An effort towards a repeatable test method for UV-leds. New tested: 3535 365nm Liteon led, 5050 (XM-size) 2.8A Epileds 400nm led
20 posts / 0 new
djozz
djozz's picture
Last seen: 37 sec ago
Introduction
I have tested a number of UV-leds, but sofar I have been struggling with the method: awkward to perform, not repeatable enough, sensitivity changed during the test, and a recent drawback: no good way to add a ZWB2 filter in the light path.
To be able to use a normal luxmeter, thusfar I made use of copier paper fluorescence, first by making an unstable stack of ledboard-reflector-(filter)-paper-plastic lens, and hovering above that the luxmeter (link), the last set-up was upside down with the paper covering the entrance hole of my integrating sphere (link).
What I like about it is that the fluorescence of copier paper looks to be the same over a range of wavelengths (I will measure the wavelength/fluorescence relation some day), perhaps making it (if calibrated to a known output) for 365nm-400nm leds a measure of radiation power (or more likely: a measure of the number of photons, which is slightly different). I found that a 435nm led hardly causes paper fluoresence, so 400nm seems about to be the upper limit of the method. I do not know the lower limit for this, but since leds lower than 365nm are very low in output and also very expensive, I do not expect to test many leds in this segment.
What I do not like about using paper fluorescence is that there appears to be variation in how much fluorescence copier paper shows per sheet, and that over the course of a test-session some bleaching takes place, so at the end, less is measured than should. Another potential issue is saturation of the fluorescent die: at saturation  level light intensities, a  noticable amount of die molecules is still in the excited stage when a new photon arrives and so the new photon is not absorbed and a new (blue) photon not generated, this happens at high light intensities and causes the blue fluorescence to be not lineair with the incoming UV intensity. I have not clearly noticed this effect yet but to be honest I have not tried to measure it either.
I did a (not exhausting) internet search of how others have measured the output of UV-leds, and I did not find a better method that could be performed with equipment at a hobby price-point. So what I decided was to stick to  using paper fluorescence, but with a better designed set-up, more repeatable, with less bleaching occurring, a filter holder in the light path, and taking into account the variation of fluorescence by different pieces of paper.
What I wanted to include in the measuring set-up is radiation pattern independance, but I have not (yet) been able to figure out a way to integrate UV-radiation without introducing extra (potential) sources of measurement error. So the method assumes a similar radiation pattern for the different leds that are measured. Thusfar all 365nm-400nm leds that I came across have the common familiar shaped dome and the standard ~120 degrees half-brightness angle, so I assume they can be compared this way.
Building the test set-up
Here's what I came up with:
*the piece of paper (not in the picture but during an actual test) covers the 80mm entrance hole of the integrating sphere (btw, the integrating sphere is in this method just used as a convenient already fixed luxmeter, the integration that it also does has no function for this). The led is further away from the paper than last method, causing a 70mm diameter illuminated area on the paper instead of 30mm, which should reduce the bleaching effect by a factor 5.4 , and this also helps avoiding saturation effects.
*over the paper is now a wooden 'bridge'. This makes the paper stay cooler (bleaching may just be enhanced by temperature) and it enables shifting and removing the paper during the test, this helped me measuring the fluorescence difference between sheets, and the amount of bleaching.
*in the wooden bridge is a 30mm hole, which is also the holder for a 30mm diameter ZWB2 filter in case 365nm leds are measured (for an explanation why I want to use a ZWB2 filter for 365nm leds see my test of led4power's 365nm led).
*over the hole is a small wooden shaft to hold the copper led-mount. The inside is covered with aluminium tape to redirect to the paper some of the light that is outside the ~90 degrees cone that is hitting the paper directly, in the hope that the set-up is just a little less radiation-pattern dependent. I'm not sure about the usefulness of this, but I reckon it does not do harm either.
This is how it looks in the measuring situation:
A sketch of how the light is going:
The sketch wrongly shows rays under the paper. Once the light hits the paper, it diffuses and causes fluorescence, this blue light goes in all directions, also through the paper into the integrating sphere and is then measured.
Characterisation of the set-up.
First thing to do was setting up the rig with a led running at a constant low current (checked constant-ness with the luxmeter) and then see what happened to the reading when the paper was shifted or replaced. What I found is that even within one piece of paper the amount of fluorescence varied, curiously over the width of a sheet of copier paper a bit more than over the length, the maximum variation within one sheet, with 15 sheets measured at opposite sides, was 3.7%. The difference between the lowest and highest reading found over the total 30 measurements was 11%, but on average it was much closer. Also a difference between front side up and back side up was found, on average this was about 1%.
(Things you always wanted to know about copier paper but was afraid to ask! laughing)
What I did was write down on the 15 pieces of paper (both ends were measured, so 30 readings) the luxreading with the led at constant output. I calculated the average reading, and wrote on each piece of paper the deviation from the average, which were to become the correction factors for each paper when used in actual led tests. I have now 26 measured and recorded pieces of paper now, so I can test 26 leds before I run out of them. Wink
I also fumbled a bit with the pieces of paper to see how sensitive the readings were for small shifts and curling up, but that appeared very ok. The position of the 'bridge' over the entrance hole was marked on the top of the integrating sphere with a black marker, shifting that a few mm's did also not influence the reading significantly.
For the moment the unit I use for the measured output of UV-leds is not Watt (or milliWatt), but an arbritrary unit. This is because I do not have a reliable calibration UV-led for this set-up, and the calibration would probably be different for leds of different wavelengths. The calibration is certainly different for 365nm leds which are measured with the ZWB2 filter in the light path. Using the arbitrary unit makes it possible to compare leds measured with this same set-up, and in the course of time I hope to come up with for each measured wavelength (365nm, 385nm, 400nm) a useful multiplier (based on specs of several leds) that gets you the output in mW, also for all previous tests done with this method. (If I would trust the spec-sheet of the Liteon led: 665mW@500mA,25degC, the multiplier for 365nm leds with ZWB2 filter in place would be 16.5. But the voltage in the spec.sheet, which I measured accurately, is at least 0.2V off, so beware...)
In this stage I decided that the method was good to go!
Four leds were measured, of which two new leds and two leds were re-measured for comparison
1) 2)
3)   4)
1) Liteon LTPL-C034UVH365 3535 365nm led
2) Led4powers's 3535 365nm led (with Semileds chip) re-measured
3) Epileds 2800mA 5050 400nm
4) chinese 3535 400nm led from Uniquefire 602C-UV re-measured
Edit: All leds were measured on direct thermal path MCPCB's.
The Liteon led caught my attention because the die looks the same as the well-performing led that led4power sells. I found it at tme-eu. The Epileds led was brought to my attention because The Miller mentioned it in one of his threads, it has (for colour leds) a rare XM-size, with the die (I estimate) of 1.5x1.5mm (XPG-size) and is rated for an impressive 2800mA, which is high for a 400nm led. I found it on aliexpress.
Because the measuring method has changed again, and I can not give absolute output levels, I put two leds into the test that I have measured before: led4power's 'Semileds die' 3535 365nm led, and the chinese 400nm led that is found inside the Uniquefire 602C-UV, that I found to have a very good output for its size.
First the XM-size 400nm led, the specs that I could find were meagre: Epileds, 395-400nm, 8W, radiometric power 80-100LM ( Big Smile ), voltage 3.4-3.8V, 2800mA, 120-140degrees beam angle. I was very suspicious because the manufacturer did their best to make it look like a Cree led, like the very low performing Latticebright leds. does it really draw 2800mA, and if so, is the output what you expectfrom such a current. I compared it with the ok-performing chinese 3535-size 400nm led from the UF 602C-UV that at best performance stays under 1.5A:
So it does draw well over 2800mA before maxing out, and has an output that matches the power draw, much more efficient as the led in the Uniquefire: higher output with lower voltage, and I think it even that the die has a higher luminance , making it throw better (in case you are into 400nm throw undecided)!  I like this led a lot: the voltage and current sweetspot (3A) is in a great range to use the led with an ordinary lineair driver like the 105C or Qlite, its power is 10W, and the output is very good, perhaps as high as 4W radiometric power (but this is a dangerous estimate not backed up by anything close to a calibration). The die has a good even luminance too which is good for your beam:
On to the Liteon led. It is in the exact same category as the led that led4power sells, but it costs slightly more. The die, when looked at it, gives off that same lime-ish-yellow visible light as the l4p led. So I expected similar performance.
But no, the performance is way different, better!. The voltages are very similar but the output is higher at all currents, and it maxes out at a higher current too, almost at 2A, with 0.9A for l4p's led (in my earlier test, another led from the same reel, the maximum I found was at 1.1A). If the die's are indeed the same, the package has a way lower thermal resistance which could lead to better performance, but perhaps also the die's are different after all.  Because of the new method, I wanted to be sure about the better performance of the Liteon, and built it into my Jaxman U1 that could use an upgrade from its medium performing led anyway. I have the l4p led in a BLF-A6 host shortened to 18350 with a 700mA lineair driver, so I shortened the Jaxman to 18350 also and used a 1400mA 101-AK lineair driver. If the led performed as in the test, and the hosts (especially the UV-pass filter) behave similar, I expect 3 times as much output.
And it does put out much more light, at a measured 1.2A tail current, from the graph I expected 2.8 times as much power and I measured roughly 2.15 times as much power, so not exact, but then: the lights have different reflectors and perhaps not the exact same filter, and the l4p led that was in the A6 might have been a slightly better one than the one tested. This led in the Jaxman is a keeper Smile (on top of that: I like the shortened Jaxman better than the long one, but kind of miss the Jaxman lettering)
The above picture btw was a kind of expensive one to take, I first forgot to protect my phone camera from the considerable UV-radiation from those two lights, which not only made the picture too purple (the final picture was taken with a polycarbonate filter), but now the chip is slightly damaged too, see the following shot of a completely white wall Sad  :
Although ending with this sad note, thanks for reading another test! Smile
Edited by: djozz on 07/07/2016 - 02:26
CRX
CRX's picture
Last seen: 52 min 21 sec ago
Cool, subscribed.
The Miller
The Miller's picture
Last seen: 1 year 4 months ago
CRX wrote:
Cool, subscribed.
+1 Wink
ReManG
Got to say that your method seems repeatable…
Very nice! Awaiting test results…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
keltex78
keltex78's picture
So is it just a LB XM clone with no phosphor layer? Oops
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
djozz
djozz's picture
The styling certainly is suspicious but the manufacturer is Epileds and I was pleasantly surprised by the performance.
I hope to do the test write-up tonight (it usually takes up a few hours) but if I do not have enough time it will be beginning next werk…
djozz
djozz's picture
Updated the OP with the four led tests!
deathless
Last seen: 2 days 3 hours ago
What eye protection are you using?
L4M4
L4M4's picture
Last seen: 2 weeks 2 days ago
wow, that XM-L sized LED is nice – and cheap.
available for 6.50$ on copper
I think, my 3W SupFire F3-L2 needs a new LED Wink
wight
Last seen: 9 months 4 weeks ago
djozz wrote:
The above picture btw was a kind of expensive one to take, I first forgot to protect my phone camera from the considerable UV-radiation from those two lights, which not only made the picture too purple (the final picture was taken with a polycarbonate filter), but now the chip is slightly damaged too, see the following shot of a completely white wall Aw :
Good work so far and thanks for sharing.
Sorry about your cellphone camera, that really sucks. With the amazing abilities modern camera sensors have it’s hard to remember that we can’t just point them at anything we want.
Break’s over for now. That was a long one! wight catchup Wink Wink Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Aircraft800
Last seen: 2 years 9 months ago
I’m not sure the Epileds XML 8W 5050 UV 395NM – 400NM LED specification is correct. I tried driving one with 1× 18650 and a 8xAMC7135 Single Mode Driver with the LED in direct contact with a heatsink with thermal paste. The LED died in 3 seconds. For the second attempt, I removed one 7135 chip, and the LED lasted 10 before going poof.. It seems like I am overdriving the LED even though my Fluke said I was well in spec. My meter showed around 2.7A, then after a few seconds ramped up and went poof. Any ideas what a better drive current would be? I could just keep removing 7135 chips till it works, but I have destroyed 2 already.
djozz
djozz's picture
I’m very sorry, I now realise that I forgot to mention in the OP that the led was not measured on the ledboard that it came with, but I first reflowed it on a direct thermal pad board (a Aluminium gen.2 Sinkpad in this case). I always measure leds on DTP-boards so it was easy to forget it.
I will correct the OP, but I’m sorry that you lost two leds on this Sad
That said, the led not living up to the specs on the stock board is a bad thing of course.
And as I mentioned in another BLF-thread, my second led showed a very uneven illumination, the test-led may have been a quite lucky one.
Btw, welcome to BLF! Smile
khas
Last seen: 2 days 1 hour ago
I also bought two Epileds XML 8W 5050 UV 395NM – 400NM LED on copper MCPCB. I tried driving one with a AMC7135*4 NANJG 105C about 3 sec of UV light then nothing.
At this point I was getting a little annoyed to say the least so I took a Samsung 30Q fresh form the charger hooked it up to the last LED placed on a heat sink ran it for 20 sec straight without any problems.
I hope somebody smarter than me has an answer ?
@djozz : Did you ever try the LED with a driver ?
djozz
djozz's picture
Yes I did, the led that I tested was soon after the test built into Nico’s Courui, if I remember well it had a (led4power) LD2 driver, effectively direct drive. This was a bit too much to my taste but it worked well. I’m not sure if Nico has had the light switched on for any length of time since the build though.
So it seems that the led that I tested was really a lucky one.
Henk4U2
Henk4U2's picture
Last seen: 4 hours 14 min ago
When I saw the initial test of the Epileds UV-led I ordered one on a 16mm alu pcb. From a GearBest flash sale I already had a Convoy S2+ with 8*7135 AMC with a rather ugly T6-4C color. Swapped this with the UV-led straight out of the box. No reflowing or anything like that. As battery I took a Li-Ion I ripped out of a 2200 mAh powerbank I picked up in an ACTION discount store sale for EURO 2.99. And now it is getting nice warm at the head and doing 2.72A at the tailcap. When I read what you did with Nico’s Courui I was planning on a re-run with a little bit more oomph but after reading the last posts I think I’ll stick to what I have and be very happy about it.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
khas
I put the last LED in a Convoy M1 with a CC driver from a EE X6 XP-L HI it works fine, the max output is around 3,5A on turbo, I have bumped it back to turbo three times that’s about 10 min on 3,5A it’s barely warm to touch. I don’t think it’s the heat or the current that kills the LED but the PWM from the driver. I have two more on order, when they arrive I will take the one I have now and try to run it with a AMC7135*4 driver again.
UPDATE : I got two more LEDs on copper MCPCBs tried them both in the same Convoy M1 as before, both failed within seconds Crazy . No more Epileds for me.
Jerommel
Jerommel's picture
So, i just got the Led4power emitter in, but i guess i want a Liteon LTPL-C034UVH365 now… Facepalm Big Smile
2Q19
vestureofblood
vestureofblood's picture
Last seen: 2 hours 32 min ago
As always, a very good thread!
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
doubleone44
doubleone44's picture
Sorry for the necro, but I like this technique.
Noteworthy, at the intensity of these LEDs, the double excitation of electrons is rare enough that it shouldn’t have a significant influence over thermal sag etc.
The only improvent I might make is using a remote phosphor layer instead of a sheet of paper as those are way less variant in amount of fluorophore and are resistant to bleaching (at these intensities)
All in a good read! Smile
djozz
djozz's picture
Thanks for liking the technique, and it is quite a coincidence that I just two days ago posted an upgrade of the method, I use a piece of uranium glass now instead of the paper. Smile But a sheet of remote phosfor may also work well indeed.
http://budgetlightforum.com/node/57798
