Parallel cells are safe - even at different discharge levels, they will self level while discharging. Series cells at different levels is an issue - one cell can deplete first and there’s no way for that condition to be detected. This is why series should always use protected cells, parallel is fine unprotected as long as the driver does LVP. Of course protected cells always will be higher resistance, have a lower threshold on amps than unprotected. It’s pretty darn safe to mix different cells at different capacities in parallel configurations. This is the beautiful thing bout SRK’s - 4 mixed bag of cells, whatever you got on hand. The down side is you need a protruding top on the cell.
For cells in series, of course if you know what you are doing and are careful, you can use unprotected cells, and understanding the tech stuff, you can lower risk by using cells either new or of known same age, same charge level, and/or be careful on draining, or knowing the level LVP kicks in, you can play it safe, but the burden is on you.
I think the 4 parallel cells are part of what defines an SRK clone. Personal opinion is if not 4P, it’s not an SRK clone.
Just thinking out loud for the mini one if such a thing becomes reality. Personally I still favour 3x18500. However if it was to stick to 4 batteries. What would offer the best performance:
4P Li-ion - 4x14500. You’d get about 2800mah and 4.2v
Or
4S NiMh - 4xAA Eneloop. You’d have 2000-2500mah 4.8v+
I’ve not worked out the wh but they must be pretty close. If you wanted to run 3amp draw+ which would stand up to it better?
I honestly don’t see the appeal in a 4x14500 light. I’d rather a single 18650 light as it’ll out perform it and be smaller. But a 4xAA one would appeal.
Djozz had seen it if my memory servers me correctly, there is a thread started about them.
So if they are interesting I figured we would see an email appear
Now that you brought it up our LED connoisseur will certainly kick in about them
I don’t see any reason for a mini version. A mini 4 cell light will still be too large for a pocketable light, won’t weigh all that much less than a 4 x 18650 and will have a foreshortened run time in comparison. I am still interested in a good 4 x 18650, using parallel cells that can operate the light on a single cell if necessary. If there was some easy enough way to engineer a light that could be easily set up to run a 6 volt XHP50/70 that could be very interesting too, but not an absolute necessity, IMO. That would likely be complicating things.
Yes, this is the aim.
And by making the housing decent, have the driver hold into place by a ring or screws this is supposed to become a light worthy of modding and relatively easy to do it with.
The reason NiMh’s are not often used in (chinese) flashlights is because of the somewhat lower energy density, but mainly their 1.2V nominal voltage requires power-limiting boosting or running at least 4 in series. Our proposed mini-SRK has 4 cells by design idea, so the use of NiMh cells is automatically a consideration.
And then the advantage of NiMh comes in sight: it is safe, well-known to the public, very available, alkalines can be used as back-up. But IMO another main advantage is power capability: good NiMh cells have very low internal resistance and allow high currents just like that. 4 cells in series have enough overhead voltage to deliver a triple or quad well over 10A even when using the relatively higher voltage Cree leds. I have not seen a NiMh-powered triple or quad (anyone know one?), but if well build (especially the battery carrier, there’s many spring connections there, steel springs are not an option) the output must be quite impressive, 2000 lumen should easily be achievable.
I see no one reasonable idea except just Feng Shui design (4 led => 4 cells) why we should stick to 4*14500 or 4*AA instead of 1*26650
26650: cheaper, more capacity, more Amps.
NiCd(NiMn) afair is sensitive to working mode - it should be dis(charged) in full to avoid memory effect. And you can’t use 1-2-3*AA configuration.
PLease let us focus on the Q8 for now,
. Must restist temptation to jump in MUST RESIST TALING ABOUT THE SMALLER VERSION CAN I? Yes the urge can be controlled I do have self restrain just press save now!
Right now we lean to XPL Hi in two tints for easy of manufacturing. We will ask of the 219C can be a third choice.
We are looking into the new Cree that started a few topics yesterday.
The XHP or MTG2 will be modding projects from you guys who want to.
Do know the integrated shelf, the square threading and overall quality and features should be making this a worthy light for modding.
The same for me.
3*xhp35 would cost almost the same as 4*xp-l hi. It provides more efficiency per Wt and imo more possibilites for modding.
But we need boost driver for 4p cells
Btw what about the beamshots, does hotspot shape look good for 4*led reflectors comparing with 3*led reflectors ?
