Hello!
We’d like to present our new project who got quite a lot of money for producing on the Kickstarter!
It’s called the Repulsor flashlight and it’s created for people who want to have only the best gear of the highest quality!
Repulsor project is a new generation light system with genuinely unique technological features.
The total luminous flux of Repulsor is 7911 lumens (according to the world standard ANSI/NEMA FL-1). That’s more powerful than any other serially manufactured flashlight of the corresponding size. Each flashlight’s lens has the beam angle of more than 60 degrees so Repulsor will perfectly illuminate the space ahead of you, leaving practically no dark corners.
You can point the flashlight lenses in any direction. You can direct one light beam forward and another one backward.
Unlike most flashlights you have to hold in your hands, Repulsor is fixed at the back of your trousers’ or jeans’ belt with the reliable fixing device. Such design is very comfortable as it leaves your hands absolutely free. All this is possible due to the “Hands-free” technology where the flashlight is not a mono-block but is divided into three elements connected using flexible fasteners.
Repulsor is suitable to be used all year around. All you need is a belt to have your Repulsor securely attached.
The flashlight is specially constructed to have a perfect weight distribution. Despite its weight of 2.8lb, you won’t feel it on your body. The light temperature allows you to use it both in bright and dull weather.
Repulsor is a real monster of light. It’s perfect for search operations in low visibility conditions.
We managed to achieve the non-stop 90/115 minutes work due to the integral battery with advanced discharge rate. That’s a wonderful result for flashlights of this type.
The flashlight’s body is made of high quality anodized aluminum which provides great protection from scratches and minor damage.
Repulsor will perfectly suit rescue services and force authorities. Due to its robust aluminum body frame and its powerful hardware, Repulsor is the best choice for situations where other flashlights are useless.
Due to the built-in USB-port and the powerful battery of 8000/12000mAh, you can always charge your smartphone, tablet or camera in places where there is no access to any power source.
Here’s our project on the Kickstarter :
https://www.kickstarter.com/projects/1484247498/repulsor-your-ultra-powerful-wearable-flashlight?ref=nav_search
Please, ask any questions! We’ll be happy to answer them all!
s. yes, that’s us again! sorry for having posted our topic in the wrong category before! hope, this time it’s right
