Very much interested !
Interested.
Always wanted a srk sized light.
Interested, in both this version and the baby one. I really like the above described UI. While I like TK’s UI on the A6 and X6/X5, it can be a challenge to quickly describe it to someone when they are using the light momentarily. “Click on, click off, click and hold to ramp it up or down.” is pretty obvious. Without actually showing a noob, “short half press” and “long half press” don’t really mean anything to them.
I am in for several of those depends of stats/price ofc, i would like to see some high binned HML/XPL emitters plus a ramping driver inside, or at least programmable
I love my SupFire M6 with XM-L2 U3 2A’s, Narsil firmware with UI configurable modes from 1 to 8, and UI configurable moon mode level, plus a locator LED next to the switch that can blink out the voltage level as well, nice lockout feature, and latest updates: easy ON/OFF of the locator LED to reduce parasitic drain down to 0.016 mA (10+ years to drain one cell). Goes from 0.1 lumens to 5000 lumens.
Biggest gripe I have on the M6 is the weight, but it helps in cooling, but it’s not the most efficient design for cooling - doesn’t use the mass effectively. Having four 219C’s, it may have potential high amp issues on a FET driver, but depends on some overall component choices.
$40 and 500 pieces is an optimistic goal for what you have listed, though I think there would be a big demand for a quality SRK 4-5 LED light. Having worked on SRKs with 3’s and 5’s, I think I would prefer 5 to 4, with one being centered. If you go with copper MCPCB, much, much better to have one single custom made copper DTP MCPCB to mount all 4-5 LED’s on, but again, probably very costly to do. 4 or 5 individual MCPCB’s is doable, probably costly though for parts and assembly.
For 3 LED SupFire M6’s, you can fit 20 mm MCPCB’s. For 5 LED’s, I’ve fit 16 mm’s but had to trim them down. Not sure of 20’s would fit for 4, but 16’s should with no trimming.
I have too many SRKs now. Let’s do a 3x 14500 with single XHP50
Or do an M6 with 3 XHP50s
Also don’t forget about the Darth and Padme. I would buy something with that styling.
Okay, great idea! Go ahead and start the Group Buy thread for us!
Its never enough m8, just before several months i had 5 modded ones plus 2 M6s - M6 weight could be an issue though, its even heavier than TN36( 445gr vs 388) …yet it still fits in most of my pockets
Anyway it would be a great to have a BLF multiemitter torch
Forgot - please put me down for 2 pieces!
I’m very much interested to see how this comes out. Just fyi… The M6 is a great price at $40, but if you can get that plus an AR lens, 219C’s, copper MCPCB’s, and an advanced driver with the quality of an M6 host (SS bezel, shelf, etc.), it would be a great deal for sure.
Interested.
Preferable the normal SRK size with 4 LED , choice of tints , 1 to 4 18650 batteries capable and moonlight mode.
As for the UI , parts used and heatsinking , will leave it to experts here with confident.
End of the day, price the deciding factor.
I’m interested as well. This would be my first SRK.
I am interested.
Sounds amazing, I’m in for sure.
I would be in for this one…
Please put me on the list for 1 unit.
Do Want.
Put me down for one
It will be a light like the old SRK
1, 4 cells, only way to make it lighter is using 1 2 or 3 cells.
2, The same easy to remove plate on the bottom so modding it to run 2p2s can be done as with the current versions.
3, 1 button (ideally with a cell status lighting - green orange red- but maybe the budget won’t allow it and it will become 3 blinks on low battery and shutoff idk, we are early in the proces)
4, 4 LEDs
We have to choose for 1 system to operate it, either a driver with regular modes (the Bistro comes up) or ramping.
I prefer ramping the way djozz describes since it has infinite brightness levels so it should fit everybody’s needs.
Yes when we are further down the road it is a good idea to see if the host version can be made available, for now I focus on a old fashioned good quality SRK.
We could check for a Cree in warmer tint if that is what a lot of people want. I thought writing this the 219C is about the nicest LED because its high CRI and still being very bright.
We could go for a few choices if that is possible, again, idk now and I do not know how more choices will change te cost of making and distribution, 1 led seems easier and well ordering 400 x 4 (1600) LEDs should push the price for individual LEDs down more then 400 x led A, 800 x led B and 400 x led C.
So there you have my point of view, please discuss and add any 2 or more lumen yourself!
The baby 14500/AA variation is a nice follow-up IMHO to become a nice set later.
So let’s forget about that little cutey now shall we
So much for my idea. I am going to build an improved srk with a deeper larger head for larger reflectors (76mm head with a compound reflector made from 4x C8 reflectors), deeper cooling fins, removable handle, and tailcap battery replacement to reduce wear to batteries and contact ring among other improvements and when complete I was going to post to determine if there was enough interest to have it produced. One thing I would definitely like to see is better threads. That alone would make me want one as a base for my big head mod but I also understand that if the same threads were used extension tubes made for it could be used on other lights. The availability of a reasonably priced extension tube would facilitate bulding a quad xhp powered by 2s4p 18650.
Based on my measurements, the Shocker had 3 C8 size reflectors, but if you can do it in a 76 mm head, sounds great. The Shocker problems were the weight and size mainly, and even the 3 cells turned out to be a major limit on output over the run-time, plus the fact of the cells in series, you should be using protected cells. The standard SRK 4 parallel cell arrangement is great for high amp unprotected cell usage - safe and scale-able. The SRK multi-LED form factor has many benefits for simple high amp, high output designs, plus the ability to have an advanced UI because of the e-switch. You can perhaps do a better UI with a two e-switch approach, as many higher end lights are offering now. Like the use of the cell status LED’s.
iam in
