BanL
(BanL)
April 19, 2016, 3:14pm
161
Hi Guys
Cree XP-E2 Red / Green / Blue P60 Drop-in available in KD.
For input voltage 3V - 4.5V
Cree XP-E2 R2 Red 620nm 3V - 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025006
Cree XP-E2 R2 Green 530nm 3V - 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025005
Cree XP-E2 M2 Blue 470nm 3V - 4.5V 3-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025004
For input voltage 3V - 12V
Cree XP-E2 R2 Red 620nm 3V - 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025009
Cree XP-E2 R2 Green 530nm 3V - 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025008
Cree XP-E2 M2 Blue 470nm 3V - 12V 1-Mode OP LED P60 Drop-in (Dia. 26.5mm)
http://www.kaidomain.com/product/details.S025007
Thanks
djozz
(djozz)
April 24, 2016, 10:23pm
162
Found 14mm x8mm boot caps in refreshing different colours, ordered some
http://www.kaidomain.com/product/details.S024982
BanL
(BanL)
May 7, 2016, 2:51pm
163
FmC
(FmC)
May 7, 2016, 10:45pm
164
Nice, an OP version.
I may have to pick one up to drop into my modded L3 , & change over to XHP + FET…
BanL
(BanL)
May 18, 2016, 2:24pm
165
Another Cree XHP35 HI is arrived to KD
Cree XHP35 HI D4 1A White 6500K LED Emitter
Cree XHP35 HI E2 3C Neutral White 5000K LED Emitter
And there is some solder on base plate. You can take a look on these.
Thanks
Rolz
(Rolz)
May 19, 2016, 4:46am
166
Looks interesting. Will be great to see some flashlights based on these LEDs. A 3 x LED model with Multiple batteries may be the answer here as the forward voltage is high.
BanL
(BanL)
June 6, 2016, 3:09pm
167
Dear ALL friends
We are now released a new version of KDLIGHT 7135 Driver board.
New Updated:
Added Battery Reversed Protection
Add the short 4.2mm (H) / long spring 12mm (H) version
S1, S2, S3 and S4 solder pad and ground jumper will be closer to let you solder easier
16 totals programmed output modes can meet your needs
Low voltage warning and LED auto shut down to protect your battery
KDLIGHT 7135 Driver Board
Also, we had introduced a new brand KDLIGHT. We would continue to offer the product with good quality and high Price–performance ratio.
If you have any comment on our product, please don’t hesitate to contact us.
Thanks
Ban
brted
(brted)
June 6, 2016, 3:42pm
168
Looks like a great driver with lots of options. Thanks!
mattlward
(mattlward)
June 6, 2016, 3:44pm
169
Looks like a nice regulated driver! But a steel spring… really?
keltex78
(keltex78)
June 6, 2016, 3:51pm
170
Nice! Interesting selection of modes here, and the longer spring is a nice addition:
BanL
(BanL)
June 7, 2016, 2:40pm
171
Hi Mattlward,
This is not Steel Spring. This spring is brass material with silver coated.
The spring wire size is 0.7mm.
Thanks
Ban
djozz
(djozz)
June 7, 2016, 3:23pm
172
Last night I ordered one of the KDlight V3 8x7135 drivers. I like the added reverse polarity protection and how it deals with low voltage. The mode spacing is good and unlike the Qlite you can choose for no memory, which is essential for me.
BanL, do you happen to know what the PWM frequency is (too high to notice I understand but how high?)
If it works as it sounds, it is going to serve in a mellow XP-G3 high CRI triple build.
mattlward
(mattlward)
June 7, 2016, 3:27pm
173
Hey BanL, thanks for the reply… Guess I will need to order a couple! The specs look great, I like regulated drivers in many of my EDC lights.
Which is the new KDlight?
Also will you get more cheap C8 hosts ? (like the old with red leds , they were great hosts).
mattlward
(mattlward)
June 7, 2016, 5:55pm
175
I really like the KD C8’s as well, good selection of parts for them as well.
brted
(brted)
June 7, 2016, 6:13pm
176
giorgoskok:
They have a 5-mode XM-L T6 C8 for $10 on clearance (bottom of the home page)
BanL
(BanL)
June 8, 2016, 6:40am
177
djozz:
Hi Djozz
Thanks for your interesting with the new driver board.
The PWM frequency is 15000hz.
Thanks
Ban
BanL
(BanL)
June 8, 2016, 6:42am
178
giorgoskok:
Hi Giorgoskok
We will update the new product desc asap.
We have re-designed the new reflector for the XP-L HI LED .
Thanks
Ban
Thanks Ban !
Some beamshots would be superb!
mattlward
(mattlward)
June 8, 2016, 1:01pm
180
Well heck, I am going to have to order another reflector and pill and try the XP-L HI now that it is optimized! I have several of their C8’s, not as clean as Convoy but very functional!
