Yeah, the 45-second turbo timer was calibrated for the BLF A6, a single emitter running at ~5 amps. A quad should probably have a shorter timer, especially if the cell is 18650. The copper pill should help, but the timer might still be a bit long.
… and then there’s the potential for directly shorting BAT+ to BAT- if the screws cut through the MCPCB’s protective coating. A simple polarity change or wider keep-outs could have greatly reduced the impact of that risk.
Which is exactly (one of the things) the protection circuit in the cell is designed to do.
So forgive me for maybe beeing stupid, but I can’t see the problem (with using a protected cell).
In lights like this, protected cells consistently measure lower lumens and lower lux than unprotected cells. And on triples or quads, many protected cells trip due to overload.
If it physically fits, if you don’t mind the lower output, and if the protection doesn’t trip, protected cells are totally fine.
M4X M4D measured more than 9Amp from 30Q, and I think this is target for quad xp-g2. Is there any protected cells for such current available? Don’t think so.
Simple cells for low currents will degrade fast if you are going to you them in direct drive.
I am using Keeppower 2900 mAh protected in a XP-L HI triple S2+ without problems. Trip current is about 10 amps. This light pulls over 12 amps with LG HE4 and up to 9 amps with the Keeppower cell. Can’t use this cell in a Nichia 219C triple though, protection trips in highest mode.
There is also a Keeppower 3500 mAh with this rating, but haven’t tried it yet.
could someone please tell us who don’t know things electronic, what the issue is here? I have read about it but don’t see it. Someone said the + and - should be reversed? What is the danger here that I cannot see? Appreciate your pointing it out, thank you!
Just under that red masking is a copper trace that carries the positive to the LED. If you take it apart and put it back together, there is a chance the screw could scratch the mask down to the copper trace and short positive to the body, which is negative, thus creating a dead short to the cell. Not good…
If one was to reflow the LED backwards, and reconnect the leads feeding it also backwards, it would only bypass the driver, running direct drive from the cell. No modes, but no venting with flame either…
Understand?
Edit: If you never remove those screws and reinstall them, there is virtually no danger of it shorting.
Would swapping the positive and negative on the board solve the safety issue with the screws? (reflow all LEDs and rotate them 180 degrees. Reverse the driver wires)
appreciate trying to educate me but I don’t see an outer and an inner circle? I don’t see this board as being any different than any other board I’ve seen. Dos most boards have na outer and inner circle? And are most boards opposite of this one? Some one has a keen eye (sharpie) to notice this. I believe I read in this thread that an ERROR was made on this in the planning stage. Lots of other boards have screws on them, I think my OLight M3XS-UT has them. Why use them if they have the possibility of scratching the board? Bizarro!
I should not worry myself, I’m just an end user but thanks for the education.
Basically, the product has a copper board inside. The board is painted red and held down by screws. If the screws scratch the paint, it shorts the battery to itself, BAT+ to BAT-. So, next time you turn it on, it’ll either melt something or explode, depending on how lucky you are. Do you feel lucky?
If they reverse the polarity, scratched paint would have much smaller consequences. It would short BAT- to LED- and make the light always run on turbo instead of having other modes. Not great, but not fatal either.
Or if they had used wider keep-outs around the screws, scratched paint simply wouldn’t matter.
So, the short version is… scratched paint could make it self-destruct the same way as the Cometa did for some people.
With a protected battery, the worst that will happen is just that the light won’t work, right? Or can something bad still happen with a protected battery?
