+1!
I like it!
Is mode change in descending or ascending order?
PWM?
What accessories come with light?
It’s a reflector.
Does it come with a centering ring for the XP-L version?
Beam seems to ringy if it is a reflector. It might be similar to dqg mini
HiReManG
The bezel is not glued.
Thanks
Michell
TIR lens, No memory start from Low mode, Diffuser included.
Hi Burgh
Mode is Low>Mid>High—Double click Turbo, Always start from Low mode.
No PWM.
Accessories includes white Light Diffuser; Spare TIR lens ; O rings ; Tin Gift box
Dose anybody like XPL Hi Emitter? Throw will be better.
Michell
XP-L HI emitter would be nice. Also, does this use separated MCPCB or LED is integrated into the driver like the DQG tiny?
It use 16mm MCPCB for better-heatsinking.
Michell
I want one!!!
… so much that I actually just ordered one with neutral white emitter.
NICE!!!
So much want in this thread!
Michell,
Thanks for the reply, one more question though. Is the TIR a common size one like 20mm? I would want to replace the stock one with a floody one. Thanks!
Very cool. Direct access to low and turbo. Titanium looks fantastic as well.
TIR size is 21mm.
Thanks
Dear sirs
Anybody like 18350 size Titanium? We have plan to make an 18350/16340 body for this flashlight to make it shorter.
Michell
YES, would this be interchangeable with the 18650 body then?
drools
