[Oshpark] HQ 15mm/17mm programmable boost driver with ATtiny13A
Firmware
I started with an adapted Dr. Jones MiniDrv firmware.
Frequency changed to 18kHz, on-time-memory, 9 modes. This works fine.
The 9 modes were for testing the behaviour of the boost circuit at low PWM levels.
Simply adapt the modes line to something like {1,8,255} for a practical result.
I know some of you out there are hoping for nice firmware implementations, we will surely need help on that. For now I’m trying to lay grounds for the hardware stuff. A fancy UI is way out of my league.
But I already reserved this whole post for firmware and will gladly fill it up with all you can offer. :laughing:
Some History
This was my first successful test to combine a boost circuit with an ATtiny13A.
I hooked up a stock Nanjg110 to an ATtiny13A and a capacitor, both remainder of a Nanjg AK47. I added an OffTimeCap between Pin-2 and GND. And I used an IRLML0030TRPbF as FET. I placed the FET on the pads for a 7135, cut the traces and rewired (better: re-blobbed) for the PWM signal from Pin-6.
I flashed a it with an offtime firmware with 4 modes.
And there was light.
At 18kHz PWM values of 2 – 10 – 40 – 255 resulted in 12mA – 102mA – 198mA – 404mA with a single full and resting Eneloop.
With 2xAA the boost controller died (blew a tiny fan of smoke) at one of the first mode changes. It’s surely the controller that died, I swapped this single component from a new 110 and everything was working again (with 1AA).
That’s when I took a closer look at the Fasttech boost driver (who has a controller for modes) and the two resistors there seemed to serve as protection.
In the meantime I found a replacement diode for the large SS14/SS24. As I looked for 2A diodes I stumbled upon the BAT60A.
Even rated 3A, only 370mV forward voltage, and SOD-323 package. It’s the teeny-tiny component on the right, where the cathode line uses up almost half the component.
I hooked it up in replacement and drained 5× 1AA and 6× 2AA (Eneloops) on this driver, while monitoring input and output current. Works perfectly fine. Even increased output current in 1AA config and efficiency in 2AA config (needs a lower input current to reach the 920 mA).
Then I reworked the FastTech driver (comes in blue now instead of green).
MCU changed to Attiny13a (which was pre-programmed)
Some MCU-traces cut (Pins1/4/5)
Rewired: Pin6 to Fet-Gate (red wire)
MCU+ is already connected to V+out
Rewired: MCU- to GND
MCU- of the original driver is connected to Fet-Source/PAM3. This did not work with the Attiny, it wouldn’t change modes.
Rewired MCU- to GND (black wire) and voila: 3-mode boost driver that did survive several 1AA and 2AA drains.
The first Oshpark board HQB15 v1 successfully built.
2× 2AA and 3× 1AA (Eneloops) drained, about 200 mode changes, all good.
It’s a HQB15 de-luxe with Coilcraft inductor and high value capacitors.
Partlist with used values and the firmware in this post.
Driver height with this inductor is 3.7mm (0.2mm less than with the FT inductor). Now take the new Oshpark 0.8mm boards and you’re down to 2.9mm. That’s 3.0mm less than a Nanjg110.
Enough space around the Attiny13a for the clip after driver assembly.
I took the experience from building v1 (it’s really, really tight) and tweaked the design. I skipped sharing v1 and went straight to HQB15 v2.
All future Oshpark boards will be introduced in this thread.
This is really great thread. I feel that it wrong for me to make this post as this thread so well put together. But, on the other hand, I don’t feel it would be right to not express a big thank you. Thank you HQ for you continuous efforts to make programmable boost driver solution available to us all.
Thanks HarleyQuin. Amazing efforts.
I’m not a builder. Can someone build these for sale? Mtn electronics?
Thx. My pleasure.
Here is the next version of the 15mm boost driver
HQB15 v3
It’s still the basic circuit (including R2 and R3, no LVP)
I think this is as much as I could get out of this 15mm design, so for now there is no v4 planned.
It’s about time for building and testing.
Notable changes from v2 to v3:
- more GND vias
- GND plane slightly increased
- 3 plus vias moved outside the L1-pad
- some copper pads increased over stopmask
  • MCU moved slightly inwards
It’s still 15.6mm outer diameter, so the copper GND ring is 0.3mm smaller than it does look on these pictures.
Oshpark Link
When installing into a light it’s crucial that D1, R3 or the FET don’t get electrical contact with the flashlight body/pill. This might be tight and could risk shorting the light.
Same goes with the LED leads (LED+/LED-). Both must avoid GND.
Pin1 on the ATtiny (RST) has no pad on purpose. That way I could move the whole component slightly down to keep pin1 of the ATtiny (VCC!) away from the side.
Parts size
(more on parts and values see partlist overview in post#2)
Switch: PAM2803, SOT-23-6
L1: max 4.3x4.3mm
D1: BAT60A, SOD323
C1: 0805
C2: 0805
C3: 0603 (optional)
R1: 0805
R2: 0603
R3: 0603
MCU: ATTiny13A-SSU, 8S1
OTC: 0603 (optional)
FET: N-Channel, SOT-23-3
It’s a bit early for that, Gunga, since so far only one prototype has been made so no beta testing with several to see what problems arise and what needs fixing. If interest holds then it’s possible RMM or 3tronics will pick them up. Since you and I can’t fix very much we need these to be more thoroughly worked up before it’s worth it for those who can to try more than a few at a time.
^ This
I’m shelling out all I can to give others options to step in.
But I consider these far from ready.
I tried to point out the lines where we stand in the “4 OPs”
Atm I can spare more time at the PC than at the rework station, so there are more boards than testing on my side.
Toykeeper’s motto is: release early, release often. I’m working on it. - nod -
It is beautiful :slight_smile: Both the finished v1 board and the layout for v3. They make me wish I had the time and equipment to build one, even though I don’t understand half of what is going on in there and wouldn’t know what light to put it into :smiley:
Thank you for the in depth history, I for one find it both interesting and helpful in furthering my understanding. Why the change in capacitors from the FastTech board? I understand the reasoning on the inductor but is it just to get better quality caps or to be more certain if the values?
Oh sorry. Desperate for a good driver and jumping the gun. :slight_smile:
Thx. And we’ll find a light for you to put it in :wink:
I just wanted to play it safe.
  1. Wight himself wasn’t sure whether Cout (=C2) of the boost circuit is enough to act as decoupling for the ATtiny. That’s why I added C3 in 0603 footprint to at least give the option to add some capacitance.
  2. The FT driver has (iirc!) 10µF as C2. PAM2803 datasheet says for C2: 6.8µF min., 10-22µF recommended.
So for the first build - to rule out any errors from possible lack of capacitance - I populated C2 and C3 and pushed in the highest values I had for 0805 (22µF, measured ~20µF) and 0603 (4.7µF).
In the next build I wouldn’t mind to use 10µF for C2 and either leave C3 empty or take a 1µF or 2.2µF.
I already consider to remove C3 from the board to get some space if needed (LVP resistors perhaps), but I tend to implement LVP in 17mm boards first for further development and only when we have a solution there I will start to see what can be put into 15mm.
:slight_smile:
In OP I redubbed “released” to “shared”.
Just to avoid a misunderstanding that we have finished, tested, evaluated, ready-for-industrial-production boards.
We haven’t.
Just some boards I cobbled together for personal use and did not mind to share.
It is just proof of concept code but you could try this:
#define F_CPU 4800000UL
#include <avr/io.h>
#include <util/delay.h>
#define FET_PIN PORTB1
int main(void)
while( 1==1 )
/* Empty the gate. */
DDRB |= (1 << FET_PIN);
_delay_ms( 1 );
DDRB &= ~(1 << FET_PIN);
    for( uint16_t i = 0; i &lt; 150; ++i )
        /* Charge a bit. */
        PORTB |= (1 &lt;&lt; FET_PIN);
        PORTB &amp;= ~(1 &lt;&lt; FET_PIN);
        _delay_ms( 200 );
It's a slow ramp on the FET gate charge which repeats forever. It goes from 'invisible' to 'a bit too bright to look at directly' on a BLF-A6 FET+1 driver. From the spec sheet, your small FET should charge much more quickly as the gate charge is about 1/8th. You can avoid the higher end by reducing the '150' loop counter. Slow down the ramp by increasing the '200' delay. If the steps are too large, a CPU frequency of 9.6 MHz instead of 4.8 MHz should help. And if it's still too bright, PWM could be done with some work. Oh and keep an eye on the FET if you run this, it could get fairly hot at moderate output.
How this would behave with a depleting cell depends on the output voltage of the boost circuit at near zero load (ie. I don't have a clue). On a li-ion setup I can compensate for the lower voltage with more charge. Could perhaps do something similar here if there was a voltage readout, which I understand would be tricky to fit in there. The other "fix" is to just have more modes.
Also, I've never tried this but the weird code could be probably replaced with regular PWM and a resistor of the right value between the PWM pin and the FET gate. I'm not sure about the component sizing (not my domain and seems very tight) but ideally, I think you could keep pin 6 as it is and connect pin 5 to the FET gate via through a resistor, or the other way around. That would make one PWM channel pulse the FET full on for the high modes and the other give the FET only partial charge for the low modes. It would be much easier to adapt current dual-PWM firmware that way. A simple matter of disabling output of the unused PWM pin for any given mode.
A completely different option would be to keep the "full on" short FET pulse but with lower frequency to reduce the PWM duty cycle. You can get N times lower output by decreasing PWM frequency by a factor of N. But it will become ugly at some point. It is also somewhat annoying to code, like what I posted above.
Anyway, this long rambling post is just to say there are options so don't worry too much about current lack of a very low mode. I hope I didn't write anything too crazy :)
Ordered some of each board. Hopefully, I will have the time to join in on the testing. Has anyone identified a low cost source for the inductors in the US?
I just ordered my allotment of boards from OshPark and forgot to order the 17mm set of these. :frowning: Will have to get a set on the next order, wanted to test in a P60! These look very interesting.
Good work!
There seem to be a lot of inductors on eBay but the nice short ones HQ used might be only mouser/Digikey.
I just don’t have the time right now to read all the separate threads on this topic. Mostly, I just want to know what range of smd footprints will work with these boards.
Regarding inductance rating. I see recommended above 4.7uH. In another thread there is a pic that says it has a 2.2yH, Coilcraft XFL4020 used. Was yH a typo? Sorry for the newbie questions but I haven’t spent any quality time with inductors and don’t have time right now to do so. I only understand what they do at a high level.
guys, thats me: :laughing:
@fixed it
That sounds promising.
I admit I understood only every second word of what you said, but i’ll dig into it.
I’m no firmware guy but I usually can adapt what others come up with.
@ImA4Wheelr
Here in EU these Coilcraft inductors even increased in price about 70% in the last 12 months. They were expensive back then, they need to be weighed in gold by now.
Any other inductor with the µH-specs and size should do, I tried several (look at my 3rd pic in post#4).
The other (non-Coilcraft 2.2µH) inductors have mostly higher DC-resistance and thus are less efficient, like, losing some 5-10% output in 1AA and (some) runtime in 2AA.
All inductors I tested (same board, swapped inductors, same cell, measured output current; very humble and unprecise testing scenario) did work on the Nanjg110. Only difference I experienced was efficiency.
Datasheet does not say above 4.7µH, it says minimum 2.2µH, 4.7µH recommended. All commercial driver of this kind I recollect have 2.2µH inductors. I tried 4.7µH and the only difference was that they were less efficient at similar size (as they have by design a higher resistance than the 2.2µH). 4.7µH might/will have advantage in other terms (saturation?) but i wouldn’t know anything about it. I’ll stick with 2.2µH. You can take the inductor from the FT-driver for starters.
y makes for µ on a keyboard without a µ.
@mattlward
Allow for 12-15 hours and you get another 17mm driver board to choose from.
Hey HQ, thanks for the update… I will wait a day or 2. So, the build is a parts steal right? Any idea what kind of output might be there?
Good point.
I added the SMD part sizes in the HQB15 v3 post. All HQB15 (v1/v2/v3) have the same parts.
In the HQB17 v1 post the footprints are stated. Notable difference is the larger inductor.
Yep, oncoming HQB17B is specifically meant as the simplest possible part swapping build (keeping fingers crossed that C2 will be sufficient).
Output should be in the 750mA range with 2AA. Very well within the spec of the PAM2803. Output depends on R1 (Sense Resistor) and the FT driver has R1 = 0.120 Ohm (“R120”), could change with any production batch, as always.
