I am in for one.
Direct Drive and 219c would be nice. But becaus of the low Vf it must be limited to a maximum of 6A per Emitter.
XP-L Hi would be nice too.
Thanks!
I am in for one.
Thanks!
I am interested
Add me for one, depending on price and final design may be more or none
mi bill
Will update later.
Must have tapped the “mark read” button it seemed so quiet all of a sudden here
Oh yeah
I want to go with these names:
Q8 for the Quad led, Quad cell, 18650 Premium SRK BLF Special
Q4 for the Quad led, Quad cell, 14500 baby SRK BLF Special
I am in for one. Add me to the list please.
I must add that I also prefer XPL-Hi…
I’m in +1!(i am already on the list #58)
18650 Premium SRK BLF Special+14500 baby SRK BLF Special
THX!
The Q4 is not worked on now, we start with the Q8 and see how it goes.
I’m interested!
I was hoping the smaller version would be the “Sky Ray Queen!”
Definitely in for this.
I figured the name Sky Ray King probably is owned by somebody
Q8 and Q4 fit the Thorfire portfolio and the Q actually makes sense.
FWIW, when people name things after the cell type, they usually use the third digit (length), not the second (width). The usual convention is:
These are all in WWxLL.L form, 16mm x 34.0mm, 14mm x 50.0mm, 18mm x 65.0mm, etc. Except of course, many cells are actually a bit bigger due to the wrappers and button tops and protection circuits and such. And the naming scheme leaves out less popular cells like 18500.
The only instance I can think of when a company used ‘Q’ for quad was Zebralight’s never-produced Q50 — (Q)uad 14(5)00 rev (0). But I’m probably forgetting some other models. Here it was next to their SC600.
For the most part, their naming schemes are consistent… ish.
Anyway, just some examples of what other people are using.
I’ll join for one of each. Are you making the small 14500 model ?
Are they gonna look like Darth and Padme ?
QV8?
sorry for being annoying but again.
why not make baby SRK BLF runnig on 1*26650 instead of 4*14500
pros 26650
- provides more capacity
- provides more current
- cheaper than 4*14500
- thinner
pros 14500
- shorter
Definitely interested, whether 18650 or 14500.
why not make baby SRK BLF runnig on 1*26650 instead of 4*14500pros 26650
- thinner
- torch body for 26650 is more simple
pros 14500
- shorter
- torch can use 1/2/3/4 pcs 14500 (in fact i’m not sure what would be the reason to use baby srk with 3 or less 14500)
You are clear and making valid points, hthus ontributing positively, thanks!
However
A single 26650 light is not to be seen as a baby SRK
A quad celled floody 14500 (AA) powered can be it.
But we focus on the Q8 for now and see how it goes.
Well about how others name their lights, it is up to them
VGxx / Sxx just to nae two series of Thorfire. Qx would fit in there.
I like the Q because quad LED, quad cell, quadrupel the output of modern SRK
I like the 8 since our BLF special should top the Supfire M6 and well there it an 8 in 18650
Q7 would do it too for me but thnking about saling it down later maybe and using a cell 14500 size made me propose the Q8 and Q4, I like it much ore then Q6 and Q5.
And we are just starting this project shoot with names, why not.
Moin,
great, I´m in.
Best regards
Chris
I’m in.
