As the biggest problem with srk’s is the cooling, how about making the head wall 1mm thicker, cutting the fins 1 mm deeper and having them all the way along the head, even though they are only 1mm deep at the bezel.
This should not add much weight but will improve cooling.
Starting to save up now, trouble is finding a new hiding spot that swmbo wont discover and use to feed the family
In for one, not worried about led or driver those can be changed to suit me later.
Cheers David
ps, This would also make the BLF light different from all the rubbish srk clones :partying_face:
Interesting, just adding a lttle extra cooling.
It does make a difference, I was testing the Darktort and Convoy S2+ te other day. about the same amount of light (Darktort a little brighter), about the same size head. The Darktort has a few very small fins on the head and is stayed cooler then the Convoy. So a little will help.
I think this is something to take along, I mean there must a new head made with integrated shelf, why not tweak the cooling.
I’m in for one, whatever comes out of this effort!
Thanks The Miller for this.
A few thoughts:
I’m split about the direction. On one hand i’d just love to find a plain gd’old 3xXML/2000 lm OTF, simple ‘click and fire’ UI, sub $30 SRK clone to gift around with batteries and charger on top. Everybody loves them. But nowadays i don’t know where to find one.
On the other hand, as a flashlight addict enthusiast, i dream of the ultimate SRK… 10.000 lumens turbo (100W with 3xXHP70?), several well spaced levels, a moon mode and hidden strobe. Fast PWM. What else? I’m not fan of ramping unless there is a physical slider or ring. If the light is designed from scratch i would prefer a more casual body with a good grip and no sharp edges. Neutral white…
Thanks to DavidEF for his idea of the Light-That-Shall-Not-Be-Named. Can’t wait to see it happen…
I would definitely buy one (currently number 17 on the list with a question mark) for the price if the result is a real flooder with a usable turbo of min 4000 or more lumens without a forced stepdown or burning your fingers after 10 seconds …
And first contact with Thorfire is made. We send the initial demands but the rep here was not aware what a SRK is.
In the huge pile of text send, was a mention if maybe a choice of three emitters could be made (XP-L Hi in two tints and Nicha 219C.
We are discussing LEDs and well XP-L Hi just blasts out the most and that is what a SRK is all about.
So in this stage, nothing is clear.
But it is enervating to have started this group buy and see the responses!
