thatâs awesome!
Lol, wowâŚthatâs insane!
Awesome! But ehhm, where does the 6V for the MT-G2 come from? Button cells? 2x10180?
:laughing: Thanks. Itâs totally impractical but i like doing this stuff, keeps me smiling.
1.4A from two 10180 cells at startup. Canât wait till itâs dark to try it out.
Nice! It gives me inspiration for a XHP70 I have around doing nothingâŚ
The definition of pocket rocket lol
Very nice
LOL, 2x10180!? Thatâs crazy! The ones I got from GB was like 70mAh or something, perhaps itâll work as a flash for your camera? One massive but short burst of light, then itâs flat againâŚ
Speechless. The things some people do.
Did a runtime test with it, around five minutes till the cells are at 3v, Not too bad for what it is.
It just puts out a wall of very nice light, albeit briefly.
The 10180âs i used are these ones fyi
Modded these in a 2 day modfest (Tuesday/Wednesday) SD75 - Kit built FETVishayDD driver and custom home made 26mm to 33.7mm copper driver adapter. The new XHP70 P2 1C shaved emitter. 18awg Leads. Carrier contacts made from copper and braided springs. Tested driver and emitter outside the light at 13.75amps off 2S VTC5âs. The Cometa (Dark OPâs) other wise known as (MELT DOWN) - Stoned the dimple off the emitter shelf, for a newly re-flowed XPL-HI 5700k on a Noctigon, 17mm FETVishayDD kit built driver 20awg leads, contact springs braided, KAN9 FWD switch and Tacticool ring added for 6.55 amps off a 26650 Basen right off the charger. M25C2 Turbo 20mm FETVishayDD simple H-M-L UI w/memory XPL-HI 1A on a Noctigon and sitting on a stripped noctigon, with plasti-gage shimâs to tune the spot, for throw (Variable adjustment) pulling 6.4 amps off a VTC5. All perform better than stock
Today I modified an unexpected day off work into a splendid day at the beach with the kids (thanks to glorious weather and a bit of an untuth to the school )
What a great mod!
Put an XP-G3 S5 3A emitter on a 16mm copper star in a Blue Convoy S2+ with an LD-2 driver, moon enabled. From a rested Efest 3000mAh dark purple cell the LD-2 pushes 5.78A through the little G3 for 1300.65 lumens out of the original orange peel reflector. These little bad boys are going to be handy!
I am so glad I have them on order via kiriba
One of my BLF D80âs. The main thing I did not like is that it has memory and the levels are descending. I have grown to prefer starting low all the time and going up.
So today I removed the standard driver. I replaced it with a 17 MM Qlite from mtnelectonics. The Qlite has the star off-time firmware with custom levels set to 1, 5, 15, 40 and 100%. Those are set to ascending and moonlite is enabled for a total of 6 levels. 8 * 7135 for 3.04 amps (standard config from Richard).
I left the standard LED and MCPCB as is.
The head of the D80 does not permit the use of a 17 to 20 MM brass adapter ring; too much thickness for the brass retainer ring to catch threads. However there is room inside the head, towards the front, to use a 20 MM partition board and place the 17 MM driver inside, between the front end and the cell tube. This involved sanding down the 17 MM to make for easy fitting. And because of the anodized internal thread at the driver retainer I had to insert a connection between the outer ground rings where the driver and partition are about 1 MM apart. I found I needed to solder a small brass button to the end of the stock Qlite spring to have sufficient clearance to make positive terminal contact.
My camera had a dead battery. No pictures as I was impatient to do this. I can easily take a photo of the driver / partiton if anyone wants to see it.
I bypassed the spring because the soldering iron was hot and, why not.
The UNI-T clamp meter gives a reading of 3.01 amps after 30 seconds, measured bypassing the tailcap with an 8 AWG jumper, using a Panasonic NCR18650B protected 3400mAh (EVVA).
I like it!
todays little effort was to fit a xhp50 on sinkpad and mtn fet guppy drier to a convoy c8 with a ext tube to run 2 x 18650
it draws at 8amps at tailcap on 30qs⌠planning to trim it down to run 2 x 18500s
Right before bedtime last night I tried shaving one more little detail off my newly built SS/Cu X6 Triple XP-G3 S5 3A. This one little detail gained me ~600 lumens, I hand polished the honeycomb pattern off the CUTE-3, bright clear finish up top now. It went from 3329 lumens to 3936.45. Worthy!
Worth mentioning, the little dot in the corner is on the positive side, I re-flowed them wrong onto the Noctigon so I simply wired it backwards.
Very nice build!
How you polish them ?
We have a cast iron sink in our laundry room, the sides are nice and flat. I use wet/dry sandpaper on the wall of the sink and press the face of the optic into the wet sandpaper, round and round we go! Started with 220, cleaned it up a bit at 320, then polished with 1500 til it was pretty smooth. A final polish with Motherâs Aluminum Polish on a newspaper and it was crystal clear. Clean it with soap and warm water to get rid of polish residues, dry it good, looks and obviously performs much better. Took maybe 10 minutes all told.
Edit: This leaves the surface flat, originally there is a dimple towards the middle and this is what takes the time to sand down to, in order to remove all the honeycomb pattern. I havenât tested how it works to leave the honeycomb pattern in the dimple and only polish the outer portion, since throw comes from the outer part of the âreflectorâ it might actually serve well to give a tighter beam and diffuse the spill portion to leave the dimple, pattern intact. Iâll re-do a CUTE-3 and test it, see how that pans out.
