Since he says the drill could “do something” with that puny battery pack, I am going to presume it could deliver 30ishC discharge rate, for up to 7'2V×18A=129'6W of power being fed on the motor. Now, by the law of Ohm, if we increase voltage by 50%, current increases by another 50%, for 225% of the expected power output with the default pack. Now, if we assemble, for example, a 3S2P battery pack with, for example, LG HE4s, we can be sure for it to be able to consistently deliver at least up to 10'8V×27A=291'6W of power. Sounds really good for such a small battery powered drill, and a 6-cell battery pack fits inside that plastic box with ease. A $1'29 voltmeter can also fit inside.
With regards to charging the pack, I was even thinking in using independent TP4056 charging boards in series attached to the cells inside the pack, which could be fed with standard smartphone chargers in an independent fashion, maybe even build a special charger with three isolated AC/DC boards in order to allow each TP4056 to charge its serial 2P unit uninterdependently: the cell pack would auto-balance on each full charge.
Well I’m curious as to how you can actually check it given the obvious evidence that these pricks will print any kind of label on anything!
Perhaps if you had access to a bench power supply you could test it to the point where it starts smoking and melts, then build your new battery pack from that info.
While the motor may take the raised levels, the wiring and switch circuitry might not.
With cheap tools there’s no great loss when the “magic smoke” escapes. I have a few cheap tools which I keep around to abuse so that my nice tools stay nice. One refuses to die no matter how hard I push it so you never know until you try!
Well, small electric motors are already very cheap. I wouldn’t expect the Chinese to make a new motor just so that they could label it improperly and stick it inside a tool where it is highly unlikely that anyone would see the label. Additionally, I’d expect a cheap, off-the-shelf motor to be rated at least 12V DC. Those motors can run on less than 12V. They are just slower with lower voltages. And, as Barkuti says, they can take actually a little over their rating as well. But, the best thing is to know what it is rated for, so that you have a starting point.
Once upon a time I had an electric motor which I removed from a hair drier, ducted fan style. It was fed with 12VDC (100Hz pulsed) by a diode bridge off the hair drier. I however, plugged it into a linear 24VAC output transformer rectified with a bigass electrolytic capacitor pack (10000+μF = 10+mF). I can estimate the motor started being fed with well above 30V and 3+A, with a total combined output power surpassing 100W.
An intense “continuous spark donut” was clearly seen on the motor's conmutator. It pulled so hard that you had to firmly hold it on (or else it would blast off). LOL!
funny thing is it would be 24v if those were li-ion.
i would run it at 24v as a test so you dont waste your time building a pack if it sends up smoke signals.
Your math is correct, 7'2 volts nominal; and nothing else, really.
As the drill owner told me it had “adequate” performance when new and he mostly uses it as some sort of screwdriver to play with his bike, I think I'm gonna go the 3SxP li-ion route.
6S li-ion is 21'6-22'2V so, not yet there strictly speaking. And remember W = V²R here so, those voltage levels mean we'd have all the tickets for the Magical Smoke Lotto.
Well, before summarizing my friend the potential upgrade cost with 3×VTC5s, a proper CC/CV charging module and a small voltmeter, I've made a simple small load test on the drill's charger stand PSU (rated 24V 500mA on its label): after loading it with a 37'5Ω combined load resistor, I've measured 11'21V load voltage… :FACEPALM: so it struggles to deliver a measly 300mA, at a much lower output voltage (no load volts ≈19'7ish).
Do you believe I could find a speedy hamster on a wheel inside of it?
I have one of three voltage monitors. It flashes total voltage and voltage of each series cell. It also emits an load audible alarm when voltage gets too low. I don't know what it's parasitic drain is and I probably don't have anything sensitive to measure the drain. It fits standard JST-XH connectors like used for hobby chargers.
For the purpose of the thing, I aim at minimizing costs, without sacrificing performance. My idea is to install the pack bare inside the housing, attaching it to the terminals with a truckload of copper wire. My smart & cheap plan is to install the multimeter inside, and attach it to the battery terminals in series with a momentary pushbutton and a small capacitor in parallel with the meter; that way voltage can be easily checked with a small push on it, and the pack is not drained by the voltmeter.
Been somewhat “away” from the forum and related stuff lately, got back to labor nearly a month back now.
This project is “oficially jammed”, I guess the drill's owner really liked the way I restored/upgraded his little laptop's battery pack, he really finds use for it at work.
He may not have liked much the drill pack restoration figures I gave him, but for sure that must have had to do with these facts: a) the drill was a über-cheap piss poor tool, hard for any figures to look good in such a case; b) he may not have real need for it.
Maybe if he finds some extra spare €uros to squander on this stuff soon…
Typical blf mod.
$25 in parts for a $5 drill.
Interesting to see how the rest of it holds up.
Btw a 15a bms will be inadequate.
Stall/near stall may be 50+a!
snakebite, my BMS choices have been influenced on a tad off-topic handful of posts brief discussion I had a few days earlier about restoring a Hilti TE 10A hammer drill power source.
Briefing: 1.2 - 1.4Ah sub-Cs, operating at up to 15A (≈10C cells).
… it more or less becomes clear to me that not even in their wettest dreams would have those AA Ni-CDs provided more than around 8A comfortably. Bottom line: the appliance was a piss-poor electric screwdriver, to start with.
Yesterday I sent inquiries about that inexpensive 15A BMS from Aliexpress to two sellers, asking for the transient/momentaneous operating current values on it. After receiving the same useless copy/pasted answer/information in both cases, already provided in the product ads anyway, I've decided to go with the eBay 15A BMS which, being like the 8A (17A transient current) unit with twice the FETs, I presume its transient current value should also be 2 × 17A = 34A. :THUMBS-UP:
