no, if you click it once, it goes to low
no memory
if you click twice, med, 3 x - high
turbo from off is one long press
{answering question “does dqg tiny 18650 start on high?”}
wle
no memory
wle
some photos
http://forum.fonarevka.ru/album.php?albumid=1062
plus of the battery is connected to the LED Thermo
Got my DQG Tiny IV today….
Sad enough it looked horrible.
I submitted a ticket to seller, hope I atleast can get a refund…
You’re welcome
II
What is so horrible on your light?
The different anodizing colors? That had been a thing since the first one……
Edit: Saw the scratches now… Well that stinks, on the up side, it is broken in…
What?
Yep. bad scratches and a couple of dents. Looks like its been rolling in a conveyor belt for a while
Mine’s got some comparable scratches. I bought a faulty DQG AAA in the past, at least this one works
Still very much like the size, but quality in general sucks. With only slight scratches as an EDC for me it’s oke though…
Offcourse it should be flawless, good luk with aftermarket sales…
Will post my mod once done. Still need some work on the driver.
Grey color have bad anodizing. They send me black for rewiew and it was OK.
I have a grey from Banggood, and it was very nice anodizing, with the bit of color mismatch that is “normal” for DQG tiny it seems. No scratches or flaws like shown…
If you want long runtimes at max power, how about the Zebralight SC600w III HI
In my opinion, the SC600w III HI is probably the best stock light I’ve ever owned. It’s so good that Vinh gave up on modifying one because none of his modifications made a significant difference on performance. About the only bad thing about Zebralights is they can’t be modded by most amateur modders.
people,which driver will be fit into this flashlight? 3amps are not enough for me.i want change it.thanks
about driver
2000mA
Just look what they’re doing
it’s step down driver and 3th tiny
http://forum.fonarevka.ru/showthread.php?t=22959
But you need new bezel & bit process on a lathe head
http://forum.fonarevka.ru/album.php?albumid=940
list this two pages
http://forum.fonarevka.ru/showthread.php?p=731180&highlight=�����#post731180
http://forum.fonarevka.ru/showpost.php?p=731443&postcount=151
Not sure exactly what size driver will fit in. It’s larger than 17mm. I think maybe 20mm.
HOWEVER… the biggest problems is that the original driver includes both the driver and emitter on the same board. This allows for the most compact light possible, but unfortunately doesn’t allow you to simply swap in a new driver. Any new driver you could buy won’t have the emitter on it, and there isn’t room to install a single-emitter star, the optic and a new separate driver board.
Essentially, if you want more power, the only option is to convert this light to a triple. The Carclo triple TIR optic is 7mm shallower than the stock TIR. This frees up enough space to mount a star in front of the driver.
Maybe use somewhat thinner glass. On mine (1mm x 21.3mm glass) it screws down all the way.
But nice, how’s the driver section working out?
I’m reorder new glass (1mm)
Driver glued. I squeezed it with a screwdriver. But in the end broke the resistor R50.
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15196
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15201
I finally finished my flashlight.
All photos here Светодиодные фонари и световые приборы. Всё о светотехнике. - Альбом MSS: DQG Tiny 4th XML2 18650
LED https://www.fasttech.com/p/3505302
Glass http://aliexpress.com/item/New-flat-glass-watch-crystal-diameter-21-5mm-Thick-1mm/1097050471.html
MCPCB http://intl-outdoor.com/noctigon-3xp-advanced-triple-led-copper-mcpcb-2-pcs-p-763.html
TIR http://intl-outdoor.com/carclo-10507-triple-led-optic-lens-p-836.html
Serp,
That is a fantastic mod! Thanks for the great photos and especially the links to the parts you used!
I do not like only a small gap between the bezel and the housing
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15681
