Ok, you need 10.6mm height if you are going to use tir without stock glass.
Afraid I’ve not received my X6 spacer. Ordered 7th March.
Tracking seems to have stopped on the 14th March.
Post of Russia
He is waiting to be sent from Russia
March 14, 2016, 22:01 102972, Mr A ^ MMPO shop Vnukovo-2
Issued by customs
March 14, 2016, 4:28 102972, Mr A ^ MMPO shop Vnukovo-2
Admission to the customs
Arriving at the Russian border
March 14, 2016, 04:08 102972, Mr A ^ MMPO shop Vnukovo-2
Left the sorting center
March 11, 2016, 9:14 347949, Taganrog
Adopted at the post office
March 9, 2016, 11:20 347900 Taganrog
Refunded.
Appreciated.
Although there was no need to do it straight away. Just wondering if anyone had experienced the same sort of shipping times?
If the spacer turns up, I’ll let you know and resend the money to you. I don’t expect to get things for nothing.
Previous year I`ve got lots of bad experience with russian post. Usually, if smth went wrong and there was no tracking update for more than 3 weeks at any stage, this meant that parcel is lost and it is not big probability to find it out.
This year smth have changed: lots of parcels have very strange way (two imports, two exports, two custom clearance, three times moving between two moscow airports and etc.), but now this is normal (russian post staff sais so) and many of this ways bring the parcel where it is necessary.
If your tracking have not refreshed for a month - contact me and I`ll make refund.
Received my S2+ spacers (pills) today… They are well machined and the shelf is pretty thick, would direct drive a triple XPL HI with confidence.
Observations:
-I’d like an even thicker shelf, driver room is way too tall for the drivers we use. Extra copper is always welcomed, but some people might prefer the lighter weight.
-Packaging must be improved, like wrapping them in protective foam or cardboard and tape. My driver retaining lip was beat up, but nothing that I couldn’t fix myself.
Spacers don’t have driver place or retaining lip. You have recieved pills.
Packaging is already little improved, now I’m using yellow bubble envelopes for most applications, sometimes thin foamed PE is added. Not sure this is the best way, still trying to find out most safety and lowest weight packaging.
Thick lip looks bad even if it doesn’t beated up. Thinking about returning to solder design, searching for low-temperature solder to make driver installation easier.
Next pills will have much better threads and thicker shelf.
Thanks for comment.
Hi kiriba-ru
I received the spacers a few days ago. They seem well machined and without any damage. After polishing the S2+ type a little I started to convert my BLF A6 into a DD Nichia 219c triple. Your spacer fitted a little bit better then the mountain electronics S2+ spacer I had on hand, so I used the Russian one.
I’m very happy with the precision of your work, it seems to help with heat dissipation.
The only thing I had to do was widen the center hole a little,
’cause I used AWG18 cables and didn’t have thinner ones at hand.
And all of a sudden I love the A6. Particularly as a 18350 shorty!
EDIT: could someone please tell me what’s wrong with me adding pictures from Google photos?!?
Thanks - X3
But it’s hard to right click on the mobile phone
Really I’ve got no other computer!
I received my copper x6 spacer (the shorter one to fit a lens on top of the optics). I installed it and I had to dremel the lower part of the spacer so that it would fit into the light perfectly. I’ll post a picture later when I get a chance.
Thanks for your feedback vinte77. My X6 host has about 21.4mm pcb place diameter, spacer lower part was about 21.0mm. Seems that host dimentions may differs a little.
There is some delay in production (machine tools are to busy), hope X6 Al spacers, more Convoy spacers and pills will be ready till end of April.
I will definitely take a copper S2+ full pill for a triple when they are finished.
Do we have any news on the X6 aluminum spacers ?
If everything goes good, more convoy spacers, single and triple pills, X6 Al spacers, X5 quad kits will be ready in 1-2 weeks.
Good news, your solid copper pills are great.
I got my first order of S2+ spacers today. Pretty good. Twenty days. My first ever order from Russia.
Very nice
I’m waiting to order when new batch is ready !
I think we could use some spacer rings so we can fit 24mm Carlco quad optics into some lights. I haven’t yet found a light it fits in, always a tad smaller than the inside diameter of the bezel. We need some kind of ring that will hold it into place for lights that need a few more millimeters to retain it.
Hi, I am interested in a Cu full pill for triple LED (for Convoy S2+).
