Err, it won’t? The LED’s temperature doesn’t simply “track” with input current. Think about it - this is just like an electric oven. Reducing the input current may or may not reduce the temperature - it depends on ambient temp, what’s around the oven, and whether you reduced the current from 100% to 80% or maybe 50% to 30%. Somewhere in there exists a “steady state” break point - above that point temperature will rise and below it temperature will fall.
For this application using lookup tables is tricky: they only fully function when they are created with knowledge of the many variables (LED, battery, light mass, external mass, ambient temp). Holding or not holding the flashlight makes a huge difference, but how do we know which lookup table to use (hand vs. no-hand) at any given time?
PID lets us dodge almost everything, I think. You brought up slow/laggy measurements - that may be an issue, I’m not really certain. My immediate take is that whether it’s an issue depends on your goal: I think most of us are ignoring the LED temp and are only interested in maintaining flashlight usability with very high power setups. (someone please let me know if I’m wrong!) In the case of maintaining usability, getting laggy temp measurements isn’t really a big deal - they’ll be reasonably close to “flashlight surface” temps and we should be able to tune the PID settings to achieve the right performance. To re-iterate - for me the “right” performance is a flashlight which I can continue to grip without burning myself, but also a flashlight that will not become scalding hot if I set it down on a table for 60s.
Very slick Tom E, good work. What type of wire are you using for your little hookup wires? The sheathing on the green wire which goes to the LED caught my eye as odd…
Soo, the tiny25/45/85 includes a useful extra feature which I should point out over here. They can measure vcc internally. No pin or voltage divider resistors needed. See my post here: Flashlight Firmware Repository - #790 by Halo
wight - that green wire is really old stuff I had laying around, not sure from where. It's maybe 3-4" with a large amt of the ends stripped - that's why a good amt is bare, it was partially used already. Guess'n it's bout 30 AWG single strand. Think'n it was wire wrap wire? Looks like this wire wrap pre-cut here.
Halo - that sounds interesting! I'm surprised the 1.1v ref would drop same as a direct batt readings, but I don't claim to understand these MCU's for sure.
:-/ Sorry, I didn’t follow that.
Your variable vcc is set as the reference then you measure the stable 1.1v. It’s backwards from how you normally set up measurements
Ahh, ok. Think I kind of/sort of understand. The 1.1v source is always a true 1.1v, but the reference source to read it is Vcc, used as the comparison for measuring 1.1v, so what you read will vary as the Vcc reference source varies. The resolution is less because you are reading 1.1v instead of a true batt+ level, I suppose, so almost 4X less resolution.
I’m actually still a little unclear on how this works Halo. Previously I suppose we were doing “single ended” measurements where we compared the voltage from our hardware voltage divider against a 1.1v bandgap. You’ve proposed measuring the 1.1v bandgap against Vcc (~4v for example).
I think I’m following you now Tom E. Are we thinking that 4v might yield a value of ~281/1023 and 3v might yield a value of ~375/1023? That doesn’t seem like a very large delta, but let’s stretch this out.
That actually looks much better. For our purposes we generally care about something like 4.2v through 2.8v I believe, so we’ve got about 134 measurement points in there. This is approximately double the resolution we normally have since we normally get 8-bit measurements ranging from the low hundreds to the high hundreds (120 through 190 or something like that).
Awesome Halo…. So dump the voltage divider and free up a pin? Sounds great. Would need of to factor for voltage drop if using a reverse polarity protection diode. Guess a voltage divider and pin would still be needed if using 2S or more cells. Especially, if using a voltage regulator chip to power the MCU.
I think this Halo method for measuring voltage would have a big advantage for e-switch lights in parasitic drain. I could be off on this, not sure, but using V = I * R, would the 4.7K and 22K resistors we use result in about a 0.157 mA drain by itself? This was probably discussed somewhere in the past I would think. Can anyone confirm, theoretical or otherwise? I’m measuring about 0.300 mA parasitic drain on a few of my e-switch lights, while a NC MH20 (0.027 mA) and SWM C20C (0.009 mA) are much lower.
For single cell momentary applications if we eliminate both resistors and the polarity protection diode we should have enough space to use a mosfet for polarity protection. This would eliminate almost 100% of the voltage drop we currently see while using a diode for polarity protection.
EDIT: At least with the older boards. The “new stuff” like A17DD-L v30+ is still in flux and already packed super tight, but I’d certainly like to implement a PCB to use this technique for momentary stuff.
I’d like to note that I didn’t come up with it. Heard about it, went looking for an example, then half forgot about.
I heard about it in relation to a different AVR originally. But saw that it’s also available for attiny25/45/85. Not an option with tiny13 though. This was before attiny25/45/85 came into use.
I am trying to imagine what a PID might be. As I understand it, there is a heat sensor either on the driver board or on the LED’s star. If it’s on the driver, then there is a delay and a steady state reduction in temperature from the LED to the driver, and these might be more or less than the delay and the steady reduction from the LED to the flashlight body. There is also heat originating in the FET, but without or with a small gate resistor that is small. So I don’t see how to do much better than regulating the current to keep a constant sensor temperature. One will have to try it to decide on that temperature, but is should be somewhere around the desired flashlight body temperature. It will be cooler when you hold it or the wind blows than not, but not by a huge amount because that will cool the driver through the star and increase the current.
The LED temperature will overshoot because of the delay and have a higher steady temperature than the driver, but maybe it can take that. I don’t see a possibility for doing a lot better than just a simple thermostat.
On the other hand, you do need also to know how much to reduce the current on the first step, so the light output doesn’t vary too much. After that things will change more slowly.
Also, the gain of the thermostat can’t be too high, or with the delay, it will oscillate, turning the light off and on. That is, the table or whatever has to be over some range of temperature.
Hhmm - I should really try measuring the sleep mode amps on a board without the diode or resistors - fairly easy to do… Dunno if anyone did that before.
I did the tests. First removed the diode, bridged the pad with solder, and saw absolutely no difference in the parasitic drain at all - zero, nothing. Still doing in the 0.30 to 0.32 mA range.
Then I pulled the 22K resistor. The light acted kind of weird, because I didn't re-burn the MCU with firmware not supporting LVP. Anyway, it would settle down, and go into its sleep state. There I measured in the 0.16 mA range, which is about exactly what I expected - it went to half the draw, as calculated from the resistor values.
So, not sure why the diode had no effect or did I mis-understand if it was supposed to help?
Btw, in terms of draw over time, a 0.16 mA steady draw would drain a cell 1 Ah in 260 days, if I did the math correct.
The diode is in series with the MCU. Bridging it cannot improve the parasitic drain. If anything that gives a slightly higher voltage to the MCU, which may increase the drain ever so slightly. If there was a diode+drain related discussion it may have been about the zener diode used on 6 V drivers? That arrangement forms a type of shunt regulator, with a huge parasitic drain by definition.
Still a mystery where the other 0.160 mA is going. Your fuse values indicate that you are not using BOD, so that is good.
Maybe some MCU peripherals are not shutting down properly during sleep?
Thanks DEL - yep, that’s what I’m thinking - something else that’s not getting shut down. Spoke last night to my EE buddy here and he said the same thing bout the diode we are using. He also mentioned these diodes will consume voltage though when the MCU is drawing power, so I think I need to know exactly what the draw is. Using the “85” and not the “85v” rated at 2.7v minimum, means you can’t afford to loose much voltage via the diode. Think’n the drain was 0.1-0.2 volts from what I recall, which means our LVP needs to cut off no less than 2.9v. I believe the loss’s caused by the diode is why we moved the voltage divider resistors before the diode, and are using a 22K instead of the 19.1K.
Haven’t had a chance yet, but I need to dive deep into the Atmel 25/45/85 specs to see if we are missing something on sleep mode. I am aware that you have control of several sub-systems for sleep/low power.
Yep, I heard bout the brown-out taking amps in sleep mode - the details were posted here a while back.
You can assume a 0.25 V drop for the Schottky-type diodes we are using (or try to measure it while the MCU is running, it does vary with current and temperature.)
There is a discussion in one of the threads to replace D1 with a ‘boot-strapped’ PMOS FET - this would give practically zero voltage loss.
I don’t think it’s necessary to replace the diode to reduce the draw, it’s just that with an “85”, you have to be extra careful with your LVP cutoff value. The 2.7v is actually 2.95v then, therefore, your cutoff point should be 3.0v or 3.1v for a little cushion. When I bought my ATTiny85’s from Mouser or DigiKey, I bought the 85V’s but the last batch I bought from RMM are the “85”’s.
