Alternative knive shops to AE, Gearbest, Fasttech ...
Okay, I ordered the Amplitude from DHgate.
(I'll get the Volt some other day.)
And the prices of the two knives that I provided links for have gone up sharply since the time of my order!
Has anyone ordered from sh0142-hk.com ?
If yes - everything OK so far?
I have 5 Knifes in sight :stuck_out_tongue:
Still waiting for delivery
I just received a mail from vendor
What kind of problem do you think it can be ? With Chinese customs or european customs ?
Chinese customs.
European customs would send a notice to the addressee.
I received my order from HengSheng today (ordered on 3/30/2016):
        ![](http://i278.photobucket.com/albums/kk107/golfrt1/IMG_3074%202%202448%20x%201836.jpg)
Gerber 342, 65mm blade, 3cr13mov steel, steel handle, quick opening, frame lock
Kershaw 1730ss, 76mm blade, 8cr17mov steel, bead blast steel handle, SpeedSafe assist, frame lock
Kershaw 3800 Shuffle, 53mm blade, 3cr13 steel, nylon fiber handle, liner lock
Comments:
Gerber 342: http://www.sh0142-hk.com/gerber-342-steel-shank-quick-opening-match-color-box-p-589.html
Nice, pocketable folding knife. Spring-assisted opening. Sharp, shaved the hairs off the back of my hand when I tested it. Frame lock took a bit of effort on my part to close, somewhat stiff - but manageable with one hand.
Kershaw 1730ss: http://www.sh0142-hk.com/kershaw-1730ss-8cr17mov-allsteel-titanize-oem-p-822.html
Very nice, 76mm blade hits my sweet spot. I like knives 75 to 80mm. Spring-assisted opening, well-balanced, fits my hand well. It came sharp (I lost enough hairs testing my Gerber, so I didn’t repeat that test). Good looking knife, I like it a lot. Negatives: pocket clip is “vise-grips tight” and almost impossible to use. And the frame lock is extraordinarily difficult to open with one hand. Even with two hands, it takes a bit of effort to pry open.
Kershaw 3800 Shuffle: http://www.sh0142-hk.com/kershaw-3800-3cr13-gray-titanium-nylon-fiber-white-box-p-823.html
A small knife with only a 53mm blade, light-weight, very EDC-able. Delivered equally sharp as the others. But I cannot recommend it because it doesn’t lock. The liner lock mechanism is a hair too long (maybe as little as 1 mil too long) to lock in the blade. I’ll have to disassemble the knife and file down the liner lock to get it to work right.
EDIT: Filed down the liner lock, just took a hair off the inside edge of the lock. The Kershaw 3800 Shuffle now works perfectly. Easy, one-hand action to open and close. :slight_smile:
3 bucks? O_o
My thoughts exactly! An assisted knife for 3$ :beer: !
Apparently I do need 6 Knifes now…
Nice to see that this shop actually ships.
Shipping is about $4 per knife where I live. Still pretty good deals though.
Hi guys
I finally just received today my 3 knives from HENGSHENG .
Little delay due to chinese customs but good communication with the vendor.
Well packed
Awesome quality for the price !
Full size : http://hpics.li/62c06e0
Full size : http://hpics.li/12d292e
Full size : http://hpics.li/c5d6119
Full size : http://hpics.li/941aa95
Full size : http://hpics.li/10481ba
few little problems :
a coating defect (stain - kind of fading) on the blade
a little metal blur on the biggest hole of the clip
thickness of the liner not burred
Full size : http://hpics.li/7f61ca1
Full size : http://hpics.li/5a85476
Full size : http://hpics.li/13e0f8b
Full size : http://hpics.li/93a011e
I received my Kershaw Amplitude 3.25 3871 from DHgate yesterday.
Shipping took quite a while, and packaging wasn't done very well...
but it's the real deal!
I really like this knife.
That’s lovely RC - what did it cost you?
$18.94
Hi RC - I’ve just checked your previously supplied link - thanks.
That knife is right up my street - very attractive. I love the blackwash finish. Can I ask a question? I’m a sucker for lanyards on knives. This looks really deep carry (which I also like) but I’m wondering if there is a means to tie a lanyard onto one of the standoffs perhaps? I can’t really tell if there would be room on any of the online pics I’ve seen. I’d rather not tie a lanyard around the clip itself - the OCD in me shudders at that lack of neatness!!!
One pic I’ve seen suggests a lanyard could be looped around the actual clip fitting, between each of the scales? Is that possible?
TIA
SP
I don't see where a lanyard could be safely tied to the knife.
Sorry.
Nope. If you put the lanyard between the scales, it could be cut by the blade.
EDIT: Actually, if you tie a knot in the the lanyard so that there isn't any slack, you could put the lanyard between the scales safely.
I take that back.
Hmmmmm……
I may only use quite slender leather cord, would that work without fouling the blade?
Alternatively, how about if a hole was drilled through the clip, near to the bend where the fitting is? Is there room there maybe to drill a hole so a strand of 550 could be threaded through it?
Cheers and sorry to pester you with q’s.
Paul
The cord would be pretty close to the blade, so I don't think that would be a good idea.
There is room to drill a hole in the clip! I think that would work.
No problem.
Good fellow - thanks very much.
I think I may have to treat myself to that one. After all, now that I have my British Blades Forum Knife (Engraved Spyderco Urban) in my greasy paws I only have a Victorinox Alox Farmer en-route……
Kind regards,
Aren’t you meant to be in bed around this time?
Paul
