Test / Review: (OLD) Panasonic NCR 18650A 3100mAh batteries $11.96 Protected and $9.97 Unprotected (OLD)
I ran a protected 3100mah in the SC600 at 500l for 2h 10min. They were at 3.05v when measured a minute later. Does the SC600 feature a low voltage cut off or were the cells just dropped down below 2.5v under load? Tomorrow I try the same with Redilast 2900mah. This is just for rought capacity comparism. When I charged the 3100mah's they terminated at 3.17v. I have a good feeling about these. I think the 3100mah is fairly acurate. I don't think the Redilast lasted even 2h with this light when I last testet and given the 3100's being new...not bad. Very good package and value for money.
4 hours and 8 minutes @ 1 amp = 4000 mah-Put an Ultrafire Label on it ! Just Kidding.
I still would like a mAh, IR, maxium draw and a LVC test from this seller as any one can print a lable, they should go down to 2.5v going by Panisonic.
except the xtar charge rate slows down as it reaches capacity. I don't know why people doubt these batteries. They are the same as Kallies with a different label. I seems I tore my label off for nothing. It was damn hard to get off too.
from Old's review
Lets look at how the charger behaves : Lets start with the 1A setting
I was using two batteries Bat-1 @ 3.03v and Bat-2 @ 3.4v to start ... Both channels were doing 1A
I was monitoring the charge rate as the batteries charged , and at 3.84v the charge rate had dropped to 800mA
At 3.99v the charge rate was down to 500mA
At 4.07v it was down to 300mA
At 4.12v it was down to 140mA
And the charge terminated @ 4.14v [ tested battery voltage ]
would like to make sure they are the same batteries and the IC's are good.
it seams no one has been able to mention the how many amps the pcb,s (ic's) can take before it cuts in and if the lvc works well and i have not noticed all mAh test on these cells from this seller yet.
i might be fussy but this is a new seller and things likr torches and brands have been copied before, im sure they are fine im very keen to buy a couple but just waiting for more info, i was hoping to buy some tonight.
same stuff diffrent bucket
Possibly a dumb question but - compared to AW: How are Panasonics?
All I admittedly know is CPF: AW, etc.
i had a car sales man once told me the car could do 50 mpg but it did 20 mpg
screw it ill just buy some an test them for myself
Benckie, i think if i insert them fully charged into the DRY, them XM-Ls will pop!
Sanyo 2600s already went way past 5A. BTW actually the Sanyo 2600s are able to get me higher amps than the NCR18650A.
Even SST-90 lights like Elektrolumens ST90 do 4 x 18650 in parallel to draw 2.5A.
The high current incans, well they managed to even pop the green Sony Knion (sp) IMRs. Stuff like the 250W TK Monster.
benckie, I can tell as much as I had been told, which by the way is what the seller said.
I tried yesterday measuring the power consumption from an XM-L, but I think there is a problem with my tester, I had no more than 3A with any battery I checked it, but I had recently 5A from the Hi-Max and 4 from the trustfire flames, but now all of them are giving about 3A, so I think it is my tester's fault, I will check replacing its own batteries.
I will let you know if it imrpoves after replacing the batteries in the tester.
IF in the worst of the cases, it can only handle to give about 3A, it is not that bad for me as I have some Direct drived XM-L flashlights, wich I would not want to toast at 5-6A, the most important thing for me now is their runtime.
Thanks yarvi.
Today I brought a couple protected ones to try out.
Protected arrived today.
These are really long/fat batteries.
They don't work in my TM11 and don't fit in the DRY battery carrier.
Almost the same lengt as the Xtar 18700 / 2600 mAh
The website has been down for a while for me any one else ?
Has any one done any test of these from this seller yet ?
I ordered a pair of protected 3100 on the 16th of november it will be a week or two before i get them.
got mine today, pcb trips on my 5.6 amp dropins but not on my 4.2 amp
Welcome to the forum, bugsy714. I hope you will participate more in our discussions around here.
Are you sure you DMM is measuring accurately. 5.6A is a high current, the higher it is the harder to correctly measure it because the leads length, thickness and resistance. It is possible that the currents to be higher than 5.6A.
Even with with stacked AMC7135 chips the current can differ . For example they are rated 350mA per chip, but if you look at the manufacturer specs you can see they are rated 340mA to 380mA.
No DMM, just my 5.6 amp regulated kenji quad in a c2 with a mcclicky (the mcclicky should provide some resistance as well). It does the same in my VIDSM copper quad 5.6amp uunit with a fettie switch
When I put them in my 6p/mcclicky 4.2amp regulated VIDSM light they run fine. I'll be taking a walk and timing how long these can run my quad on high, an AW IMR 18650 is about 25minutes @5.6amps so I'll be hoping for a lot more runtime at 4.2amps =)
Hank has told me he will release their official test reports of these batteries soon!...
the runtime is noticeably longer than my trustfire flames
I also just purchased 3 of these batteries, and will compare with Callies Kustoms when I get them. Sounds like a real good deal for these cells.
ordered 3 unprotected and they are shipped, will post when I have news (facts)
