Yes Tom, and if anybody wants to mod the Q8 into a series monster running unprotected cells and know what they are doing I really like to see the mod!
Uhhhh, no one mentioned XPG-3's yet. Hhhmmmm...
https://www.cutter.com.au/proddetail.php?prod=cut2924, https://budgetlightforum.com/t/-/39216
Djozz had seen it if my memory servers me correctly, there is a thread started about them.
So if they are interesting I figured we would see an email appear
Now that you brought it up our LED connoisseur will certainly kick in about them
I don’t see any reason for a mini version. A mini 4 cell light will still be too large for a pocketable light, won’t weigh all that much less than a 4 x 18650 and will have a foreshortened run time in comparison. I am still interested in a good 4 x 18650, using parallel cells that can operate the light on a single cell if necessary. If there was some easy enough way to engineer a light that could be easily set up to run a 6 volt XHP50/70 that could be very interesting too, but not an absolute necessity, IMO. That would likely be complicating things.
Yes, this is the aim.
And by making the housing decent, have the driver hold into place by a ring or screws this is supposed to become a light worthy of modding and relatively easy to do it with.
What about a boost driver to run 6v emitters? The cells could stay 4p.
Too much possibility, let stick around with the original plan quad led with 4x18650.
The other setup can be used for future project
Please put me in for quantity of 2. This potentially could be my first SRK style light. Thanks.
Aloha, Put me down for one please.
Mahalo
Agree!
The reason NiMh’s are not often used in (chinese) flashlights is because of the somewhat lower energy density, but mainly their 1.2V nominal voltage requires power-limiting boosting or running at least 4 in series. Our proposed mini-SRK has 4 cells by design idea, so the use of NiMh cells is automatically a consideration.
And then the advantage of NiMh comes in sight: it is safe, well-known to the public, very available, alkalines can be used as back-up. But IMO another main advantage is power capability: good NiMh cells have very low internal resistance and allow high currents just like that. 4 cells in series have enough overhead voltage to deliver a triple or quad well over 10A even when using the relatively higher voltage Cree leds. I have not seen a NiMh-powered triple or quad (anyone know one?), but if well build (especially the battery carrier, there’s many spring connections there, steel springs are not an option) the output must be quite impressive, 2000 lumen should easily be achievable.
Interested!
I see no one reasonable idea except just Feng Shui design (4 led => 4 cells) why we should stick to 4*14500 or 4*AA instead of 1*26650
26650: cheaper, more capacity, more Amps.
NiCd(NiMn) afair is sensitive to working mode - it should be dis(charged) in full to avoid memory effect. And you can’t use 1-2-3*AA configuration.
PLease let us focus on the Q8 for now,
Must restist temptation to jump in
MUST RESIST TALING ABOUT THE SMALLER VERSION
CAN I?
Yes
the urge can be controlled
I do have self restrain
just press save now!
What’s the proposed led in there? Could we have the new 219C? Or Shaved XHP70 or shaved MT-G2? But I really would like the XHP35
I’m interested!
in
Right now we lean to XPL Hi in two tints for easy of manufacturing. We will ask of the 219C can be a third choice.
We are looking into the new Cree that started a few topics yesterday.
The XHP or MTG2 will be modding projects from you guys who want to.
Do know the integrated shelf, the square threading and overall quality and features should be making this a worthy light for modding.
The same for me.
3*xhp35 would cost almost the same as 4*xp-l hi. It provides more efficiency per Wt and imo more possibilites for modding.
But we need boost driver for 4p cells
Btw what about the beamshots, does hotspot shape look good for 4*led reflectors comparing with 3*led reflectors ?
In the 70CRI 219C sales thread from RMM I did a small output calculation comparing the 219C to a similar tint and CRI XP-L Hi at 5A, and qua output the XP-L Hi wins by a margin.
In a direct drive situation the situation is different and could be as follows:
depending on flashlight resistances and type of battery, because of its very low Vf the 219C will draw more amps than the XP-L Hi, then at the cost of more power and heat the output of the 219C’s could still come close to the output of XP-L Hi’s.
Consideration for 219C could be the lowVf, tint, and price, but it will probably not have the best output and runtime, and it will run the flashlight hotter.
Yes Djozz is right to the point here. We are considering the new Cree but for now the XP-L HI is the winner and aim.
We are aiming at making the Q8 accept the current SRK reflectors.
Meaning one could mod it into a light using anywhere from 3 to 10 emitters.
I am going to BOLD some specs in the OP that are set like the 4 parallel cell configuration and XP footprint for LEDs to avoid confusion and having to repeat the need for modding oneself if XHPs are wanted every page of this thread
