I have some time to kill so I’ll throw in my .02 cents.
It all depends on the cost factor, application and intent. Ive had +18,000 OTF lumens of wide angle HID on the front bumper of my 4 X 4 for 3 years and have thoroughly enjoyed them without any problems. They even came with their own wring harness, which makes the installation a piece of cake. They can stay on for as long as the truck is running and wont overheat, dim, change luminosity or color temperature. When voltage sags at low RPM, they still remain at the same constant lumens without dimming. Nothing beats their simplicity and ease of use for plug-and-play/simple mod installations. They just work. I did buy a high quality HID kit to avoid the pitfalls associated with all the cheap chinese garbage that has saturated the market. The housings I put them in are the standard in professional off-road racing as well as many military vehicle installations… which defines their amazingly well controlled beam profile. All said, the intense concentrated light source of the 100 watt HID mod is what brought them to life.
My friends “all-out modified” 6.5A TK61 got completely blotted out by my 100 watt HID searchlight conversion (My HID has at least twice the range 5 times the beam width). Although the flashlight is more convenient, you almost cant tell if its on or off when compared to my HID. An AGM cell pack in my backpack gave me a 2.5 hour continuous run time @8000 lumen output with no thermal considerations of loss of lumens. His TK61 was thoroughly overheated inside of 4 minutes and needed to be shut down! :confounded: The ergonomics of the spotlight also made it far more comfortable to use, easier to carry and aim.
I’ll eventually finish my LED light bar project along with its proper heat sink necessary to cool that much power during continuous low speed operation, but it will be to compliment my HID’s, not to replace them. Even with the advanced high powered drivers that were custom built for this application, I will still have to deal with heat sensitive logarithmic current controlled throttling for the sink as well as the drivers, put up with the dimming of the LED’s at low RPM’s (as voltage falls below vF of the array), long expensive heavy gauge wire runs, large marine grade relays and fuse blocks, 20 lb heat sink, wiring nightmares and very expensive CNC milling. Then make it all waterproof and reliable.
Then there’s the variable beam monster HID in my sig, that will easily obliterate anything LED in its size and price range… not to mention its technical excellence as an engineering masterpiece.
I keep waiting for large efficient single die .5 - 1.0” emitters with at least 4 times the surface brightness of the current top offerings, but I think we will probably need a new and different technology to achieve those goals.
Thanks to the rigorous testing of others, I am only familiar with the 100 watt HID kits with the large ballast, external ignitor and ceramic lamp base. There are several vendors on ebay and aliexpress. Just check the pics in my thread and get the exact same kit and avoid the others. You need to specify bulb mount type and color temp. Maximum lumens is with the 4300k bulbs. Knock on wood, I havent needed to shop for replacement lamps. They have lasted for at least 200 hours with no signs of degradation in a demanding, high vibration environment.
I bet the Colossus will love a 100W HID. If you can find a good 70W HID bulb w cermaic base for the 100W ballast, you might achieve even higher surface brightness. Sorry, I cant find the thread now.
Lets hope so, but they still have a long way to go to make any of those other solutions affordable and mainstream. And they might not ever be suitable for modifying existing hardware to produce cost effective, simple, worthwhile results.
IMHO, for many inexpensive, high lumen applications (especially in DIY and retrofit), nothing can come even close to matching the simplicity, performance/cost ratio of a properly engineered HID solution.
I agree. I have the new LED lights on the 2016 BMW X1 and it is absolutely fantastic. From the outside, it’s “just a projector” but I can clearly see the emitters through the lens. The cutoff is exceptionally crisp and the light is very, very even. I am lamenting the fact I didn’t opt for the LED lighting for the 2015 Mini Cooper… only halogens swapped to NightBreakers
Having said that, as a proper retrofit, HID trumps LED if only for the mere fact the engineering going into these so-called LED Conversion kits (hey, we sell them, unfortunately!) is a bit lacking.
Cars headlights are not designed for max throw. So it makes sense that LED’s better fit the bill. I haven’t built many serious LED throwers. Best was 800+kcd, 2nd and 3rd best were around half that. None of them throw as well as my 35 (maybe 55watt) HID spot light.
It would seem HID are cornered by LED into an ever receding pocket of niche usage, they are much more complicated by design especially for hand held use but LED that are now more efficient than HID still cannot touch it for ultimate intensity and CRI.
I find little reason to switch over to led bulbs in my bathroom fixture. Little running time and frequent ON/OFF switching is the perfect recipe to keep using my beloved top CRI incans I can buy everywhere for cheap as @#$%. The fixture keeps the bulbs upside down, so when the filaments break a bit I just have to give a few taps to the bulb and it works again. ;-)
Oh wow, you didn’t know that HID bulbs can be used in more than just flashlights?
Do you think that sky beams use LEDs? lol
HID have tons of applications.
The 2.3M lumen bulb isn’t handheld, but to prove my point here is a flashlight with ~50Mcd which is impossible to achieve with an LED:
Go ahead and try, plenty of people have, there is no LED anywhere close to this.
Also, single HID bulbs can do 8000lm+ while nearing 100lm/W efficiency.
Go try to find a non-COB LED which can do that many lumens at that efficiency. (because a COB is useless for throw)
The closest I have found is an XHP70 at 12-15 amps producing 6-7000lm at about 60lm/W efficiency.
Then why quote it?
To encourage more people to click the button?
Just press it and move on, if some meaningless words on a screen really affect you that much.
Yes you are right about HID performance and record breaking but when we need a trailer for such light it is really no brainer to make assumption that something is wrong with us; but in a good way of course cause we are probably preparing for war or alien encounter on our diy ships, helicopters and planes.
For me HID in flashlight format was dead several years ago and if you see the future for HID in our regular flashlight use and modds then I think you are very optimistic person.
There is no definition of “flashlight format” other than a battery powered portable device.
Yeah I agree it’s not any good for an EDC pocket sized light, but you need to understand that not everyone uses flashlights to carry them in their pockets.
The maxablaster is still a flashlight by definition.
No, definitely not in this forum where almost everyone is buying single or double digit cost flashlights.
HID is obviously way more expensive and more for enthusiasts.
Expensive and rare =/= dead.
Or maybe you think we should say bugatti and all the other hypercars are dead just because they are rare and expensive and few people use them?
Actually, this thread is about HID in general.
I don’t see anywhere that it says “HID is dead for pocket lights” it just says “HID is dead”
The flashlight world is larger than just pocket lights, and just because the majority of people don’t use something doesn’t mean it’s dead.
This is a flashlight forum after all, not just a pocket light EDC forum.
PS- there is no such thing as “HID form factor” you just made that up xD
Did you mean to say “EDC”? Because I can see how what you’re saying applies to EDC lights, but definitely not all flashlights.
Pfft…the HID on my boat makes the longest throwing LED flashlights seem like dim candles blowing in the breeze. It is said to be “portable”, and I would almost have to agree. :laughing: They are only fun for about 5 minutes when stationary, then you’ll be wondering how to make it portable to use on the go.
Has anyone else grabbed one (or similar +1kW) to play with and mounted atop a pickup truck or boat? A manual roof mounted pan/tilt would be interesting and a whole lot less complex/expensive than my mod.
All mentioned above have sense and it stands weather we talk about our classic handheld flashlights(90% of market) or about specialized vehicle or huge HID lights(10% of market?) but also because of everything said and mentioned in previous posts flashlight manufacturers will tend to work with more cheap and reliable parts in a future so yes I agree with DBSAR… HID is not dead yet but it will probably be in a future, and all that because HID technology probably reached its maximum potential while LED has still more room for developing (although currently in LED technology I don’t see any progress especially when it comes to super throwy emitters we had 2 years ago).
