added a link. Still have to look at the specs but coming from Nichia they should be good. Iâm at work now so I should not spend too much time on BLF :innocent:
Looking over the specs, the 144A is 5.0mm x 5.0mm, and compares to XHP50 in size and performance (but not the top XHP50 bin) with a single chip/die and better color rendering and lower Vf than the XHP50! :partying_face:
The 90 CRI version of NV4L144AM is available NOW. 3A forward current, thermal resistance only 1.2 â/W, 936 lm. Ideal led for a single 18650 âluxuryâ flashlight.
Erm, not single 18650 unless you have a boost driver. The Vf of the AM is ~6V. The AR is ~12V. Almost like theyâre trying to directly compete with XHP-50âŚ
A thermal pad is needed because you want to thermally connect the led to the flashlight with no non-metal obstructions, and the electrical pads can not be used for a direct metal connection. The output advantage of a direct thermal path only starts at an out-of-spec current (under 3A a XM-L2 shows hardly an advantage) and gets more when current increases.
What would work really well as a non-DTP board would be a non-DTP board like this:
(orange is the copper-poor, blue is the exposed copper for soldering)
If the MCPCB is made with an as thick copper-poor as can be produced, the heat will spread sideways fast and have then enough surface area to cross the dielectric layer efficiently. This board can be used with all the two-pad leds that are out there and boost their performance compared to the common boards.
No-one makes these, perhaps we can ask Hank to have a Noctigon version of this board designed.
I think getting those made is a worthy goal. I do understand that a direct thermal path is better technically. But, I havenât seen proof that Nichia LEDs specifically suffer from NOT having the separate thermal pad. Iâm sure itâs impossible to tell, since they donât make any of their LEDs both ways (with and without DTP pad) for direct comparison. But, what if the emitters that donât have DTP pads are designed in such a way that heat isnât the first thing to cause failure? What if removing heat isnât the bottleneck to performance? I know for Cree LEDs heat is definitely THE issue, but what if for the Nichias it just isnât?
Itâd be nice if it fit on a common Cree footprint so MCPCBâs were easy to come by.
Creeâs probably wouldnât need a thermal pad at their rated specs either, but because they do we can overdrive them to the levels that make this hobby fun. Likewise Iâm sure there is no need for a thermal pad at the Nichiaâs rated specs, but it could have been much more fun if there was one. Time/testing will tell.
Direct XML swapping was in my mindâŚbut I didnât see that the Vf is 6V. It makes the swap more complicated.
Like DavidEF said, itâs more a XHP50 competitor
The 229A is 4.0mm x 4.0mm and ~3V. Not exactly XML size, but could be used for a swap. Youâd need to replace (or mod?) the MCPCB anyway, since the Nichia doesnât have the third pad in the middle for DTP.
There are ways for DTP with custom driver concepts:
a) Reverse the battery so that the body is + and can be electrically connected to LED+.
b) Use a high-side switch, i.e. a P-FET. These typically have a somewhat higher R_DS, but there are very good ones, too. LED- can then electrically connected to body (batt-).
So you would use short fat wires from the led into the copper star ?
And heat would go to the star ?
This would work with LEDs that also have a thermal pad. For turbo heat transfer.
