*BLF LT1 Lantern Project) (updated Nov,17,2020)
This Prototype has all those you listed above, except the built in Charger port. Right now the prototype is very water resistant, (it can handle short submersions) its made of solid aluminum (as its SRK based) it has a great moonlight mode that would allow it to run continuously for months (with the Q-lite Rev. 105 Nanjq driver it has) output is very good with great run times, (700milliamps on high with four 18650 cells all in parallel keeps the XP-L in its most efficient output vs. Amp-draw range, and on medium mode will give you a couple weeks of run time using it 4 hours per night) and with the down-firing LED & reflector design it has the least glare out the side of all the other lanterns i have seen or tested.
A blue-print type drawing and specifications for this prototype will be posted soon, and discussed with Kronos so he can work his magic with manufacturers/brands to get this into a production model soon.
Thumbs up from me DBSAR! Keep up the good work :slight_smile: .
Great result man!
A we some build.
Very useful
That’s the best lit camp I’ve ever seen! The prototype looks awesome!
Great lamp! And now for the production model. But whatever screw-ups there will be in the chinese manufacturing process, it will still be miles better than any lantern for sale today.
The Lantern is looking great. Thanks for the update. Im getting excited.
Man, there’s definitely no shortage of lights when you’re around.
Thanks for the update. Great to see the lantern out in the wild. Tint looks gorgeous and run times are impressive!
Looks really nice! Just curious on how hot it got when running it continuously on high for long periods of time.
Nice pic!
I LOVE IT! You’re doing some really solid work and I can’t wait for these to come to market. Thanks again!
The top got warm, but not overly hot. :slight_smile:
This looks great! I like what you are doing with the design and building it based on actual needs and wants of campers.
I hope Kronos can find someone other than Manker and Banggood to handle this. I’ve had about all I can take from those two companies.
+1
Manker and Banggood to handle this??? Please avoid it. I do not want a bomb.
I withdraw if they are chosen.
^ This. What are everyone’s thoughts on Thorfire? I have a few of their lights and the build quality seems good.
thank you all for the great work.
for me as previously noted the number one issue is glare. i think this design has covered so many things i would never thought of.
but…
when i think of glare it is the direct line of sight. (we like car headlights becuase we sit in the shadow). imagine how fatiguing it would be to “see” the filliment (point source) of our headlights while driving.
if the design will not allow a larger brim (for lack of a better name) can an allowance be made for an aftermarket brim.
i want to be able to read by it and not have to “see” the actual point source of light. i hope my point both makes sense and gets traction.
again brilliant prototype but i dont see a brim to block the point source of light (for example when walking wih it or setting down on the picnic table).
thank you so much for taking this on.
and as far as mfg i dont think it matters as much as strict adherence to new product release processes. point being that we (the product managers) decide when the spec is frozen and production is started. as i see it ALL! the quality issues on any blf light could have been avoided if the mfg made exactly the light we approved. blf has to date caught every screwup the mfg made. as long as thoes are pre preproduction samples no blood no foul.
until they show they can produce with out screwups we need to be in control of the spec.
they will learn how to build it right the first time.
i would love to see simon and convoy be the mfg/distributor. but if we control when it is approved and when it is ok to produce then BG/manker will also do fine, provided they follow this sensable cavait.
Reducing glare was one of my goals on this. as its impossible to remove the glare completely, i did design it to reduce it quite substantially.
most all current factory lanterns have the LED facing up, or out the sides (where our eyes have it in plain view) i have placed the single LED facing down wards, inside a mildly frosted diffuser, with the LED out of eyes-view when on a table. Also have a close look at the close-up photo of the lantern in the OP, you can see roughly a 1/4 inch solid white “band” around the top of the shade, where that band blocks the point-of-view of the LED form reaching the eye even more when looking at the lantern form the side (as if its resting on a table at eye level.
while the glare is not completely eliminated, (which is impossible to do with any 360 degree area lantern or light, even with an incan bulb) it does have less glare than any of the other LED lanterns we had on the camp trip. When walking with it there was no glare as the LED is facing down. (unless you carried it upside down.
I would love to see Simon build this light under the Convoy brand name. All his products seem very solid and he seems to care about high quality craftsmanship.
he would be a good one to do it, but no matter who can take on to put it to production will have to start from scratch for tooling, (except for the SRK body base/battery tube which is really the only part that can be found stock on a current manufactured light. Will need to hear Kronos’s input soon on that. (sent him a message on it last night).
I would be interested in this light depending on the price.
