HELP!!! new here, not sure how to ask a question. Need help from you tech’s. Got my S70 and it will not come on . Checked in DIY forum and read the info from Don, used paper clip from batteries to body and light comes on and changes modes. So I guess the problem is the tail cap?? THANKS for any help
Two things I can think of. First remove the four pedal cigar ring and try again. If it works the cigar ring was not turned all the way down or the retaining ring in the switch was over tightened and not giving you enough clearance. If the second slightly loosen the retaining ring until the light works.
If the cigar ring was not the issue the try tightening down the switches retaining ring.
Just did a tail cap reading with my new Basen 26650”s which I bought after the good reports on here about them & am disappointed.
4.20A compared to 5.24A with my KP”s, 4.94A with my Thorfires & 5.01A with my 18650 Efest 3100 mah IMR”s.
Post about the Basens”s, post 34 & 35 Basen 26650 4500mAh Issue ?
Tail cap readings does say a lot but not everything!
It all depends on the type of driver used.
With a good buck driver, if the cells maintain a higher voltage the amp draw will be less. And the other way around, if the voltage sag is bigger (thus the cells have a lower voltage) the amp draw will be higher.
Let say the the driver regulates the current to 4.5A to the led.
4.5A x 6.5V = 29.5W.
With some driver losses (10%) that is 32.76W from the batteries, or 4.20A with a voltage of 7.8V (3.9V per battery)
The driver wants to maintain that 4.5A to the led, so the batteries has to deliver 32.76W.
I my above calculations I took your reading of the Basen’s, the voltage is a guess but that’s ok since this is just an example.
We know the batteries has to deliver 32.76W to the driver to maintain 4.5A to the led.
Lets take your other reading, 5.24A.
32.76W / 5.24A = 6.25 / 2 = 3.125V (per battery)
So your KP’s voltage does sag a lot more under load so the driver has to pull more amps to compensate that and maintain 4.5A to the led.
(assuming the Amps to the led are all the same)
If the above is true, it means that the Basen’s are very good batteries, even better then the Efest 3100 mah IMR’s
Pls correct me where i’m wrong, this is how I understand the workings of a buck driver. I could be wrong, but then I wouldn’t know :laughing: .
Could you make a comparison of luxes, with this different batteries? if you do not have a lux meter, you can use your Smartphone with an App of luxometer. It’s not about getting accurate lux values. It is to see the difference between the batteries.
What I am disappointed about isn”t the performance of the Basen”s compared to my other 26650 cells but their performance compared to the earlier Basen 26650 cells.
I know that they have less sag compared to say the KP”s but mine are lower resting voltage, lower capacity & give lower tail cap amps than the earlier Basen”s.
Or am I getting this wrong & the fact that these new Basen”s give lower amp readings than the earlier version actually means they are better ?
That is with a light meter app on my phone.
I have no idea whether the app is any good though ?
Guessing the app isn”t up to much as I just got exactly the same reading using a Thorfire C8s as well ?
Are you guys really in write only mode? Check the video a couple of post before… Buck driver pulls what the led needs. If the voltage sags the amp will be higher, if voltage does not drop under load the amps will be less.
Yes I know I will phrase my question differently.
This is my question.
2 cells, one weighs 100g, has over 4500mah, resting voltage of 4.18v. & gives a tail cap reading of 5.4A
The other cell weighs under 90g, has just over 4000mah, resting voltage of 4.15v & gives a tail cap reading of 4.2A.
Which is the better cell ?
Is it the 4.2A cell as it is giving more voltage hence the lower tail cap reading ?
The second cell is advertised by the manufacturer as an improvement on the first cell.
Yes. Check my post .
It al has to do with power (watt), amperage only isn’t saying a lot.
We can’t say for sure based on your measurements, it takes a lot more testing to know what battery is better. Though I think that the lower weight cells has a lower internal resistance so you can draw more amps while maintaining a higher voltage. That doesn’t mean it’s better, it’s just capable of delivering higher amps. While the other has a slightly higher capacity.
Steve Martin once did a skit about being an audiophile. Starting with a little AM transistor radio and moving up to FM Stereo, you want more and more and more, soon enough you have a 10,000Watt system and have to go to the Moon for best hearing experience.
The more lumens we get, the more we want. It’s an never-ending avalanche of incoming lights. Pocket book forewarned.
