What did you mod today?
I reflowed an XM-L2 5C onto a DTP board and put it into my Kronos X6. The tint is great, and the beam pattern is perfect.
I modded my B158.
I swapped in an XP-L HI 3B reflowed onto a Sinkpad, added 22 gauge wire, a MTN-17DDm driver, lighted tailcap, and bypassed springs.
That was my second reflow ever, and I’m so happy I didn’t mess it up!
I painted the top of the pill a flat black to minimize any artifacts (Thanks pilotdog68 for the paint brand!). Man is it hard to use that stuff without ruining the finish.
I get 5.5-7 amps at the tail from it, and 169600cd. So about 824 meters of throw.
CRX you are seriously busy at the moment, great work!
All I did today was centre the led in two BLF A01…
Does this count as a mod?
It is a Remington Standard, it does not say 12” anywhere but perhaps the 16 means it is a 16” ?
Found it on the street 10 years ago, still works, my son finds it much fun, he is just starting learning to read!
S2+ with a qlite (mtne) + 7 7135s (double) 16mm XHP50 U4 1C 2 keeppower 750s. You can’t keep it on high very long but it sure will give you a laugh. L/MedHigh/TurboHigh. A LOT of light. I am still laughing. Carry some batteries for backup! File, file, and file the driver retaining ring. Everyone should have at least one.
I learned to type on one of those, over 40 years ago. The letters were worn off the keys, still have it as a matter of fact. Now I have to go look to see if it was a Remington or an Underwood….
I’m having a hard time not to write something like: if you show me yours ……….
I found it somewhere eating dust and disassembled and cleaned every last detail of it.
Then I lend it to my kid-brother so he could write his thesis. Got it back a short while ago.
Apparently he could not be bothered to put a cloth over it :person_facepalming: :rage:
I tried a 219C on a filed Noctigon in my Olight S2…that was a fail !
Artifacts everywhere in the beam, the TIR does not focus the light properly :frowning:
So I swapped the stock CW emitter for a nice warm T4-7A and called it a day…
Much improved Nitecore Tube XM-L2 4C
Did you chopped an MCPCB ? Do you have some internal pics ? CUrrent ?
How, and wow, great job as usual :smiley:
No MCPCB at all, it’s just a bare LED with a tiny copper block soldered onto the thermal pad & rigid wires directly to the emitter.
Stuffed a bit of that silicone cube stuff around it too but there’s really not much current to cause much heat. I should have took pics and measured current, but i didn’t :laughing:
This one was a little more difficult, i accidently dedomed the XR-C while working on it so i’ve covered it with UV setting glass glue for protection.
I’m obviously running out of lights to mod, down to nitecore tubes now… :laughing:
You obviously have too much time in your hands :partying_face:
Keep it going, I love seeing original mods !
True, and thanks :laughing:
It’s only the beginning : S10R II triple XP-G2 3C combo from KD
X3…looking good already. I like!!
Well that was stupid.
I just fried a dedomed xpg2 (I hope it was just the LED….). I spent the last few hours modding a UF-1508 aspheric with a dd xpg2 and a 5.5A MTNMAX driver. The 1508 has a bit of an odd pill and a threaded parabolic piece that screws down onto the mcpcb. After several failed attempts at getting the LED leads soldered flat enough I switched over to flat copper sheet. It worked eventually, just a pain to work with such tiny pieces of metal. So I screw down the securing piece to secure the mcpcb and I think to myself “don’t forget to pull this back off before testing”……… I hook up the driver pop in two cells and a flash of light followed by utter disappointment as I instantly realized my mistake. :person_facepalming:
Also swapped my second SRmini’s emitters :
7A on the left and 4C on the right
unknown, I thought I was the only one that did stuff like that! :stuck_out_tongue:
I just ruined three brand new XP-G2 S4 2B mounted on a triple noctigon. Not going into details.
But we want details :smiley:
I put a stacked resistor on an L2 and forgot about reflector clearance when soldering the leads back in, shorted it and fried the driver. I did have Kapton tape on the base of the reflector, but it tore. I’ll be happier with the Bistro driver anyway… :wink: Still, was hoping to find out what the stock driver was capable of. :frowning:
