side I put a cutout which effectively deburrs this feature. Aligning op1 features with op2 features is something machinists call “clocking.” Both the S2+ pills and C8 pills are clocked.
Too bad Convoy doesn’t make the light to take a pill anymore eh?
They look so nice and shiny and I was like: I want, I want and then I read “international shipping 37$” goddamn international shipping, can get 3xS2+ delivered, strap them together ang have ~3000 lumens S2+ triple for less than 37 freaking $ >:-#
Anyways, your cnc machining is so mesmerizing
How much space do we need under a driver? .250” maybe? Right now there’s .340” which is pretty accommodating.
I removed a driver from the pill using solder wick. It’s doable but not something I’d want to do over and over that’s for sure.
There sure are a lot of ways to retain a driver in a pill. Crimps and tabs and solder and rings and spring and things. What about using micro-miniature screws around the perimeter to retain drivers? They would have to be smaller than 0-80 in the case of the S2+. …it would have to be a #000-120 requiring a T1 torx driver. The head of that screw is .066” diameter and .026” tall. The screw diameter is .034”. Could be used on any pill really. It’s too bad they cost .50¢ a screw.
Do most folks use the glass lens in front of the triple optic? That’s my preference.
The height of a Noctigon plus a carclo triple optic is .305” [7.75mm] or so. The lens+reflector+star on the standard S2+ assembly is .075” + .460” + .062” which is .597” [15.16mm]. That’s a difference of .292” [7.42mm] and would make for a pill that’s ~.8” [20.32mm] long instead of .51”. [12.95mm] If it were made .725” [18.7mm] long it could accommodate the stock glass pretty easily…
There is no need in presicious height measurements in pilled versions. Pill can be a bit lower and screwed in the place until the lens will contact head/glass.
I was considering if the battery + were kept in the exact same position as with the stock assembly, how long the pill would be.
The difference between the lengths of the two batteries is about .585”. So we gain .292” from the switch to the Carclo optic if using no glass lens. This leaves .293” to make up for. The stock pill being .51” long with a .050” deep star pocket, it needs to be .46” long to accommodate the 20mm star and keep that same length. From the base of the star, it would need to be approximately .167” tall [4.24mm] to keep the same installed position at the rear as the stock assembly. Yea I think that’s right.
Edit: actually, the stock heatsink has length added for the brass retaining ring as well so it is effectively shorter than .51”. The length of the pill would need to be too short for my comfort.
Actually now that I think about it, you are probably correct about there not being a bottleneck. Pretty disregard my suggestion. A thicker shelf would make the pill unnecessarily heavy.
