Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Thanks for getting the BLF Q8 flashlight!
This light is a cooperation between flashlight lovers gathered on the website budgetlightforum.com and quality manufacturer Thorfire.
For more information see: bit.ly/blfq8
For a manual for how to use and configure the software on the flashlight see: bit.ly/narsilinfo
Before using this flashlight please take the time to read about how to safely treat the batteries/cells for the flashlight here: bit.ly/lionsafety (Information in several languages)
The BLF Q8 is a very powerful flashlight that requires some knowledge before and during use.
The Q8 is intended to be used with button top cells.
The use of protected cells is highly recommended.
Please make sure to install the cells correct, the button in the direction of the head/LEDs.
The Q8 is a very bright flashlight, do not point the beam at others.
Never leave the flashlight ON unattended.
The Q8 is not a toy, do not let children play with it.
Hold it when in use to monitor the temperatures and turn the light off or switch to a lower mode when it starts to become really warm.
Turn the Q8 off and let it cool if it gets hot.
Use the lock-out sequence to deactivate the switch before putting the Q8 in a pocket or bag.
When you want to store the light for a longer period of time, make sure it is clean and dry and in case you want to keep cells in it, lock the current by unscrewing the battery tube a bit (turn the light on, unscrew until it goes off).
It is advised to clean the outer parts of the light periodically.
Every couple of months check the threads, adding a bit of grease to the threads if needed.
When you encounter a problem please share it in the above linked BLF Q8 thread.
The Q8 is developed with flashlight modders in mind.
If you want to modify the flashlight, make sure you know what you are doing and/or start a thread on budgetlightforum.com on your planned mod, the friendly and experienced community will surely help you with solid advice.
And above all, enjoy this beast of a light!
Initializer of the project declares that,
the BLF Q8 flashlight,
manufactured by Thorfire,
2nd Floor West, Building A, Yi Li Technology Park, DaHe Industrial Zone, Guanlan Town, Longhua New District, Shenzhen, Guangdong Province, China. 518000,
conforms to EU legislation,
and so do the manufacturing and quality control practices for it
Thanks very much jack-bkk for translations!
Commercial text:
BLF Q8 是一款由来自世界各地的手电筒爱好者设计开发的手电筒,进入网站BudgetLightForum.com查看更多多功能手电筒。
这款手电筒可通过 1-4个18650 锂离子电池供电,通过易使用的电子侧键开关控制电源。
4盏高性能Cree XPL LED灯安装在铜板上,以保证最大亮度和安全性。
Q8定制的电路版能让电灯以低于1流明的荧火虫模式到4000以上流明的高亮度运行。
极高的频率保证了脉冲宽度调制的无声或可视操作。
这款手电筒的设计特点满足了许多不同场合的需求。
摄影师,露营者,渔夫,自行车运动员,急救工作者,可将Q8手电筒固定在三脚架上使用,无需手持电筒。
BLF Q8 一款经典的罐头设计手电筒,重新制定了更多功能,更强大,更有效率的设计。
高质量的设计制作注入4000流明的大电量 ,操作简单。
这款手电筒的亮度射程范围,可达到至少150米远的大范围区域。
Cree的XPL V6 3D中性白光LED以其质量及耐用性而闻名。
这些特点带来了吸引人的色彩。
其定制的DTP铜板为其提供了最佳的散热性能。
BLF Q8可使用多达4个18650电池。
使用一个电池时可使用低输出功率的高率频式来调节,
每增加一个电池,可使用的时间会更长;增加两个或以上电池,使用最大亮度模式时,这时可充分使用其功能。
可通过侧键开关来操作。
这个软件非常容易操作,每位用户可以选择设定如何操作 BLF Q8.
从几乎看不见的亮度到弱光,月光/荧火虫光到明亮
手电筒有多少个可控模式(从高到低或从低到高)
推滑式控制开关(在150种亮度的范围内通过按住按扭自由滑动调节),而非模式选择按键。
松开按扭之后,亮度会保持在所需位置。
5种频闪和灯塔闪烁模式去读取电池的工作电压
手电筒的设计特点防止不使用时电池的自动耗电。
锁住开关,可防止意外开灯。
低电池电压下降防止电池烧坏。
用户可设置涡轮延时器(延时熄灯)降低电压来防止过热问题。
长按开关按键20秒开关会自动锁住并关闭电灯,以确保放在包里或口袋时不会长期亮着。
开关对面的1/4通用镙丝可用于把Q8手电筒安装在三脚架上固定起来,无需手持电筒操作。
BLF Q8 易操作,小体积便携带,可用三脚架安装固定,是一款理想的手电筒。
在大空间以及小空间的地方工作时,
如,用在剧院,摄影以及电影灯光
露营时
钓鱼或进行户外活动时
停电时足够点亮最大的房间
一款高质量的BLF Q8,值得拥有!
颜色:黑色
手电筒型号:推滑式或12种模式组合供选择
镜片 玻璃:镜片
反射器:SMO
开关形式:电子侧键开关
尾架:有
光源品牌:Cree
光源型号:XPL V6 3D
流明(最小)<1流明
流明(最大)4000 流明
是否含电池:否
电池规格:18650
电池数量:1-4个
Specs:
这是规格
要转换的中国:
…………规格………………注意事项
BLF Q8
…………标记/标志“BLF Q8”的团购,制造商可以选择事后自己打标/标志
价钱
………… $ 40 …包括运费…。制造商可以事后决定自行定价
发射器
………… 4个…。 3535足迹
…………克里XPL NW ……。是的,现在它决定非HI XPL
…………安装在DTP星LED灯
内幕
…………集成LED架…。良好的散热至少4mm厚
………… 20 AWG电线…………
…………驱动挡圈
…………双重弹簧具有较小磷青铜弹簧
…………线程电池筒方形或梯形板(未三角形)
…………阳极氧化线程部分电池筒的螺丝拧入头锁出
…………尾盖 / 尾罩 可以拧访问连接的PCB – 细胞侧
…………线程尾盖方形或梯形板(未三角形)
…………线程挡板可以是任何制造商选择
…………电子侧开关
…………安装三脚架
………………… …安装螺母孔未钻孔虽然整个身体,以确保防水放置按钮的对面
光学
…………铝反射器……。相同尺寸的顶部作为旧SRK反射
…………玻璃镜片……………。 2mm厚
保护的
………… O形圈表圈………。因此,质量和厚厚的完美契合
………… O型圈电池筒…质量从而厚,完美契合
………… O型环尾盖……。因此,质量和厚厚的完美契合
………… 铝 合金…… … 6061-T6
………… II型阳极氧化…不是HA3的团购
…………防水侧开关
…………不锈钢表圈
…………轻型带有用于所有大小备用O型圈
软件
………… tom电子纳西尔圣剑固件
…………几种模式和闪烁模式
…………用户可配置
…………固定模式和斜坡
…………电压检查
…………低压切断
…………锁定
驱动程序设计
…………汤姆E代表纳西尔圣剑固件的电子开关驱动器
…………非常低寄生漏
…………能跑1,2,3和/或4键顶部18650电池(S)
……。 MCU …。爱特梅尔ATTINY85V-10SH或ATTINY85-20SU包是很重要的:8S2
……。 FET …。马努:日前,Vishay Siliconix公司,马努PN:SIR800DP-T1-GE3,Digikey PN:SIR800DP-T1-GE3CT-ND
……………………外形:PPAK SO-8
……。电阻… … 0805 SMD 47K OHM 1%1 / 8W
……。电阻… … 0805 SMD 220K OHM 1%1 / 8W
……。二极管…… …肖特基,10V 570千安SOD323马努PN:ZLLS410TA,Digi-Key询问PN:ZLLS410CT-ND
……。电容…。 0805陶瓷,12uF 16V X7R
……………………………… …如果可能的12 uF的或更高,而不是10 uF的 – 可能需要
……。 7135芯片…。 7135用于低模式350毫安7135安培稳压器
质量
……………。样品100%同意并出售之前延续指定
……………。最终生产灯100%同意,规定和样品
……………。跌落试验装运包装的视频可供出售前灯提供。
…………………。该视频显示在包装的光的至少10滴从至少1米多高
…………………。落在不同的角度,在8个顶点,底部和侧第一击中地面
……………装运前进行测试,以发现并解决问题,避免 产品无法正常工作(无法启动电源)。所有灯。
驱动程序设计说明
… …The 47K和220K电阻分压器,其中所述220K为R1,所述47K为R2
… …The 12K电阻是FET栅极电阻(从单片机的I / O引脚跟踪到FTE门,
……连接到地。)
… …Diode是反极性保护
… …The SIR800DP FET是昂贵的,但可以轻松处理高安培我们得到驱动4个并联LED的
……。从4并联电池,没有任何退化或热量。它是它的大小不平凡的表演FET
The commercial text in English, yeah it was way out of our comfort zone to write it, but we needed something to explain our ideas to China manufacturer :wink: )
BLF Q8
This flashlight is completely designed and developed by flashlight enthusiasts from around the world, gathered on the website BudgetLightForum.com
The result is a highly versatile flashlight.
It can be powered by one to four 18650 Lithium Ion batteries and is controlled by an easy to use electronic side switch.
The four high performance neutral white Cree XPL LEDs are mounted on a copper plate for maximum light output and reliability.
The custom built circuit board for the Q8 allows the light to operate from below 1 lumen firefly mode to a massive 4000+ lumens.
Very high frequency insures no audible or visible PWM.
The features in this one flashlight makes it suitable for a lot of situations a flashlight is needed for.
Photographers, campers, fisherman, cyclist and emergency workers can fit the Q8 to a tripod for hands free use.
BLF Q8
A classic soda/soup can flashlight design, re-engineered with more functionality, power and efficiency.
4000 lumen of flood and decent throw in a high quality, easy to use flashlight.
This flashlight lights up a large area to at least 150 meters away.
Cree XPL V6 3D Neutral White LEDs are known for their quality and durability. These offer a pleasant tint.
The custom DTP copper plate provides the best possible heat dissipation.
The BLF Q8 uses up to four 18650 batteries.
It works with just one battery with reduced output on the higher modes and with every battery added it can work longer and with two or more batteries used the brightest modes are fully functional.
It is operated with a side switch.
The software makes it very easy to use.
Every user can choose to configure how the BLF Q8 works:
moon/firefly, brightness from barely visible to very low
how many modes the light has
the order of the modes (from hi to low or low to high)
ramping instead of modes (smooth gliding between 150 brightness levels with a click and hold. The light stays in the desired brightness level when the switch is released.)
5 strobe and beacon blinking modes yes or no
to read out voltage of the batteries
The light is safe with features to prevent parasitic drain to avoid depleting the battery when not in use.
lock out of the switch, this prevents accidental turning the light on.
low battery voltage step down and cut off to prevent battery damage.
User configured Turbo timer step down to avoid heat issues.
When the switch is not locked out by user and is pressed for 20 seconds it will automatically lock out and turn the light off, to make sure it will not go on when put in a bag or pocket.
Opposite of the switch a 1/4” UNC thread can be used for mounting the Q8 to a tripod and hands free operation.
With its ease of operation, relative compact size and tripod mount the BLF Q8 is an ideal light to use:
During work in large and small spaces
As theater, photo and movie lighting
On the camping
When fishing or during other outdoor activities
To light up even the biggest rooms during power outage
BLF Q8, a high quality must have!
Color Black
Flashlight Modes Ramping or 12 mode groups to choose from
Lens Glass Lens
Reflector SMO
Switch Type electronic side switch
Tail Stand Yes
Light Source Brand Cree
Light Source Model XPL V6 3D
Lumens (Min) <1 lumen
Lumens (Max) 4000 Lumens
Batteries Included No
Battery Form Factor 18650
Required Battery Count 1 up to 4
Nice initiative! But if the idea is going to be a new design by a manufacturer, I see a thousand good reasons to have a good conversation with kronological about it, to avoid the many pitfalls.
I like the idea of Thorfire making it more than a deal with Fasttech. I think I remember that attempts of group buys with discount never worked with Fasttech.
If it is designed from scratch, a version can be made with a 4mm shelf that is continuous with the body, and separate ledboards screwed on top of it, that would be very versatile, and good for the heat path! The driver could simply be the Kronos X5/X6 driver expanded to the SRK-size board. A (elegant) handle would be a great extra!
Depending on how it turns out, I’m in
Nice idea.
Wouldn’t it better with a copper shelf instead of brass?
PM send to Toykeeper
PM send to Thorfire
And yes agree let’s make the shelf an integral part of the housing and 4mm thick
How about the famous PD68 tailcap?
The Supfire M6 and Roche M170 both have an integrated shelf, the former being around the same price as you propose.
Yeah I’m in
Great idea, always wanted a good SRK. However I would go with an electronic switch version and forget the lighted tailcap.
I’m interested. I’m short on funds, so can’t commit to anything yet, but I like it. One thing I’d like to suggest, though. I know a lot of people like tail clicky for lockout, but I’d rather see lockout through the UI with the side e-switch. It works well on the Olight S20-L2, IMHO. And it will cut down on the major design changes that need to be done to the light.
yes, hence the reason for aiming at that pricepoint. if they can do it so can we :wink:
An integrated shelf is also a nice cost reductor compared to copper or brass screwins.
And as far as group buys, yes it is my first, however I do have some experience with dealing with Azian companies.
This is my idea and basic design,
Asus was not keen om making it, but I was sure this would be a great idea.
Hi The Miller,
If you keep the interest list in the second post, every single update of the list will generate update-mails to thread-subsribers and the updated-button in the recent posts page will direct to that 2nd post every time, instead of the really new posts.
Updates to the OP will not do that, so it is better to keep the list there.
cool, thanks!
Zou je in het team voor dit project willen? (MAW wat meer PMs ontvangen dan normaal)
Well the Supfire M6 for 40 USD is just the basic version, if you want the “pimped version” with higher output (4000 lumens) and better FW you must add another 50 USD!
I would not recommend to go for a lighted tailcap, but It would be great to have a choice of LED type (Nichia for the photographers and those who want the natural colors or Cree´s for maximum output)
Anyway i´m interested! I was tempted many times to get me such a can but resisted because I din´t want the cheap latticebright LEDs….
K.
I’m interested :wink:
Yes the tail switch is ditched for lock out via the side switch, cheaper to make, less parts so no brainer.
Will update OP now
Interesting…but with all the extras you have in mind I guess it will never become reality.
the only two main differences wth the original SRK are the integrated shelf and cell status via side witch.
We are basically asing Thorfire to make a new light, based on proven design, proven pularity, known sale of first batch. They can up the price for their own branded ones and have the best SRK available, we would recommend that instead of the Supfire.
I think whoever i going to build this light is offered a great deal but I would love to see a Happy box SRK arrive :wink:
=prima, ik denk dat ik qua design wel wat kan bijdragen :slight_smile:
chance of low voltage cut off?
One more idea from the peanut gallery. Probably not for this group buy, but maybe in the future. A “mini” SRK with 4P 14500 and 4x XPL HI V3 emitters! Integrated shelf should dissipate heat well enough. Smaller reflector size would ensure less throw, but who ever bought SRK for throw anyway? Sizing it down to 4x 14500 would make it pocketable, and with the 4x XPL HI V3 emitters, it would still be awesomely bright! A lot of the longer standing members already have SRK-size SRK’s (LOL), but the smaller size would make it unique, and possibly more would be on board for one. Then again, maybe I’m the only one. :stuck_out_tongue:
One note about the size: the ratio of diameter/length of a 14500 is almost exactly the same as 18650, so the entire body design of the SRK could just be scaled down a bit and still look and function the same. Nothing new to design, really. Upgrade the driver and LEDs of course, just like we’re talking about here.
Hahaha oh yeah a cute little baby SRK
I hope we are getting a nice thing going here and can indeed follow that up with a smaller version.
How a about a name for this current BLF Premium Soupcan?
