Don’t forget about the Convoy S7, which has a polished steel host and a rubber boot. The boot is easy to switch out to any color you want. It’s also a bit narrower than other 18650 tube lights since the steel doesn’t need to be as thick to get the same strength, and it’s much more resistant to wear.
However, it’s also heavier and can’t shed heat as well, so not a good choice for a triple.
I’ve got a black boot on mine right now, but the plan is to give it a clear boot and fancy lighted tailcap.
SS switch with clear body and SS clip, do not care if do not match exactly . New here, and every light seems to be black body,black tailcap button and black clip ,like the change! :sunglasses:
The deep carry clip is black and can’t be changed (polished) without redesigning the light. There’s always the bolt on stainless clip. I’m not a fan of it personally but some people like it. Clear ano with the standard stainless button is easy enough though.
Apparently Halo, not as many as I would have thought. Still Simon is working on making it happen for the Desert Tan S2+ so if there’s enough interest maybe it could just be made a selectable option like an emitter change as Dwantink suggested. I like that idea too.
I hope they are too. If given the opportunity I will post pictures of the clear S2 with the black switch and the regular switch side-by-side. That would be much better than my words.
I like the idea of a option for the tail cap switch. to make it cost effective add a dollar to the choice, SS, black or rubber. Build 30% black, 30% rubber and 40% SS and see what sells best. I would pay a dollar to get my choice. Many would not! Maybe a bad idea?
I don’t think it’s a bad idea but I don’t know if Simon would go for it or not. A choice between metal switch colors seems reasonably doable but to go with a rubber switch requires a completely different tail. I’m not sure if he’d want to do two different versions.
I like the simple silicon boot better: it feels better, looks better, you can use dimmer leds if a lighted tailcap is made (messes less with the driver), and it is more waterproof.
I understand your thinking. I don’t agree on the looks part but I respect your opinion. I do like the light up tailcaps and while I understand they shine brighter and are more beacon-worthy with a translucent switch boot I love the way the subtle glow looks in the SS switch even though I know it’s less efficient. Honestly I’m completely torn on this issue. I really like the clear switch boot as shown in the clear sample. That said, only 25% voted for the rubber boot. The stainless switch is unique in a field where too many lights look alike. That’s another reason I pushed for the black stainless switch. It’s unique.
I hope I have posted in the correct area, but may I ask if Convoy has decided on a switch style for the clear S2+ yet?
If not, I would like to say I prefer the rubber style switch boot. The design is overall simpler and proven, and one can change the boot colours easily and cheaply if they like
I’m a very big fan of Shenzhen Convoy Electronics Co, own many of your lights and given many as gifts. Will be sure to buy a couple of these clear S2+ when they come out. (regardless of which style switch Convoy release and hoping for the clear shorty 18350 tube too)
Thanks for what you are doing for the community Simon.
I enjoy reading the articles from the community here. Was a collector of Maglite and hi current Ni-Cd cells many years ago and have started collecting lights again. I also collected many Fenix lights and AA eneloops but once I discovered “bang for buck” and customer service of Convoy it meant Fenix collecting ceased.
Clear convoy S2+ with clear rubber switch boot, black clip and 18350 tube would be a cracking light.
I think the SS button (especially with that ring of light) looks best by far.
I don’t think it’ll mismatch with clear anodization, it’s just a different tinted metal.
Pity there’s no plain SS clip though.
Don’t know what material the black clip is, but maybe strip the black paint off?
In this particular case it should stay with the SS switch. It is what will set it off . Making a black piston switch would be a waist and would diminish the overall look . I have no issue with installing one of Simon’s new black clips on it, as it would balance out the light. Just enough black to set off the flashlight!
Those that care to go with lighted tail cap can still do so if needed. It does look nice lighted.
