Review//Lixada 3800 Lumen Triple
66 posts / 0 new
robo819
robo819's picture
Last seen: 1 day 5 hours ago
This light was provided by TomTop for review. (Link to TomTop) http://www.tomtop.com/?aid=1199
(Link to this light) http://bit.ly/1Wd84NB
At $19.22 at the time of this review, this seems to be a decent quality light for the price. The video review and the specs listed below that.
Features: Powered by 3 * T6 LED bulbs, producing very bright beam of light. Brightness is up to 3800 lumens. Smart circuit control, five-speed memory dimming circuit(Five switch modes: High, Middle, Low, Strobe, SOS). Very solid aircraft-grade aluminum alloy flashlight shell. Hard-anodized finish; Anti-abrasive, free-scratch, shock-proof, and waterproof design.
Specifications: Brand: LIXADA Powered: By 3 * T6 LED bulbs Light Color: White LED Quantity: 3 Battery Configurations: 2 * 18650 3.7V (Not included) Switch Location: Tail-cap 5 Switch Mode: High(4500mA 3800LM) / Middle(2000mA 1500LM) / Low(450mA 380LM) / Strobe(2000mA 1500LM) / SOS Brightness: 3800 lumens LED Lifespan: 100,000 hours Material: Aluminum alloy Lens: Coated glass Reflector: Aluminum smooth reflector Casing Color: Black Item Size: 28.5 * 5.5 * 3cm / 11.22 * 2.17 * 1.18in (Max. L * Head Dia. * Tail Dia.) Item Weight: 393g / 13.87oz Package Size: 23.5 * 7.8 * 7.8cm / 9.25 * 3.07 * 3.07in Package Weight: 454g / 16oz
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
saypat
saypat's picture
Last seen: 1 day 36 min ago
howdy podner. I’ve spent more on seemingly less lights before. $19 and change seems like a great deal. You did not mention whether or not the 3800 lumens seemed accurate or not? Hard to imagine 3800 lumens for under $20 and running on (2) 18650s.
thanks for the heads up.
robo819
robo819's picture
It is really hard to guess at the triple as it puts puts out a lot of light but not a distance like a thrower would. Also I do not have a lux meter, if I had to guess or give an estimate I would say 2500 to 2800 lumes would be a more accurate number though.
WhitedragonBC
WhitedragonBC's picture
Last seen: 5 days 1 hour ago
I like the look of it without the extension. Basically a triple C8. Think the triple reflectors would out throw the triple optic in an X6?
robo819
robo819's picture
I have not seen a comparison nor do I own the X6 triple so I really could not give an honest opinion, sorry.
Manx
Last seen: 2 days 6 hours ago
+1
But why with old XM-L led? Why not with XM-L2?? :-/
www.youtube.com/channel/UCeDhMPm0L1yvr3LpygDPgMw my flashlights/knives/gear video reviews
www.absoluteblack.net my dark comics
robo819
robo819's picture
Manx wrote:
+1 But why with old XM-L led? Why not with XM-L2?? :-/
They are XM-L2 T6 emitters from what I am seeing in the light.
Chicken Drumstick
Haven’t watched the vid. Do you have any pics of the light, were you able to strip it down easy?
If it has good thermal path and easy to get to the driver, then this could make an interesting modding host.
robo819
robo819's picture
There are a lot of still shots in the video starting at 2:50 also some beamshots and shining around outside.
I didn’t take the driver out so to speak, the whole reflector pill and driver is one unit and unscrews though. The reason I didn’t take the driver itself out is because there is 3 healthy solder blobs on the outer spring and I just didn’t want to mess with it at the time. Everything else came apart really easy though.
Manx
Are you sure?
On the web site linked, in the 3° photoshot, you can easily read XM-L 3800 (with some blur).
I’ve thinked that this is an old 3 x XM-L Trustfire rebranded. So that’s the cheap price.
But if it is a real 3 x XM-L2 for 20$ it’s a bargain!!!
Led: Cree or LB ? To good to be true Big Smile
Thank you very much, nice video!
EDIT:
Here is: Trustfire TR 3 x T6
With just 1×18650 it work? Or 2×18650 is minimun? I really like too the shape of a C8 with triple led (and 1×18650 only)
Ah, and if I remember well, if it’s a Trustfire it’s around 1800/2000 lumens (here on BLF you can find more about it like review and so on)
kronological
kronological's picture
Last seen: 2 years 1 month ago
It looks like a pretty decent, budget friendly light for less than $20! Lots of critters in the video too. Ernest T. really took a likin’ to the postum…nice job, robo Smile
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
robo819
robo819's picture
Manx wrote:
Are you sure?
EDIT:
It is a lot like my TF TR-3T6 but there are some minor differences inside with the driver springs, as I say I didn’t have the driver all the way out. It is slightly brighter also then the Trustfire is to the eye. It will only work with 2 or 3 cells.
I am no photographer and not an expert on lattice bright, so here are a couple of pictures of the emiiters in the light.
Manx
Thank you very much Robo Smile
Sad
OrionLight
OrionLight's picture
Last seen: 2 years 9 months ago
Thanks for the review! Looks like it really puts out a ton of light even if it’s not really 3800. Hard to beat for $20.
robo819
robo819's picture
For $20 it is a pretty decent one and yes it puts out a good amount of light to around 200 yards, but it IS a flooder not a thrower.
Manx
[stupid question on]
So this is much better than Trusftire TR, righ?
[stupid question off]
I ask it because 2 years ago I’ve thinked to buy the Trusfire, but never do it.
When I’ve saw your review of Lixada and the photos on TOMTOP site, assembled with 1×18650 too, I’ve said: “wow! Finally it’s time to pull the trigger” 8-)
But then on specifications I’ve read: Battery Configurations: 2 * 18650 3.7V so…. Sad
robo819
robo819's picture
It is a little brighter to the eye than the TF, build quality about the same I would say.
The configuration on the TomTop site shows with the battery tube is misleading , as with the tube in that configuration the 18650 is at least a full inch too short to use the light that way. It will only work with 2 cells (or 3 if you have a second extension tube).
muzzleblast
Thanks for the review, Robo. The Trustfire TR 3T6 is a flashlight I have been considering and this seems basically a cone. But, I think am going to save my pennies, waiting for the Maxtoch 2X. However this triple has a nice broad, floody beam with some distance to it and it looks like a useful flashlight. Your reviews do a good job of demonstrating a flashlight’s capabilities at varying distances. Very helpful.
robo819
robo819's picture
Glad to do the reviews MB. Yes it is a low cost flooder with decent quality and decent output.
WhitedragonBC
Really? Glad I hadn’t ordered one yet then.
Manx
Thank you very much for this important clarification!
So no way to work with just one 18650… Sad
I got to build a triple by myself…
edit:
that’s true Smile
Manx
Maybe with a spacer between the battery and springs?
Or putting 2xCr123 or…I don’t know… 2×18500 are too short.
The Lixada arrived with the tube extension (to work with 3×18650) or only with the 2×18650 tube?
robo819
robo819's picture
Only the 2 cell tube configuration arrived.
The Miller
The Miller's picture
Last seen: 1 month 4 weeks ago
Very nice to see this C8 on steroids Big Smile
But I must say, I really like the fact that there are flooders with cells not in series.
would it work with one cell?
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
The proportions are strange, thickness of tube is odd. Not crazy about the large spring ground connection a la p60 either. I wonder if the short tube is for 2 × 18500.
Scott
kelsey
kelsey's picture
Last seen: 1 week 1 day ago
I like the amount of fins, I wonder if they can be utilized? Did you take it apart to see what the thermal path is like?
robo819
robo819's picture
The short tube only extends, as it will not screw on to the head.
robo819
robo819's picture
The still shots of the teardown are in the video. The pill and reflector are all one piece and it screws into the head with threads under the fins.
DB Custom
DB Custom's picture
Last seen: 5 hours 58 min ago
I found it intriguing enough to order one.
When I am done with it, it will be not so much the flooder and will work with one cell. Wink
Thanks for the head’s up, looking forward to the challenge. Big Smile
robo819
robo819's picture
Cant wait to see what you come up with on this one.
Manx
that’s right!
A big head (like C8 or Warsun Mx900 – always C8 style)
Triple led (ok floody/wall of light)
1×18650 (thinner body)
dual switch (tail cap on/off- side switch for changing mode)
Blf A6 driver
1-2 short tubes for extend the body
Budget (25-29$ shipped)
Let’s start a BLF GB Big Smile
