People who think like that probably aren’t thinking rationally or logically. To paraphrase your argument. Only 4mm wider will give you double the capacity of a 14500 for the same length.
And as there are already plans for a 4x18650 SRK a 3x18650 would probably be redundant. But 3x18500 would be significantly smaller than a regular SKR and much better performing than any 14500 power one.
must resist temptation
… ooh can’t resist going off topic
I would love to see a smaller brother baby SRK capable of 14500 and AA cells, this I would gift no I fell for it
Please know a baby SRK is talked and thought about but first the King!
I think you missed where I was going. a 3x 18500 wouldn’t be much smaller than a 3x 18650, but 1/3 the cell capacity. Why do it? A 14500 cell scales down almost perfectly from a 18650 cell. In other words, the ratio of length/width is practically the same for each. So, to make a 4x 14500 that is the same shape as a 4x 18650, but significantly smaller, makes some sense and could truly be called a ‘mini’ version of the same.
XHP50/70 or even XHP35 require a 2S2P or 4S battery compartment, and that will limit the modding possibilities of this light. One of the main reasons to want a good quality SRK-type light is because of the use as modding host. We will keep that goal in mind during the developement.
It FEELS like a clever arrangement of the battery compartment should allow the light to ship 4P, but allow a modder to “cut here and here for 2S2P, there and there for 4S”. Having never seen an SRK in person, does the tail cap screw on separately or is the battery compartment once piece? Is there / could there be an insulating plastic cup in the bottom of the battery compartment that would be swapped or modified for different cell configurations? How does the front end of the ‘battery pack’ contact the driver? A PCB would allow reconfiguration by changing jumpers and inserting cells in a different orientation.
If the cells were held in a plastic carrier, 3 different carriers could be produced to provide the 3 different cell configurations…
Can someone post some good pictures of a disassembled SRK clone?
