AstroLux A01 AAA Nichia 219B Review - Winner winner, chicken dinner. An excellent, Neutral tint High CRI LED keychain light!
267 posts / 0 new
Zeet
Zeet's picture
Ahhh. Now I understand. I thought there was something like that going on when someone seemed gleeful when referred to a tutorial on how to “reflow an LED”.
So if I get one of these little beauties, can I count on you all to help me get it to work right?
brted
brted's picture
Last seen: 1 month 4 days ago
Zeet wrote:
Ahhh. Now I understand. I thought there was something like that going on when someone seemed gleeful when referred to a tutorial on how to “reflow an LED”. So if I get one of these little beauties, can I count on you all to help me get it to work right?
People live for that. They run out of lights to fix, so the next best thing is helping other people fix lights.
ReManG
Andyman,
Sounds like a bad driver to me if that did not fix it…
Any light can have quality issues, this one too, so I hope these get fixed, it is a nice little light…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
WalkIntoTheLight
Last seen: 1 month 1 day ago
Zeet wrote:
Is it just me, or is this just poor quality control? I know the price is great, but this seems like sloppy workmanship. When I carry a light, I like to feel confident it will work when I need it.
Well, I haven’t got mine yet (it’s in the mail), but I don’t expect high quality on a sub $10 light. I do expect it to work, but if it has a few glitches occasionally that’s what I expect from a cheap light. I would certainly never use a cheap light like this as a primary light where I really needed it (like a nighttime walk in the woods or something like that). So I’ll use mine around the house, or carry it when I don’t really think I’ll need a light (but where a light might come in handy).
ReManG
It is a cheap light for the features, but not being able to use it when you want to, or if it is your back up light, kind of negates the reason for it..
I don’t know how many have been sold, but so far one scratched emitter and two possible bad drivers are not that bad, especially if Banggood makes good on them…
My Reviews
WalkIntoTheLight
ReManG wrote:
It is a cheap light for the features, but not being able to use it when you want to, or if it is your back up light, kind of negates the reason for it…
To turn a cheap light into a reliable expensive light, just carry two of them. One of them is bound to work when you need it, and it will still cost much less than a reliable expensive light.
ReManG
I like the way you think!
My Reviews
altblf
Last seen: 1 week 6 days ago
Could this use 10440 li-ons?
Hobo
Last seen: 47 min 56 sec ago
It can and it’s brighter with 10440, but gets hot quickly. 10440s are not supported officially, so I can not tell whether it will damage the light in long term or not. I will use it with AAAs.
8) Lube Threads Everyday 8)
ReManG
It does not officially support 10440’s, I have tried the 3.2V LiFePO4, and it worked for a couple of minutes during testing…
It is so nice on AAA/eneloop, I see no need for 10440’s in this light… Just my opinion, if anyone runs 3.7V for a long time, report it here for this that want this knowledge…
My Reviews
jerm03
Last seen: 2 weeks 6 days ago
I purchased two. I was unable to get one to work until I removed the spring and cleaned the inside of the barrel. That would not be too bad, but every time I change the battery I have to remove the spring and reinstall it for the light to work. The price on Banggood is $11.95. I recently purchased two Tank 007 e09 lights with the FT discount for a total of $22.54. My experience with the two lights persuades me that the Tank is much better so I do not think the Astrolux is a particularly good buy.
Jerry
ReManG
Jerry
Pull the tail spring, wrap some fine sandpaper around a pencil or dowel and polish the end of the tube with it where the spring goes.
There was some anodizing over spray in the purple one I had. This should fix your issue with that one. I cannot think why else removing and replacing a spring would be needed, except for bad contact surface where the spring is…
Just the comparison with the Tank 007 E09 makes this a not so good light? I do not think you can get a high CRI version of the Tank without moddding it yourself… The Nichia 219B V1 is $4 by itself… So you would have to add $8 to your total and mod it yourself to make the Tanks High CRI
I agree the Tanks are good lights, but they do not make this one a bad purchase either… For what I want, these are my current favorite….
My Reviews
1dash1
1dash1's picture
Last seen: 10 months 3 weeks ago
Andyman wrote:
ReMan and ImA, I finally got around to playing with this a little more. Shaved the donut (reduced thickness by about half), and while I didn’t think this was possible, it got even weirder. Now it’s a 1-mode light! Really – it doesn’t cycle through modes any more. It actually turns on a little more easily, and at least it’s consistent – the twisty does feel more “normal” and less finicky. But where did the modes go? It still turns off when I tighten the head all the way, but I have to tighten pretty hard for this to happen now – it doesn’t turn off with a normal finger-pressure tightening, only when I grip it harder and actually try. Overall I have to say it’s improved, but I was hoping for a light with modes… Is there someone here who represents BangGood that I can PM to hopefully get a replacement? Or would I be better off emailing their general CS contact? Thanks! Andy
For my two Astrolux’s, I encountered two different problems that affected the UI.
First, overspray of the anodized finish onto the threaded end of the barrel. Easily taken care of by filing/sanding the edge.
http://budgetlightforum.com/comment/887091#comment-887091
Second, gunk or sludge-like residue on the flashlight head (positive node) plate that prevents the flashlight barrel from making a good, clean contact. You need to clean the plate off.
http://budgetlightforum.com/comment/887813#comment-887813
Once these problems were taken care of, the UI worked smoothly and reliably.
Rule 1-1 as it applies to life, take it as it comes.
Lick
Lick's picture
Last seen: 2 weeks 4 days ago
I had a problem with it not turning on. I somehow fixed it by messing around with the head (moving the pill clockwise a little bit). The head had problems, and it still does, the foam is not stiff enough, so as soon as I put on the head, it turns on. It was finicky and too loose with turning on. I put on another retaining ring, and it didn’t help. I eventually have it mostly working by pressing on the spring a few times so it would not press it so hard to the foam.
It works but feels very loose.
ReManG
Try wrapping the threads in the teflon plumbing tape. A couple of wraps have tightened up my threads on another light and make it easier to keep from coming on accidentally. Neither of my A01’s heads are loose enough, but we all know that threading can vary…
My Reviews
Evgeniy
Last seen: 1 day 13 hours ago
ReManG, you contact with seller and manufacturer.
Can Astrolux create 1x AA flashlight with same LED, driver, but with button and slighlty bigger (AA size) heatsink in head (as in 1xAA Zebralight’s), for cooler work in 100lm mode ?
Flashlights : custom (Jaxman E2L with led4power LD-4 drivers and 3xOsram CQAR.CC), custom Skillhunt H03 with Osram 3К/4К, Zebralight {H600fc IV, Sc600fc IV, H600fc III}, Jaxman E2(N219b), Convoy UV.
Previous: Zebralight {H501, H600W, H600W II, H602W}, NiteCore TIPCRI, A A01, Fenix L2D CE/CEQ5.
bikenber73
bikenber73's picture
Last seen: 16 hours 20 min ago
My second one arrived yesterday and the head wont screw all the way past the o ring . It works but mot waterproof at all. Its liker the threaded part of the body is too long or the pill isn’t screwed in far enough I cant get it to move any further in to the head. Anyone else had this problem?
Thanks
vitriolix.com
Last seen: 2 years 5 months ago
I’m interested in a nice orange
T18
I have definitely fallen behind ReMan, You always have the best reviews, AND the GB I also just found for the Cu’s
I had wished these would come out in Cu and you have it done, fantastic, these little lights are great and really were a surprise when I got it back around Jan, from packaging on great light..
hank
hank's picture
Last seen: 5 hours 57 min ago
One caution — be wary of these coming on accidentally at the bottom of a pocket or purse.
My orange had the flicker problems mentioned earlier; I worked most of that out with disassembly and cleaning up, and now I just get a bright flash before the moon level, but not the jumping around and skipping.
But it’s twice now come on deep in a pocket. I have to turn the head WELL past the “off” position to avoid this happening.
The threads are wobbly enough, apparently, that a little pressure sideways on the light can cause it to bump on and bright.
Then it gets really hot fast if it’s down in some insulating material.
I’m putting a fat O-ring on the light that I can slip into the groove behind the head when the light is off, as a safety.
Could just be a mismatch between head and body if the threads are plus-or-minus the desired spec and I got the smallest body/largest head threads.
Anyone else noticed this?
ReManG
I had not noticed the coming on of the light, but I can see it happening.. I put a few wraps of plumbers Teflon tape on the threads on all my twisty lights to tighten them up… Give that a shot as well… I like the oring idea though…
My Reviews
WalkIntoTheLight
I finally received the first of these lights I ordered, a green one. Nice!
I notice that mine has no foam ring over the driver on the + end of the light. I thought I read somewhere that these lights are supposed to have one, for reverse polarity protection. Is this a concern, or can I just ignore it as long as I’m careful to always insert the battery the correct way? The light seems to work fine, all modes are easily activated, so the lack of a foam pad doesn’t seem to affect the operation.
ReManG
I would send a pic to Banggood and see what they say… They may have put in protection (diode) but see what they say…
If the battery is in right no issues, but the one time you pop one in backwards… That stinks when it happens…
My Reviews
brted
brted's picture
Mine didn’t have the foam ring either.
WalkIntoTheLight
Okay, well, it sounds like mine is not unique in missing the foam ring. I’m always careful with batteries, so it shouldn’t be a problem. I might ask Banggood, but I doubt their customer service would know how the lights are designed, so probably not much chance of getting a proper answer.
Anyone else with a recent color of light (green, orange), missing a foam ring? Anyone actually have one in a recent run of the lights? I’m wondering if it’s supposed to be without a ring, or if there’s a quality control issue.
When I get the rest of my order, I’ll see what they have.
In any case, I love the tint of the light. A nice somewhat-warm clean beam, free of any of the ugly green that Cree is so famous for.
hank
hank's picture
Not on mine. WAs it supposed to have one?
And, DO these have reverse polarity protection?
ReManG
I will ask Neal about this issue as well. Once I get an answer I will post it here…. This seems like either something forgotten (foam ring) or something changed (reverse polarity protection) ether way w we need to find out…
My Reviews
WolfA
WolfA's picture
Last seen: 10 months 1 week ago
I got my A01 today and played around a little. Soon I noticed heavy flickering issues when changing modes. ANNOYING! After a close look I noticed that the inner edge of the body tube was ever so slightly elevated and felt sharp! If this little burr made a wobbly “ground” contact first it would maybe explain the uncertain switch behavior…
So I cautiously deburred the body tube inner opening with a countersink. Voila: The flickering is gone and mode changes work perfectly fine!!
At least for the moment Smile
"A black bulb which, when switched on, turns the room dark"
(Gyro Gearloose)
hank
hank's picture
Got my 2nd orange A01 in the mail today.
Awful flickers, not just a little bit, quite unusable — with a couple of minutes of use with a NiMH cell
I’ll try the usual everything. It will probably get better.
ReManG
Arrrrrrr…. This stinks Hank. One member had a burr on the tube, chamfered it away and it worked well it seems…
Sorry to hear this Hank…
Let us know what the resolution is from Banggood..
My Reviews
