These two screws are isolated from circuit wire which also called MCPCB board so that should not cause a shot circuit even when the screws got contact with the body.
I received an S41 Nichia today. Ordered shortly after the pre sale started with expedited shipping.
Man, this is one sweet bright little, and I mean little, light!
The optics are quite a bit tighter than a Carclo narrow quad with 219C.
Currently running it with an AW 800 mah 12A IMR 18350. I’ll try and get a tail clamp meter reading in the morning. Not as bright, of course, as my DBCustom modded Cu X5 with the quad 219C, with narrow Carclo, but that is max modded. This is stock! And, it is holding its own!
I just got a few of Richards newest FET + 1, Bistro drivers and the new quads with XP-G3’s, and both flavors of 219C’s, now how long until I have to try putting one of those in?
I’m curious if I will be able to use the stock optic with one of those MCPCB’s…
I think most people will be stoked to get these! I have an XP-G2 model coming as well. Had to try them both…
what should i say? I can locate the short on the edge of the MCPCB where the screw sits with a DMM. It is not the body and the screw causing the short. The screw touches the positive trace of the MCPCB. It is not a big deal for me personally, because i often modify lights. I placed a piece of an insulator over the edge, that worked for me. A disc only didn´t.
And please remember, the light worked without shorting when i got it. But i think this could be improved in future designs for safety purposes.
+2
Today with our neighbors with watching the DFB Cup final (Bavaria Munich:Dortmund) afterwards and tomorrow with some friends again. Yummy :partying_face:
The real thing here is what happens AFTER the light is shipped. The factory expects us to use the light, when we get it it’s perfectly useable. But once it’s taken apart and inspected and put back together, well, they can’t control what happens once the light is opened and this is why we see some lights we can’t easily get into.
Yes, simply putting the LED’s on the mcpcb in reverse, with their positive side on the negative pad, then placing the wires on the opposite way, will reverse the board and cause less potential danger.
Sharpie has said it so many times to try and get their attention. It needs to be addressed before someone has a catastrophic failure. Bar-B-Que?
Hi all,
I’m a NOOB, but have been lurking around here just long enough to pre-order one of these S41’s. Being I have zero experience with flashlight modification… in order to make this light safe could I apply thermal adhesive (Arctic Alumina Thermal Adhesive) around the outside edge of the MPCB, thus alleviating the need for screws?
To make it safe, don’t open it in the first place.
Edit: I know that sounds facetious so let me explain. It’s the very act of taking it apart and putting it together that causes the unsafe potential. The masking is actually tough, the light comes in working order. Taking it apart is how the masking get’s compromised, tightening down the screws and potentially ripping the masking with a rough edge or excessive pressure.
By NOT disassembling it, it stays safe.
EditII: As for the soldering, anyone look at Vinhs soldering? He knows he’s horrible at it, it’s a running joke, but his lights work, and work well. Just don’t look at his soldering if that sort of thing bugs ya.
