The S70 dimension and the L2 dimension are measured with a simple ruler thus not 100% accurate (but still within 1mm :laughing:
That is indeed good news.
Will Simon make a smooth reflector, so we can choose between smooth and orange peel, for the host? That way we have a wide variety of options! I mean this L6 might look similar than the L2 but its still a different beast!
I’m not holding you to 100% accuracy buddy. I appreciate the approximated comparison you did.
He did say he would make both smooth reflectors for the L6 and OP for the L2 but not until after the first run of the L6. So it may be a little while but in the end we should have both reflector options for both of these big lights.
+1,0000,000,000,000
You just have to. It’s not optional. But as DB mentioned, it will be running at a lower spec so they probably will toss the 70 on the outdated and obsolete heat insulating star. :SICK: :SICK:
That and if they decide on using an OP reflector to correct the cross? I’ll pass. I hate OP reflectors on anything. IMO. I have seen partial OP designs, so that might, might be a possibility…
That’s the thing with aluminium star, I’ve been annoyed too to see them being used in a good quality light but I’ve come to appreciate the fact that if they do what they’re designed for in the stock light then that’s fine, most buyer’s won’t even know what one is.
I have the XHP70 in my L2 with the standard smooth refector and I cannot see a cross, I don’t know if that’s because I haven’t adjusted the height of the emitter with respect to the reflector to optimise it.
Well that’s not going to happen because then I’d have to change my thread title to “Convoy L6 …XHP70 or XHP50 or XHP50 triple Beast!” and that’s just confusing not to mention a bit wordy.
Honestly though there is no plan to make the complete light in anything but the XHP70 at this time… however, this light will be available as a host so the sky is the limit.
Unless you’re looking for Copper for heat sinks, not gonna find much of that in the sky. Just sayin. And finding triple optics may only be slightly easier than creating your own from scratch depending on final interior head size. I’ll probably be finding all that out on my own, but still…
Triple emitter flashlights at mega power are a nightmare for a manufacturer. Litigation and all that. Interesting though, the concept of manufacturing bursting the safety bubble. It could happen… (not holding my breath or giving away the lathe just yet)
